Old 09-05-2003, 11:39 PM   #3631
V12
V12's Avatar
Originally posted by hierog
anybody having any problems with the ballcups on the surikarn? i think they absolutely stink! they come out at the slightest bump. and of course because they are so big, the only think i can do is get tamiya replacements or change out all the balls/ballcups! aarrrggghhh!
I never had a ballcup coming off since now with my EVO3. But there are some new low friction ballcups made of a harder plastic. I think itīs #53601.
V12 is offline   Reply With Quote
Old 09-06-2003, 12:10 AM   #3632
hawker's Avatar
Default Diff Question
Hey guys,
I'm having to much trouble with the one way so i'm building up a diff, I searched back through the threads and found the list I need for it, but according to the suppliers at work, the thrust washer you need is discontinued (the one for the 04). Does anyone know how to obtain it or has it changed part number?
If they have changed part number, can someone give me a news list of part numbers to use? thanx.
matt
hawker is offline   Reply With Quote
Old 09-06-2003, 12:14 AM   #3633
PizzaDude's Avatar
Why won't they just release a complete diff assy???
PizzaDude is offline   Reply With Quote
Old 09-06-2003, 12:18 AM   #3634
hawker's Avatar
Default bloody good question
very good question, wish i knew the answer, apprantly they are, but hey, who knows, i'll ask our local tamiya guru when I see him next (owns every damn tamiya car ever made, usually 2 of each lol)
but in the mean time, the only way I can think of doing it is buy the 04 dif set and taking parts from that :S
Old 09-06-2003, 12:40 AM   #3635
TRF-Powered's Avatar
Default Re: Re: DO I Need a Spare One Way Diff Unit??
Originally posted by Randman
I havent had any problems with 1 ways on any of my cars in the past, but I have heard of people having problems with them, so it couldn't hurt... You just gotta judge if the price is worth it to keep a spare.
Did I see a SE TBevoIII in Randman's info box???!!! wow.... did you trade your pink Cuda to that EvoIII??
wow..... did Dave (JDM) give you some smack Talk for doing that??? since you even send that Pink one to Japan to him.....
TRF-Powered is offline   Reply With Quote
Old 09-06-2003, 07:36 AM   #3636
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Default Re: Re: Re: DO I Need a Spare One Way Diff Unit??
Yeah, my buddy Dan had 2 Surikarn's new in box on his desk that he hadn't got around to building, I wanted to try one, so we did a trade Of coarse Dave smack talked the Evo 3, he is Mr. R2
Old 09-06-2003, 04:08 PM   #3637
P2
P2's Avatar
Trader Rating: 15 (100%+)
Default Re: Diff Question
Originally posted by hawker
Hey guys,
matt
Matt, I had to special order the thrust bearings here in Japan. Kawada has a diff kit that will work. It comes with the bolt, spring, thrust bearing, and nut that fits the EVOIII diff. You have to also get the bearings. Hope you can find the parts you need.
P2
P2 is offline   Reply With Quote
Old 09-06-2003, 04:16 PM   #3638
hawker's Avatar
oh well, I can't wait that long to get it from japan (i'm in australia) i'll buy the 04 diff and use the parts out of that, i have an 04 anyway so i'll uses the other bits as spares, you know the piece of plastic that slides down into the diff, where the locknut sits, is that the same for the 04 as it is for the evo?
Old 09-06-2003, 06:28 PM   #3639
Aurra Sing's Avatar
Originally posted by Aurra Sing
This is my stock/mod setup for rubber tire/asphault track, works pretty good.
Front:
Springs: yellow (harder if more traction)
Oil: 40wt
Stabilizer: yellow
Droop: 5mm
Wheel spacer: 1mm
Rear:
Oil: 40wt
Stabilizer: yellow
Droop: 4.5mm
Wheel spacer: 0.5mm
Toe-in block: A-C (depends on traction)
(steering links mounted on front hole of upright)
Car is kinda twitchy... I want to play around with shock oils and o-rings in the shocks next.
I changed to 60/50 (f/r) oil weight and the car was perfect now.
Aurra Sing is offline   Reply With Quote
Old 09-06-2003, 07:11 PM   #3640
Trader Rating: 28 (100%+)
Aurra's setup is dialed......Lets say I thought my car was pretty good in qualifying.When I put his setup on my car for the main,ouch.I went 2 laps faster then my best qualifier.Thanks Aurra for the help before then main.Sorry I beat you.
racenut123 is offline   Reply With Quote
Old 09-06-2003, 07:12 PM   #3641
Does anyone have a good setup for the Surikarn at SoCal, or Tamiya?
Old 09-06-2003, 07:15 PM   #3642
Found one more part on Square's website, wondering what it is.
Old 09-06-2003, 07:33 PM   #3643
Steevo's Avatar
Looks like a diff adjusting tool similar to what I have. It fits in the slots in the outdrives to hold them steady while you check the gear slip.
I could be wrong though....
Steevo is offline   Reply With Quote
Old 09-06-2003, 07:41 PM   #3644
aah, yes, I guess it could be for that. It was Square's website listed as Evo 3 stuff, I would have thought that it would have been a part for the car itself. That tool is somewhat universal...
Old 09-06-2003, 07:46 PM   #3645
Steevo's Avatar
Randman, Can you post the link to the Square Web Site Please..
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
