Tamiya TB-Evolution III
#3466
Super Moderator
i agree with aurra..i was scratching my head because that should give you lots of steering..anyway to gain on power steering, toe the from in..BTW..are you using the oneway?
What tires ARE you using? Using the stiffer spring in the rear actually sometimes gives you more traction as well. what cured my push problem was getting rid of the droop..making the axles parallel with the arms. try that..and hopefully you get closer to what you want.
#3468
Originally posted by Pirvan
Hey rtypec, you were saying sumthing about the little grub screws in the sway bar thingy. I have been wondering whats the effects of lossening or tigthening those, any advise?
Jeff
Jeff
#3469
Yes, I'm using a oneway. I'm using 30 Shimizu tires front and rear on an asphalt track. With regards to getting rid of the droop, should I adjust it with shocks on or without to make the axles parallel? Also, parallel axel with batteries on I assume.
Thanks.
#3470
Originally posted by rtypec
What I meant to say is that if you if you move the sway bar connector (the balls with the set screw thingy) closer to the end of the swaybar, it'll create a softer effect. If you move it further away from the end of the sway bar, it'll be more direct and stiffer.
Rod, Charlie, others- What ball cups are you guys using? I've found the Tamiya black balls cups are like the AE cups in that if you brush a pipe just right, it'll pop right off. Even if they're new and you don't have to hit very hard. I had the steering linkages pop off a few times and the outside camber link in the rear when we were in Atalanta for Fernando's big race (Toys for Boys). I had to back off in the main and drive in cruise control becasue I was scared I would brush a pipe and DNF over a stupid ballcup.
#3471
Gear Support
Hey Guys,
I was thinking of getting this gear support made for the front one way. I know the tamiya factory guys have something similar. It is a support that *has the same circumference* as the gear. Made out of aluminum .062 in thick (same thickness as the graphite piece).
I tried shimming the one way but still stripped a couple.
I don't know if a support like this will solve it, but I know it will help.
I'll test it and see if it works. If it helps I'll have more made. My co-worker owns a machine shop and is making them for me.
Your feed back is appreciated.
Here is how it looks like.
#3472
another view
#3473
Okay, so i'm not tripping on the sway bar connector adjustments :P
Interesting ball cup observation. I've only "popped" one off when I sheer a corner off my car...not exactly what I call brushing something hahaha. There are newer low friction ball ends (the gray ones) that I've been using lately (it's in the new Tamiya catalog). I believe they even cost less than the replacement black ones, thread on the turn-buckle tighter, snap on harder, and seem to be stiffer. There was talk at the Reedy Race about how the TRF guys were using the LF ball conectors with LF balls and having them pop off. I haven't found that to be the case. They worked fine and I highly recommend the LF gray ball connectors. If you do find yourself in a situation where a the ball connector pops off, I'd be more worried about what else may have broken after the impact that caused it haha.
#3474
One way back plate
Hey EJ...yup that looks exactly like the machined aluminum one that we run. It helps a lot but gears will sometimes strip.
BTW, awesome night-vision drive last weekend. Your car was the only one that was visible, that and the radio shaking in your hands When I was on the straight, I would see a dark shape with red led light zoom by, disappear behind a shaking radio, and reappear in the sweeper where the dark shape now had two white disks to spot it
#3475
Hey Rod,
My laziness finally paid off!! painting the body all white. I still have lots to do though, as dialed as I thought my car was in the main, you did the quickest by like .4!!!
#3477
Super Moderator
Ej..thats what i should have one..my paintjob was so dark i was looking at other cars to guage where i was at!
Explorer-i was referering to the droop screws on the arms..on my car, the shocks are actually longer than the parralell position, but i still use the droop screws to limit it's down travel..i am also at 4.4mm ride height. Can you get a hold of Take-Off 27's? That's the tire we pretty much have our base settings off of...then, we adjust accordingly.
#3478
Do you guys use the floride coated ball ends from Tamiya as well? they are awsome.... very durable on worn....
#3479
Re: Gear Support
Originally posted by E.J. Evans
Hey Guys,
Hey Guys,
#3480
freeing up drivetrain
i understand it does not really matter how long a drivetrain runs.
not trying to debate whether its the driver or what brand makes better cars. just want to get some ideas.
after reading about blueprinting drivetrain for the TC3 and how R2 can spin more freely after mods. any tips or tricks we can do for the Evo III to make the drivetrain more efficient?
besides clearing out bearings.
Thanks!
Thanks!
