Old 09-23-2003, 06:57 AM   #4006
rtypec's Avatar
Originally posted by McLaren
Thanks everyone for your help about the EVO3 bit loose off power (entering a corner).
I noticed that by adjusting my driving style a bit ... the problem has not been entirely solved but reduced a lot ... maybe it is a matter of getting used to the front 1 way ... more than anything else!
I was not using brakes ... but I was taking the throttle off completely before entering the corner at the last moment! I have the KO PRO transmitter and can surely adjust the drag brake ...
Shall I increase of decrease the drag brake? And what effect does this make?
You did not mention earlier that you had over steer entering a corner.
I for one would not use your radio or alter your driving style to fix the problem. However, turning your brakes down to 20-50 percent is okay. That way they aren't full lock when you apply them but slow the car down before or during cornering. This pretty much takes away any panic brake so think ahead
A relatively simple solution would be to decrease the amount of droop in the rear, thereby decreasing the amount of weight transfered to the front. You can also try going one spring up in the front. You can try kick up in the front A block as well. There are many things that you can do but the most important thing is to maintain balance.
rtypec is offline   Reply With Quote
Old 09-23-2003, 08:29 AM   #4007
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by Evoracer
Sounds like Randy is becoming another Macky !!!! I think he's owned at least 1 of everything !! Randy , if you need some input about Tech Racing stuff.....contact Macky, he seems to like them alot.
Actually my buddy Dave over in J-Land sold me on their stuff, said it's the hot car over there, so now I just gotta get one sent over here
Old 09-23-2003, 01:46 PM   #4008
racer's Avatar
you should try out the MY02-R. looks nice!
racer is offline   Reply With Quote
Old 09-23-2003, 02:48 PM   #4009
racer's Avatar
anyone here know how to read Japanese or at least help translate an article?
i'd post it here. but i think it'll be larger than average size for the forum to handle. guess i'll need everyones approval before posting.
this article talks about the Evo III and the SD. conversion maybe? not too sure.
any help would be appreciated.
Thanks!
Old 09-23-2003, 03:17 PM   #4010
Steevo's Avatar
Default TRANSLATOR
Here is the translator I use for Japanese to English and a few other languages. It works in most applications
CLICK HERE FOR TRANSLATOR
Steevo
Steevo is offline   Reply With Quote
Old 09-23-2003, 03:45 PM   #4011
racer's Avatar
sorry Steevo,
it is saved as a jpeg format. and i failed to mention it was a scan from a magazine. i'll send it to anyone who is kinda enough to help translate and post their finding in this forum
Old 09-23-2003, 10:16 PM   #4012
I picked up a XXXS tonight, but propably be picking up a MY02R before long
Old 09-24-2003, 12:06 AM   #4013
McLaren's Avatar
I bought the LRP Quantum Competition 2 from Japan and cannot find the setup instructions in English.
Can I get them online from somewhere?
McLaren is offline   Reply With Quote
Old 09-24-2003, 12:10 AM   #4014
try the lrp homepage.
how much did it cost anyway?
trf racer is offline   Reply With Quote
Old 09-24-2003, 12:19 AM   #4015
McLaren's Avatar
The LRP Quantum C2 costs 31300 yen including EMS delivery! I think it will amount to something less than USD300.
I cannot find the setup instructions on the LRP website ... anywhere else?
Old 09-24-2003, 12:22 AM   #4016
when you say set up do you mean for the transmitter or for punch and drag brake.
which ever i could tell you.
Old 09-24-2003, 12:23 AM   #4017
McLaren's Avatar
Can you help with both?
Old 09-24-2003, 12:27 AM   #4018
ok this is to set up the speedo to the transmiter.
turn transmiter on then speedo
press the set up button [keep it in]
then the led will flash then live the transmiter in neutral and push the set up button.
then the motor should bleep pull the throttle to full power on the transmiter and while doing so push the setup button again.
then the bleeping should stop then pull the transmitter to full brakes and press setup button.
then it should be set up to transmitter.
Old 09-24-2003, 12:32 AM   #4019
McLaren's Avatar
Ok thanks ... if you manage to find the setup instructions in English for the LRP Quantum Competition 2 ... please let me know, cause I need to check the available programs.
Old 09-24-2003, 12:38 AM   #4020
ok to adjust the punch intial brake etc is a bit more complicated.
hold the mode button down then you should get a flashing green light.this is the punch control
you can check the set value[1-5] by counting the red led flashes [1 flash equals value 1,2 flashes equals value 2 etc.]
you adjust values by pressing setup
press mode button again and this will bethe intial brake again we havesetting 1-5.
press mode again and we have automatic brakes set up [drag brakes]
with 1-5 settings.
on the punch control 1=smooth 5=mega punch
on the intial brake 1=linear 5=progresive
on the drag brakes 0=off 5=strong
default setting is
punch=2
intial brake =2
drag brake=0
hope this helps.
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
