Tamiya TB-Evolution III >
Old 01-14-2003, 10:32 AM
  #361
izzyracer's Avatar
Trader Rating: 27 (100%+)
Default Hmmm!
Can you pull out the spur gear from that state? Don't you still need to take out the rear diff box?
izzyracer is offline
Old 01-14-2003, 10:35 AM
  #362
Trader Rating: 49 (100%+)
rc-zombies do you know how to get the link to read in engish (or anyone) thanks again
weaponx is offline
Old 01-14-2003, 10:43 AM
  #363
rc-zombies's Avatar
Use babelfish translator:
http://babelfish.altavista.com/
rc-zombies is offline
Old 01-14-2003, 10:56 AM
  #364
thanks again rc-zombies
weaponx is offline
Old 01-14-2003, 11:05 AM
  #365
rayhuang's Avatar
izzy-good point!!! With the rollpin installed-maybe you cannot remove the spur because you cannot move the drive-shaft forward....... I guess I'll need to download babble fish (Great name-from "hitch hikers guide to the universe") and see what the caption says!!!
Ray
rayhuang is offline
Old 01-14-2003, 11:12 AM
  #366
rtypec's Avatar
Default What the caption says...
Translated from babelfish, it says "Forty-Two"
rtypec is offline
Old 01-14-2003, 11:36 AM
  #367
rayhuang's Avatar
Well-that helps!!!!
rayhuang is offline
Old 01-14-2003, 12:42 PM
  #368
You will still have to pull the main shaft out the back by pulling the diff cover off so not much saving of time even with the conversion. If you pull the 4 screws surrounding the spur you can still do the same. And take me out for a beer with the $220 you save.
Rod did you find the diff won't work in the 201 yet the EVO diff is wider then the 201
D
Difuser is offline
Old 01-14-2003, 01:26 PM
  #369
rayhuang's Avatar
Lightbulb Castor
Hello Tamiya pros!!!,
I am wondering if anyone knows for fact that the standard C-hubs on this car, part tree number 50985 (also 000415) are 4-degrees?
I know that the Racing Hub Carrier, part number 53458 is 6-degrees.
I use castor a lot to tune. Is there a 2-degree set as well?
Ray
rayhuang is offline
Old 01-14-2003, 02:12 PM
  #370
izzyracer's Avatar
I thought they were exactly the same racing hub carrier as the 414M2 6°
Old 01-14-2003, 02:17 PM
  #371
SpeedTech's Avatar
Hi Guys,
Ti-screw kit is a good idea. I'll see if I have a supplier that can give me a good price break on bulk Ti-screws and I'll figure out some screw packs for you guys. It probably won't be Tamiya screws though
Also, Tamiya is releasing the graphite chassis and shock tower for the 414M2 in the new SSG Graphite, I'm crossing my finger and hoping that they will do the same for the EVOIII
Steve Wang
Speed Tech R/C
www.speedtechrc.com
SpeedTech is offline
Old 01-14-2003, 02:18 PM
  #372
izzyracer's Avatar
It does say 4 degree caster on front
Total length: 366mm, Total width: 189mm, Clearance: 5mm, Weight Fully-Equipped: 1,440g (Measurement includes TP-S3003 servo, CPR Unit and RC2400SP Battery with RS-540 motor) Wheelbase: 257mm Tread F/R: 163mm Chassis Material: Carbon Chassis Shape: Double-Deck Frame Steering Tie Rod: 3 part Suspension: Front and Rear Double Wishbone Caster Angle-F/R: 4deg/0deg Camber Angle-F/R: adjustable Toe Angle-F/R: adjustable/The kit comes with 4 different suspension mounts for the express purpose of adjusting rear toe angle Skid Angle F/R: 1.6deg/0deg Damper: F/R TRF Super Low Friction Dampers Drive train: Shaft Driven Full Time 4WD Gear Ratio: 7.34:1, 6.88:1 (Standard in kit) Diff. gear system: F/R One-Way/Ball-Diff Speed Controller: Electronic Speed Controller Tire Width: F/R both 24mm Tire Diameter: F/R both 64mm Tread Pattern: F/R Sleeks.Caster Angle-F/R: 4deg/0deg
Old 01-14-2003, 02:22 PM
  #373
izzyracer's Avatar
Speedtech...what is special about SSG Graphite?
Old 01-14-2003, 04:32 PM
  #374
Aluma's Avatar
I doubt most of us will care if they're tamiya or not...there will be some guys that race TCS. but i think most of us will be huntin' xray, associated, and losi
Aluma is offline
Old 01-14-2003, 05:54 PM
  #375
TRF414M's Avatar
Silver Graphite Plate is lighter and slighty more flexible.
TRF414M is offline
