Tamiya TB-Evolution III
#346
i plan on buying the evo 3 and i noticed it comes with phillips head screws. could someone please tell me the sizes of the screws used thru out the kit so i can replace them right away with hex screws. ( if i am correct about the kit coming with phillips screws) any help is appreciated. also i will have a 414 m2 for sale if anyones interested pm me. Thanks
#348
For the screw sizes, you can just take a look at the back of the instruction manual to get all the different sizes.
It should be 3 x 8 and 3 x 10, 3 x 12, 3 x 15 and 3 x 18.
#349
Button Head Machine Screw
3x15(4), 3x12(4), 3x10(1), 3x8(9)
Flat Head Machine Screw
3x8(16)
Button Head Tapping Screw
3x18(2), 3x10(18), 3x8(17)
Flat Head Tapping Screw
3x1(17), 3x8(5)
Hope this helps.
#354
ShoePooed Electronics
Well Izzy, double sided tape would be good enough, but the way you guys keep nailing me, I'd have to shoegoo everything in just to keep everything underneath the body! J/K I typically shoegoo the speedo in because of all the man-handling the wires get (from soldering motor to pulling corally plugs) and considering how short they will be in the Tevo3, I'd rather be assured that the speedo stays in place. BTW, with everything laid out flat on the chassis, the car looks TIGHT! Now onto the real test...will the glitch-gremlins take control of this car or not hehe
#355
SHOE-GOO TIP
If you shoe-goo your electronics..
place some electrical tape under your ESC or Receiver before you shoe goo... This will make the removel of your equipment later on alot easier and keep your electronics looking new. especially on LRP products...
#357
does anybody knowwhere you can get the kai conversion kit for the evolution 3
see:
http://www2u.biglobe.ne.jp/~kmodels/index1.htm
Kai kit for the Evo-III cost around $220.00++++
in limited quantaties..once sold out...no more will be produced.
