Old 09-02-2003, 04:11 PM   #3541
Korey Harbke's Avatar
I think it comes with 4 degree blocks. I'd likw to know if they have anything with LESS caster, somewhere along the lines of 2 degree.
-Sushi Boy
Seido Speed Works - Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 09-02-2003, 05:47 PM   #3542
Wilfred's Avatar
Question: Anybody tried to lock the front diff? will it stop the strippin? does it work like one way?
Wilfred is offline   Reply With Quote
Old 09-02-2003, 06:37 PM   #3543
defMondo's Avatar
Yes it does help with the gears because your using a diff gear not the one diff gear.
And it's sort of like a one way, coming out of a corner it's like a one way, but going into a corner you have breaks.
The main problem is understeer into the corner, but you can adjust your driving to work around it.
Personally I think it's good for tight tracks with lots of sharp turns (180's) if you have a smooth flowing driving line then I would stick to the oneway.
my 2c
Tony
defMondo is offline   Reply With Quote
Old 09-02-2003, 06:40 PM   #3544
rcfiend's Avatar
Trader Rating: 29 (100%+)
Thanks Sushi Boy. Does anyone else know if optional caster blocks are available for the EVO3 or EVO3S.
rcfiend is offline   Reply With Quote
Old 09-03-2003, 09:10 AM   #3545
Trader Rating: 28 (100%+)
Default Set up
Here is my evo3s setup for Medium sized,asphault medium bite parking lot track.
Front
Associated Blue spring
40 wt oil stock piston
Kit mounting position for shock
.7 shim in under the front arm block
Middle camber mounting position on upper mount w/5mm shims under camber link.
Kit wheelbase setting
Yellow sway bar
Front oneway
Cs27 premount
Rear.
Associated Silver spring.
40 wt oil stoc piston
Middle camber link mounting as in front.
No sway bar.
Kit shock mounting position.
B block in the rear.
cs27 premount.
Losi alpha body
car was very stable,not overly planted,rotated well.Was just slightly on the edge so it was very nimble thus it was fast everywhere.I love this car.
racenut123 is offline   Reply With Quote
Old 09-03-2003, 05:47 PM   #3546
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Sup guys, I'm gonna be picking up a Surikarn this week, so time to start following the Evo thread
Old 09-03-2003, 06:18 PM   #3547
gtypecanare's Avatar
So does that mean your going to trek up to Tamiya on the weekends?
gtypecanare is offline   Reply With Quote
Old 09-03-2003, 06:25 PM   #3548
The Tamiya track is one of the reasons for getting the Surikarn
Old 09-03-2003, 07:44 PM   #3549
Trader Rating: 24 (100%+)
Its Surikarn time !!!! mine's on the way also. Does anybody out there know of somebody or some company who might be keeping a "library" of Evo setups ??? Sure would be nice to have a quick access source for all the great (and some not so great LOL) setups that team drivers and us mere mortals have posted or are willing to share.
Evoracer is offline   Reply With Quote
Old 09-03-2003, 11:44 PM   #3550
Well, I'm not a team driver, but I found a very nice setup for carpet racing if your interrested.
It gives you a lot of grip and great corner speed. It even takes care of the negative side of racing a oneway ----> It makes it posible to use the brake, so you should be able to win the braking duals when entering a corner, without ending up rear first.
just pm me, and I'll make a sheet for you.
Take care
SSL
SpineX-SSL is offline   Reply With Quote
Old 09-04-2003, 06:06 AM   #3551
hierog's Avatar
I've got a Surikarn also and have been unsuccessful in finding a setup sheet for asphalt. Anybody have a good sheet to use for this car? I'll be racing at speedworld in Roseville, CA (fyi) as soon as I find a good setup and get some good practice sessions in!!
hierog is offline   Reply With Quote
Old 09-04-2003, 08:11 AM   #3552
hierog's Avatar
question for you all..... this is a when i run my EVO and let off of the throttle, my car immediately turns to the left. could this be a weight distribution thing, or . . . .? i have set it up on a Hudy board and everything looks great. runs straight at full throttle, but as soon as i let off, immediate spin out!! any suggestions?
thanks
Old 09-04-2003, 08:24 AM   #3553
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
SpineX- I would be interested in seeing your setup for carpet. Are you talking about rubber or foam tires on carpet? Because I would like to note that if you are running foams on carpet, you run very little or no droop which will allow you to use some brakes without spinning the car out. However, assuming you are talking about mod foams on carpet, your best bet is to run a diff especially if the track is tight.
Tony (defMondo)- sorry bro, but I'm not with you on the spools for tight tracks idea. Spools primarily work best on rubber tires with a large sweeping track. The reason for this is that the spool binds the front tires at low speeds where there is weight on both front tires while turning. Most drivers find that a spool will not only cause understeer (correct there) but they find a loss of corner speed at low speed turning. This is especially true in high traction situations such as foam carpet racing. I have a friend that I race with and he runs a spool everywhere. He is a very good driver and makes less mistakes than I do, but I usually have better lap times because I run a diff or oneway. He doesn't see that I'm gobbling up real estate on the infield when we race together. Bottom line? Learn to race with a diff, oneway, AND a spool. Then find out which one works best for the application (track) and use it.
BigDogRacing is offline   Reply With Quote
Old 09-04-2003, 10:30 AM   #3554
E.J. Evans's Avatar
Send a message via Yahoo to E.J. Evans
hierog, I won mod at speedworld last week with the EVO3-S. My setup is pretty much stock.
except:
60W in the front
50W in the rear
associated silver all around
second hole in on shock tower (front)
third hole in on shock tower (rear)
Yellow sway bar in the front
none in the rear
B block in the rear
5mm ride height all around
9mm droop all around (bottom of chassis to bottom of tire)
I'll give you a copy of my set up sheet this sat, If you'd like one.
tires make the biggest difference...I ran 36r's with zenon black
hope this helps!
E.J. Evans
E.J. Evans is offline   Reply With Quote
Old 09-04-2003, 11:11 AM   #3555
hierog's Avatar
that'd be great E.J., I'd like to see the sheet. I'll be there 2morrow afternoon to do some practice.
thanks!
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
