Old 09-05-2003, 09:52 AM   #3616
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by rtypec
Hey BDR...So what kind of test procedure did you come up with? Are you going to purposely crash your car? haha. Btw, I forwarded your idea to the interested parties and so far, I havne't heard back from them.
I also, just built my EvoS and boy does the drivetrain feel like crap hehe . I'm gonna do some installation runs tomorrow to see how things free up
For transmission breakin, I use the slave motor out of my lathe hooked up to like 2 volts, let it run for a couple hours and it should free things up for ya Rod
Old 09-05-2003, 09:54 AM   #3617
rtypec's Avatar
I could do that...but I'm going to break it in the fun way! hehe.
rtypec is offline   Reply With Quote
Old 09-05-2003, 10:53 AM   #3618
What's the internal drive ratio on the Evo 3?
Old 09-05-2003, 10:57 AM   #3619
NMRCDude's Avatar
Send a message via AIM to NMRCDude
NMRCDude is offline   Reply With Quote
Old 09-05-2003, 10:58 AM   #3620
Cool, thank you
Old 09-05-2003, 11:13 AM   #3621
One more question. I just bought a tuned spring set for the car, but there were a couple different sets at the hobby shop, and naturally the guy working there didn't know what was what. Can you guys just confirm I got the right stuff please.
Old 09-05-2003, 11:18 AM   #3622
eeyan's Avatar
Send a message via AIM to eeyan Send a message via Yahoo to eeyan
Randman,
These are the correct set for the Surikarn... Tamiya also released two newer much HARDER springs but you have to buy them separately... I believe they're gray and maroon colored...
Tamiya also introduced shorter springs, but I doubt if those will fit the standard height of the Evo shocks... they were meant for the shorter stance of the TA04-TRF towers.
-Ian A.
TAOB Racing Team (1999 - 2011)
eeyan is offline   Reply With Quote
Old 09-05-2003, 11:20 AM   #3623
Alright, I did good them I dont think that I will need any stiffer springs than these, from what I understand Red is the spring to run at Tamiya, and Yellow at SoCal. So I should be set
Old 09-05-2003, 11:28 AM   #3624
PizzaDude's Avatar
Default WEIGHT
Can anyone tell me wether the delrin (white) outdrives are lighter then the stock black, plastic ones?
Also between the original shocktowers and the Surikarns, what do they weigh?
Thanks,
Pizza
PizzaDude is offline   Reply With Quote
Old 09-05-2003, 11:38 AM   #3625
The weight should be just about the same between delrin and plastic, but delrin is a stronger material, less prone to wear and warping.
Old 09-05-2003, 06:30 PM   #3626
Steevo's Avatar
Default DO I Need a Spare One Way Diff Unit??
Howdy all.
I was just putting together my order of Back Up Spares for My Evo III SL and I was wondering if you think a spare Front one-way diff unit should be on the list...
Has anyone blown a One-Way bearing or had a need to replace it for any reason??
Please let me know as I don't want to get one if they are not something that I should have a problem with.
Steevo
Steevo is offline   Reply With Quote
Old 09-05-2003, 06:35 PM   #3627
Registered User
You can also use Associated TC3 springs. They fit better on TRF Damper than Tamiya springs.
Aku-Man is offline   Reply With Quote
Old 09-05-2003, 06:38 PM   #3628
Default Re: DO I Need a Spare One Way Diff Unit??
Originally posted by Steevo
Howdy all.
Steevo
I havent had any problems with 1 ways on any of my cars in the past, but I have heard of people having problems with them, so it couldn't hurt... You just gotta judge if the price is worth it to keep a spare.
Old 09-05-2003, 10:00 PM   #3629
hierog's Avatar
anybody having any problems with the ballcups on the surikarn? i think they absolutely stink! they come out at the slightest bump. and of course because they are so big, the only think i can do is get tamiya replacements or change out all the balls/ballcups! aarrrggghhh!
hierog is offline   Reply With Quote
Old 09-05-2003, 11:33 PM   #3630
V12
V12's Avatar
Howdy all.
Steevo
If youre using a good lube for the oneway bearings they should last for long. Best lube I know of is the Serpent oneway lube. Thats also the one Im using for all of my oneways.
But be careful with cleaning. Some people tell you using brake cleaner for blowing out the grease. The problem is some brake cleaners and maybe some motorspray also are containing some stuff that will damage the plastic cage of the onewaybearings.
Im only wiping off the grease from the outdrives and then two drops of the Serpent lube on each of them again. This should last for one weekend.
V12 is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
