Old 08-28-2003, 11:16 AM   #3451
they give more or less steering.i think its c1 right and c2 left
trf racer is offline   Reply With Quote
Old 08-28-2003, 01:22 PM   #3452
audiaudi's Avatar
Send a message via ICQ to audiaudi Send a message via MSN to audiaudi
Originally posted by V12
Anybody know about the difference on the front uprights C1/C2?
Check the parts list at the end of the instruction sheet, you'll find the uprights are in opposite position, means the ride height / roll center will have some different when you miss install them. Look carefully, the center of the shaft was not an the middle of the overall height of the upright....
https://www.facebook.com/aldusdesign
Trying very hard to jump back into RC with CRC Xti-wc.
audiaudi is offline   Reply With Quote
Old 08-28-2003, 01:40 PM   #3453
rcfiend's Avatar
Trader Rating: 29 (100%+)
Hello everyone I just purchased a Surikarn EVO3 Edition yesterday. I have a couple of questions maybe you guys would be kind enough to help me out with.
1. I noticed that the Surikarn edition has rubber sealed bearings. When you guys clean your bearings, do you remove the rubber seals to clean them and do you leave one side of the seals off.
2. I've heard that simple green does wonders in removing dirt and grease from bearings, is this true.
3. How well does the kit setup work in mod at a Tamiya like track.
Any of the building / preperartion suggestions will be greatly appreciated as well. Thanks for your help. Looking forward to building the kit.
rcfiend is offline   Reply With Quote
Old 08-28-2003, 01:53 PM   #3454
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
i ran my evo s at tamiya this weekend..the car works awesome..probably the opnly think i recommend in set up is stiffening up the springs...other than that, it is hooked...Rod kinda liked it too!
audi audi..you shold post your paintjobs at the painting forum...good stuff man!
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
TEAM ASSOCIATED|REEDY|HITEC|PARMA|PROTEKRC|SWEEP|IWATA| RPM|AMAIN|CREATEX/WICKED/AUTOAIR PAINTS|CFX|CAL RACEWAY
charlie_b is offline   Reply With Quote
Old 08-28-2003, 01:57 PM   #3455
audiaudi's Avatar
Thanks very much.. I have do that before.. but I have just made a big update so I'll try to do it later.... Thanks again....
Old 08-28-2003, 02:04 PM   #3456
Regional Moderator
R/C Tech Charter Subscriber
this mans paint work is great !yours is too charlie
Ko Racer is offline   Reply With Quote
Old 08-28-2003, 02:52 PM   #3457
Aurra Sing's Avatar
Im just in the final preparation for the nationals beginning tomorrow. Now I noticed the front uprights at my EVO3 are not as in the manual being C1 for right and C2 for left side. I bought the EVO3 as prebuild by another racer and he switched them over so the C2 is on the right and C1 is on the left side currently.
When it is C1 right and C2 left, the front roll center is higher by 1mm than it is when opposite. It will give you more turn-in steering at the expense of less mid-corner. It affects the amount of droop so you have to reset it if you switch. I always ran it Left C2 Right C1 on my 414M and Evo3.
Aurra Sing is offline   Reply With Quote
Old 08-28-2003, 02:55 PM   #3458
Trader Rating: 28 (100%+)
The kid is right and smart too.....Aurra?You racing Hobbytown this weekend?
racenut123 is offline   Reply With Quote
Old 08-28-2003, 09:10 PM   #3459
Default Understeer problem
Hi guys. Would like to ask anyone on how to improve steering on Evo3S. I just built the car and it understeers too much. Any suggestions?
Thanks.
Explorer is offline   Reply With Quote
Old 08-28-2003, 09:26 PM   #3460
Super Moderator
charlie_b's Avatar
what blocks ar you using in the rear? What springs/oil are you using? what's your ride height? How much droop do you have front and rear?
The real question is, where are you getting your understeer? entering a turn? in the middle? exiting a turn? on Power? off power?
that will narrow it down more.
Old 08-28-2003, 09:50 PM   #3461
Thanks for your quick reply.
Rear Block: A
Springs (Front): Tamiya Blue
Springs (Rear): Tamiya White
Ride Height: 5.5 (all around)
Droop: 4.5 front and rear
I experience understeer when entering a corner and on power.
Old 08-28-2003, 09:54 PM   #3462
Pirvan's Avatar
Hey rtypec, you were saying sumthing about the little grub screws in the sway bar thingy. I have been wondering whats the effects of lossening or tigthening those, any advise?
Jeff
Pirvan is offline   Reply With Quote
Old 08-28-2003, 09:57 PM   #3463
It should allow you to adjust the tension of the sway bars.
Awesomatix A700L (building) | VBC Wildfire D07 (building) |416WE/X Smokem | Hobbywing 120A v2.1 | Sanwa M11x
itchynads is offline   Reply With Quote
Old 08-28-2003, 10:00 PM   #3464
Pirvan's Avatar
So tightening the grub screw would increase tension and vice versa?
Old 08-28-2003, 10:22 PM   #3465
Aurra Sing's Avatar
Rear Block: A
That setup should give you a lot of steering... If you're having understeer then it's likely a tire related problem. Make sure you have the right tires and compound for your track.
racenut - i'll race at hobbytown this weekend. you running stock? even though I built your Evo3 you will never beat mine. hehehe
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
