Old 09-12-2003, 01:17 PM   #3811
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I thought that for the TCS rules you can not modify any parts on the car, unless you use Tamiya hop ups and use them only for what they are made for. Countersinking the upper deck isn't a hopup, it's additional work on the car, so I wouldn't think it would be legal for TCS rules...
Old 09-12-2003, 01:20 PM   #3812
iam not sure about tcs legal but what advantages does countersunking the top deck have?
also anyone tried double wires?i tried it and had about twice the punch!
trf racer is offline   Reply With Quote
Old 09-12-2003, 01:25 PM   #3813
Countersinking the top deck prevents tweak on impacts.
What do you mean by double wires?
Old 09-12-2003, 01:28 PM   #3814
aaaaahhhhhh.tweaking woudnt be effected on low grip tracks?
i use 2 wires on the positive of the batts and negative and the same on the motor.
it lowers resistance and thus gives more punch.the only thing is trying to cover it up at our tracks so no else gets the idea!
Old 09-12-2003, 02:18 PM   #3815
You can get tweak on any track, it's caused by collissions, and bumping corner dots.
I think I'll stick away from the 2 wire idea, you'd have to use so much solder to get them on that it would cause even more resistance...
Old 09-13-2003, 01:39 AM   #3816
alan1467's Avatar
Re: Re: Square Middle Brace
Originally posted by Steevo
My Square Middle post is 100% Alloy Too
Steevo
My Square centre post is nylon?????? but the 2 outers are alloy
Tamiya TRF - Tekin
F104W Pro - CRC Gen X10
alan1467 is offline   Reply With Quote
Old 09-13-2003, 01:52 AM   #3817
P2
P2's Avatar
Trader Rating: 15 (100%+)
Default Motor air dam
Anyone else doing this...see pic..besides puting a fan onboard? Lot's O people are using them in Japan.
EJ,
I only got you one set of Bs with rims . The Square red gear case, bearings, and diff outdrives are in are in I will mail them out on Tues. I will also send you an Air Dam so you can try it out.
Your best buddy
P2
P2 is offline   Reply With Quote
Old 09-13-2003, 05:17 AM   #3818
TRF-Powered's Avatar
More wire, more resistance... It does not lower resistance at all.
what you did was creating a parallel circuit, I don't see how it is giving you more punch, but I do see that it is a "safer" connection, if one of your wire comes off + or - end, it will still be functional.
TRF-Powered is offline   Reply With Quote
Old 09-13-2003, 08:27 AM   #3819
Default Re: Motor air dam
EJ,
Your best buddy
P2
I used to run the air dams, unfortunately they make the car a little hard to work on, and are fragile. I didn't notice any change in temperature either.
Old 09-13-2003, 11:18 AM   #3820
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Sorry -TRF- P
More wire is less resistance. By your thinking a single strand of wire would be preferable
As long as the wires are connected in the normal fashion the circuit is the same, if he were to run a wire from the esc to each cell then that would be different
A longer piece of wire is more resistance, but a larger diameter wire of same length = more area for the little electrons to move freely from point A to point B
When you try to imagine the flow of electricity think of how water flows, very similar effect....
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 09-13-2003, 11:24 AM   #3821
rocketron's Avatar
Trader Rating: 16 (100%+)
Originally posted by RedBullFiXX
Sorry -TRF- P
wOw - too deep for so early
rocketron is offline   Reply With Quote
Old 09-13-2003, 04:41 PM   #3822
gcooper's Avatar
Wink
Countersinking the top deck is legal for GT1 just not the rest of the classes. Which is direct from Fred from Tamiya.
Coop
gcooper is offline   Reply With Quote
Old 09-13-2003, 05:24 PM   #3823
Trader Rating: 19 (100%+)
that is odd. fred said that counter sinking the top deck was NOT tcs legal. the guys at the tech table confirmed that and said it would have to reverted back to the original for the nationals.
MDawson is offline   Reply With Quote
Old 09-13-2003, 05:49 PM   #3824
lol, I thought I was the only person that thought so
Old 09-13-2003, 10:21 PM   #3825
picco007's Avatar
Trader Rating: 85 (100%+)
Send a message via AIM to picco007 Send a message via Yahoo to picco007
Default setups???
Can anyone tell me where I can get some asphalt setups for the evoIII se? At this time we race on an aphalt track with temps in the 130's to 150's. I would appreciate any info...
Thanks,
Ronnie
picco007 is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
