Tamiya TB-Evolution III
#3691
I race at the normal spots around here. RC TECH on Tuesdays, RCCAR, Gilroy, Speedworld...
Well, EJ said he'll help me if I get the car, but he said he hasn't fully cured the one-way problem either.
#3693
BigDogRacing
Originally posted by BigDogRacing
BigDogRacing
BigDogRacing
Are you the Jason that put the smack down in the 19t TC class last month in Atlanta with the Evo III S at TFB?
Kenny
#3695
Man, I want a evo3 now. Looks like i'll have to pick one up
#3696
[QUOTE]Originally posted by rcethilon
[B]A question for P2 and one for V12.
P2, how sure is that 'Tamiya guy' that the rear diff gear material is of a harder carbon material? I am not trying to challege you, trust me. I'm just overtly curious. I have made the reaming of the rear diff gear so that now it fits the front oneway. I have yet to try it on the track. My impression on reaming the rear diff gear is that if the material is really harder than the front oneway gear, the difference is pretty subtle. The material of the rear diff gear and the front oneway gear look (lustre) pretty similar and they both warp to the same extent if you bend them. I will be very amazed if by doing exactly what you described, I won't strip another front oneway gear at the track.
rcethilon,
From what I can see and feel the two gears are definetly made of different material. Just trust me it works!! So far I have not broke any teeth off a modified oneway gear. I did forget to lube one up last weekend and when I opened up the gear case there was plastic/carbon dust everywhere. I used this gear for 3 races and it still worked. It looked pretty bad and still rolled pretty free. If I would have known it was that bad I would have replaced it ASAP. I could not feel any binding (without motor attached) so I continued to use it. Thank god it lasted the whole race day!
All, I'm not saying this mod will fix the oneway problem 100% but it has worked for me and has saved me lots-O-$$ and headaches. I used to go through 1-2 gears a race and would worry about it after one crash. Now I'm pretty confident that the modified gear will finish the race!
Knock on wood,
P2
rcethilon,
Knock on wood,
P2
#3697
I think you should too! You know EJ will hook you up with the setups in your area. I will still have a connection here in Japan so getting parts won't be a problem. It's cheaper too!!
Paul P AKA P2
#3699
[QUOTE]Originally posted by P2
[B]
hi there, i don't know if this is new or oldies tip...but i just found out that the Yokomo SD front one-way set is direct fit to the evo3 one-way problem
im new with evo3 ... ran only 10 packs but already changed 2 gears on the one-way. so when i build friend's SD(i charged them, obviously)...i had the change to check whether the SD fit the evo3...it is AND IT WORKS PERFECTLY....IM A HAPPY MAN NOW.
[B]
rcethilon,
Knock on wood,
P2
rcethilon,
Knock on wood,
P2
#3700
Are you talking about the one-way gear? And it meshes perfectly? Do you know if the # of teeth are the same?
#3701
the ring gear do look very similar
#3704
Originally posted by Randman
Do the ring gears have the same # of teeth on them?
