Tamiya TB-Evolution III
#3661
Regional Moderator
Originally posted by BigDogRacing
Are you thinking about doing some racing out of town Mike?
#3662
-I think for stock this setup is so hooked it probably needs the roll centers raised to loosen it up.
#3663
Racenut, I'll refrain from smartazz comments for now, at least until I hear your suggestions to loosen the car up starting with the best to the worst.
I have one thought for you before you respond- When racing on carpet with foam tires, and you have way too much traction on one end of the car or the other, or even overall, what do most "national level" to pro level drivers do first to loosen a car up after the obvious things like swaybars and springing up don't work?
#3664
didnt mean to come off like a smart azz.
But since you took offense,obviously I will will refrain from commenting anymore.Looking at your setup,I thought a couple of changes would be in order before you raise the rear roll center.
I am just going by what a reputable Tamiya Factory driver here in our area said of the Evo3.
#3665
Regarding Big Dogs' avitar........Jeez Jason..why is your hose so limp!!!!??? LOL
On a not so important note....what is this one way secret Randman mentioned and is it the one you mentioned earlier that didn't work the way you wanted it to??
Does any body out there use or prefer 48 pitch spur with the Evo3?? Any downside??? I had a problem with proper mesh during my last race outing and thought I might try 48p next time???
#3666
Steevo
#3668
R/C Tech Elite Member
#3669
it may not really the preblem of the spur.. I m using tamiya spur and pinion..
#3670
Racenut- I didn't really take offense, I was just busting your ballz- . Actually, I come from drag racing and 1:1 car racing so even though I don't drive as well as I wish I could, I know a little about suspension tuning. To be honest I was ready to eat crow if you did produce some good ideas for freeing the car up without changing roll centers. With that said, please feel free to offer any suggestions if you have them. Sorry I barked too loud...
Roll centers- one of the reasons for trying to free a car up with roll centers instead of excessive over springing is because lowering the roll center won't make the car break loose violently when it does break loose. Not to mention that the track had a few sealed cracks and the cars need some amount of suspension to navigate smoothly through those rough sections. I could have gone down on springs and let the car roll over a little more, which means decreasing the contact patch of the tire by letting it get on the outer edge more, but the tires had a perfect wear pattern in the center and weren't wearing at all, which means I wasn't scrubbing or sliding the tires- front or rear!! sweeeeeeet
Dino- yea when you put out as many "fires" as I do, your hose stays pretty limp...
The oneway "secret"...lol... first of all, you need to shim the oneway with approximately .3mm shims on the driver's side of the oneway witht he Tamiya 10mm shimset. Now the fix- I used some thin metal to make a ring or sleeve that fits over the pinion bearing to make it a tension fit into the transmission case bearing seat. That stopped the "floating" action of the pinion bearing. My intention was to stop the pinion from deflecting on a heavy load away from the ring gear. It didn't stop the stripping... totally. I ended up shimming it back to the .3mm.
Spur gears- Fernando told me that the spur gears that comes with the Surikarn car aren't those stupid metric pitch gears anymore, so I tried the 96 tooth with my standard 64 pitch Ti racing pinions, and he must have been right! They are perectly smooth and quiet!! I couldn't believe it. And they hardly wear at all. They are actually some of the best spur gears I've ever run.
#3671
#3672
Its the bearing that sits behind the front bevel gear on the end of the prop shaft... I think...
#3673
Randy a shaftdrive car's transmissions contain a ring and pinion differential. The pinion gear is driven by the shaft and the ring gear drives the outdrives. I know the use of the term pinion gear is confusing you with the motor pinion gear, but that's what it's called. Sorry you were confused.
#3675
A question for P2 and one for V12.
P2, how sure is that 'Tamiya guy' that the rear diff gear material is of a harder carbon material? I am not trying to challege you, trust me. I'm just overtly curious. I have made the reaming of the rear diff gear so that now it fits the front oneway. I have yet to try it on the track. My impression on reaming the rear diff gear is that if the material is really harder than the front oneway gear, the difference is pretty subtle. The material of the rear diff gear and the front oneway gear look (lustre) pretty similar and they both warp to the same extent if you bend them. I will be very amazed if by doing exactly what you described, I won't strip another front oneway gear at the track.
V12, if the front oneway gear is now on the side of the motor ( opposite the side of the battery pack) as you've described, do you have to reverse the polarity connection of the motor?
