Old 09-10-2003, 02:20 PM   #3751
audiaudi's Avatar
Send a message via ICQ to audiaudi Send a message via MSN to audiaudi
but I have the same problem with the KB saver....
https://www.facebook.com/aldusdesign
Trying very hard to jump back into RC with CRC Xti-wc.
audiaudi is offline   Reply With Quote
Old 09-10-2003, 03:15 PM   #3752
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Got a pic of my Evo 3 yesterday before I ran it, let me know what you guys think
Old 09-10-2003, 03:18 PM   #3753
Aurra Sing's Avatar
post # 300
I haven't had any problems with the white servo saver.
Just make sure that when you put the rings on, don't bend them outward. Let them slide on.
Randman - NICE body!
Aurra Sing is offline   Reply With Quote
Old 09-10-2003, 03:27 PM   #3754
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
man, that paint is awesome!! who, and how much! i need one like that badly...
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 09-10-2003, 03:32 PM   #3755
rocketron's Avatar
Trader Rating: 16 (100%+)
Thanks Charlie
Ron - I've got the gear on, but it slid over too far and the mesh was too tight. I dont have any good phillips drivers, so all 4 screws on the 1 way are stripped, looks like I'll have to dremel them off and get another carbon plate.
OUCH
your the guy with all the tools too
can you maybe just dremel a slot into the screws and possibly get them out using a blade driver?
man what luck!
rocketron is offline   Reply With Quote
Old 09-10-2003, 08:18 PM   #3756
jfc_tech's Avatar
Send a message via Yahoo to jfc_tech
Exclamation TB02??
check this out guys...TB02???
58310 1/10 Scale R/C 4WD Mercedes-Benz CLK-DTM
For this new addition to the R/C Car Series, Tamiya introduces the TB-02. Based on TB Evolution III, the TB-02 chassis can be fitted with aluminum and carbon parts designed for the TB Evolution III. For the first model using this chassis, Tamiya has chosen the popular Mercedes-Benz CLK-DTM Team Vodafone AMG-Mercedes.
To mark the release of the TB-02 chassis, Tamiya is also releasing a series of optional parts.
53677 TB-02 Stabilizer Set (F & R)
In order to improve stability on high grip roads, Tamiya offers a stabilizer set for the TB-02 chassis.
53678 TB-02 Aluminum Racing Steering Set
To obtain a more secure attachment and more direct response on cornering, Tamiya offers an aluminum steering set for the TB-02. Combined with a carbon plate, you obtain a TB-EVO III style chassis.
53679 TB-02 SSG Carbon Center Plate This option part carbon center plate attaches to the bottom of the main frame of the TB-02 chassis, providing more solid pitching, more accurate suspension settings, and reduced power loss.
53680 TB-02 Aluminum Motor Mount
This blue anodized Aluminum Motor Mount allows drivers to lighten their chassis for higher performance. Like the regular part included with the TB-02 chassis, this aluminum mount features 4 different motor positions allowing 12 gear ratios when combined with various pinions.
53681 Titanium Wheel Axle for Assembly Universal Shaft
This Titanium Wheel Axle has been designed for the Assembly Universal Shaft to be mounted on the TB Evolution III and TA04 chassis and can be mounted at the front and at the rear. Its lightweight (only 2g) provides reduced power loss and a higher top speed.
53684 TB Evolution III Aluminum Heat Sink Motor Mount
Presenting a gray anodized version of the TB Evolution III motor mount included in the 49335 TB Evolution III Blue Conversion Set (September Coming Soon). Shape of motor mount means improved heat dissipation, and longer connector holes makes removal of motor easy.
its from here Team Orion Web site
If you are in front of me, That's because I let you!
jfc_tech is offline   Reply With Quote
Old 09-10-2003, 09:23 PM   #3757
A low-cost version of the Evo3?
Awesomatix A700L (building) | VBC Wildfire D07 (building) |416WE/X Smokem | Hobbywing 120A v2.1 | Sanwa M11x
itchynads is offline   Reply With Quote
Old 09-10-2003, 09:44 PM   #3758
Big Dog Racing... Jason Lutz He's really good, and has good pricing as well. Cost depends on the job.
Old 09-10-2003, 09:46 PM   #3759
Originally posted by rocketron
OUCH
man what luck!
I got all the tools except phillips head crap
Got it all back together, now I'm just shimming the gears until I get them perfect. It's already pretty free, the tooth size is a hair smaller than the Tamiya gear, but I dont think there will be any meshing problems once I finish breaking it in.
Old 09-11-2003, 07:07 AM   #3760
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
The tooth size on what? A different ring gear?
BTW- the car looks great with that body!!
Here's mine- this was just a quick shot. Keep in mind this body has been run for like 10 practice packs, 5 hours of glitching (no I'm not exaggerating) to fix the glitches, and 2 full races...
BigDogRacing is offline   Reply With Quote
Old 09-11-2003, 09:56 AM   #3761
Who's the pimp playa NOW?!?!?!?!
LMAO!!!
Old 09-11-2003, 10:05 AM   #3762
Trader Rating: 24 (100%+)
Ain't red purty !!!! Where'd you get all the goodies from??
Evoracer is offline   Reply With Quote
Old 09-11-2003, 11:26 AM   #3763
wow, the Square parts do look good Jason If these new gears work out next Tuesday, then I'll post pics and a how-to, although I think Rocketron already has. I ran prostock last tuesday, but I'll be throwing in a brushless motor this coming week, see how the car holds up with some actual power thrown at it.
Old 09-11-2003, 12:27 PM   #3764
Got a few more pics to share with you guys.
Old 09-11-2003, 12:27 PM   #3765
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
