Old 08-20-2003, 07:12 PM   #3331
racer's Avatar
has anyone tried square 3 peice aluminum centre posts that hold up the upper deck?
i have seen the same 3 graphite deck setup similar to the Yokomo SD.
just want to get an idea which will be better in preventing the chassis from twisting.
any input on this would be appreciated.
Thanks!
racer is offline   Reply With Quote
Old 08-21-2003, 03:57 AM   #3332
does anyone no were i can get the trf team t-shirts?
trf racer is offline   Reply With Quote
Old 08-21-2003, 09:04 AM   #3333
rtypec's Avatar
Up until recently, they were reserved only for team drivers. However, they have now been made available to the public so you too can look fast and represent. Okay..enough of the BS...here's the poop:
Available from TamiyaUSA
Size Item# Price
S S1127 $16.99
M S1128 $16.99
L S1129 $16.99
XL S1130 $16.99
2XL S1131 $18.99
rtypec is offline   Reply With Quote
Old 08-21-2003, 12:42 PM   #3334
Fully Hopped's Avatar
Lightbulb Shimmed Front One Way Pics for noobs
Here's some detailed pictures on shimming the front one way/diff. I thought I'd post this for noobs to the thread, and for anybody else that haven't done this mod that's getting discouraged with their cars due to the stripping of the Front One-way ring gear.
1. Pick up some shims For the front one-way. You will need Tamiya 10mm shim set part # 53588
While your at it pick up a Tamiya 5mm shim set part #53587 and shim the axles to take out the play. I shimmed mines 0.4mm on each side in the rear and 0.3mm on each side in the front.
Back to the Shimming of the Front One-Way
2. Shim the Front One-Way by placing the 10mm shims on the left side in-between the ball bearing and the front one-way as shown in the pictures. I shimmed mine by using [2] 0.3mm and [1] 0.2mm shims. A total of 0.8mm. This will move the One-way ring gear closer to the Bevel pinion gear for a much better and needed mesh, which will prevent stripping and enable a smoother drive train.
The amount af shims you use might vary, so shim and test till you get it right.
Heres how my One Way Ring Gear looks after 60-70 packs with a Reedy 10t dbl and a 19t spec. I really lost count
Still New looking! Not a scratch. Thats Ceramic grease on the gear btw. I gotta get some of that spray stuff that was mentioned in the thread somewhere.
Fully Hopped is offline   Reply With Quote
Old 08-21-2003, 01:08 PM   #3335
Aurra Sing's Avatar
Cool, thanx for the tip.
After three races, I have already stripped 3 front one-way gears. Never knew about the shimming trick.
Aurra Sing is offline   Reply With Quote
Old 08-21-2003, 01:43 PM   #3336
Intelligentsia's Avatar
I haven't stripped any on my Evo III S. I have had it for a few months now. I cracked my chassis before I stripped my oneway gear.
Intelligentsia is offline   Reply With Quote
Old 08-21-2003, 02:20 PM   #3337
Fully Hopped - Thanks for sharing. That looks like great advice on the one-way gear issue.
ARC MotorSports is offline   Reply With Quote
Old 08-21-2003, 02:29 PM   #3338
thanx rtypec.ive been using some that was printed at a local printing shop and now i waqnted the real thing and couldnt find ne at all.do u if they are limited edition
Old 08-21-2003, 03:49 PM   #3339
racer's Avatar
Fully Hopped,
did you sand the front/rear gearboxes to loosen up the bearings?
where do put the shims for the axles. on the outside where the wheel hub sits or on the inside where axles run through the steering knuckes?
Thanks!
Old 08-21-2003, 03:52 PM   #3340
rtypec's Avatar
I don't know. They don't have a 49xxx number but then again, they aren't rc parts
Old 08-21-2003, 03:55 PM   #3341
lol!ive just phoned tamiya usa and they got them so mine are on order[2 of them]!
Old 08-21-2003, 03:56 PM   #3342
Trader Rating: 28 (100%+)
Default bought 2
on monday.
racenut123 is offline   Reply With Quote
Old 08-21-2003, 03:59 PM   #3343
monday?i dont understand
Old 08-21-2003, 04:05 PM   #3344
Default From the tamiya usa website.
I purchased 2 monday,or was it tuesday....Anyways they are on thier way.
Old 08-21-2003, 04:09 PM   #3345
oh ok.now i get you
the only thing is the smallest they have is xl now is a good excuse to eat a lot and put on extra weight for it to fit !!!!
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 05:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 08:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 11:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 08:49 AM
SEO by vBSEO 3.5.0
