Old 08-15-2003, 08:45 AM   #3286
VenomWorldOrder's Avatar
Originally posted by (SE)XRAY
Does anyone know were I can get a Rollout chart from?
Thanks for the gear ratio chart.
Ta
check out my website www.rcunderground.net it is under the downloads/useful info section.
VenomWorldOrder is offline   Reply With Quote
Old 08-15-2003, 09:43 AM   #3287
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
The best place to generate your own gear ratio/roll out chart is here- Rcracing.com gear ratio page
Remember the EVO3's internal gear ratio is 2.6
BigDogRacing is offline   Reply With Quote
Old 08-15-2003, 01:30 PM   #3288
SpeedTech's Avatar
Hi Guys,
We have a couple new TB EVOIII hop-ups in stock from Tamiya, including the new 3mm chassis, aluminum upper camber link mounts and the new Delrin outdrives for the EVOIII.
Click here to go to the new parts page
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 08-15-2003, 02:54 PM   #3289
Intelligentsia's Avatar
Your Webpage shows that the lower chassis is out of stock Steve. Is this true? It already sold out?
Intelligentsia is offline   Reply With Quote
Old 08-15-2003, 08:50 PM   #3290
Default Gears !!!
I have been told that it is possiable to use TC3 diff gears in the EVO III gear box to help the car run more freely. As mine still seems to have a tight spot no matter how many times i rebuild the diffs i would like to know if this is true and if so what parts are used on the ball diff and the one-way diff.
Xray X1 "16" driven by an idiot, me
weekendracer_uk is offline   Reply With Quote
Old 08-15-2003, 09:30 PM   #3291
SpeedTech's Avatar
Hi Guys,
Sorry, it's true, some of the items are already sold out (word got out fast I guess ) I will try and get more in stock by the end of the week. Sorry about that guys.
Steve wang
Old 08-15-2003, 10:10 PM   #3292
Default Re: Gears !!!
Weekend racer, I've done it using the new yellow material ring gears, and it doesn't work all that well. There seems to be something more that is missing. With the TC3 ring gears, the mesh isn't correct and it wears the top edge off of the ring gear teeth, then those fine white slivers get into everything else and casue some binding. Hopefully I will get the chance to try some new stuff out soon that may help. I'm not sure...
Old 08-16-2003, 09:08 PM   #3293
jfc_tech's Avatar
Send a message via Yahoo to jfc_tech
Hi there every1? im new at TB Evo III. my drive is not that smooth as TC3 but seems ok after reinstalling the shaftgear. it doesn't sit properly the half round hole. I use matrix silicone lube for the bearing. Now i can push the Evo III and it never stop till it hit something.
Now my real question is regarding my new Quantum LRP ESC. Which mode i should use? the default is map 2=for offroad. I don't think thats correct for our use. pls advice friends thanks.
If you are in front of me, That's because I let you!
jfc_tech is offline   Reply With Quote
Old 08-17-2003, 02:09 AM   #3294
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
Hey Guys,
1st run at Tamiya today with my Evo3 S. Not a bad car..i slowly changed setups to get it going. I think for my driving, running the car with the stock springs/swaybars make it handle too sluggish. I am gonna try stiffening it up next week and see what it does.
Rod, thanks for the tips man!
charlie_b is offline   Reply With Quote
Old 08-17-2003, 07:22 AM   #3295
rtypec's Avatar
Hey Charlie....ya know...take look at Fred's car. He's got all the new stuff on it like your's and it was looking really good yesterday. Mine was so so.
rtypec is offline   Reply With Quote
Old 08-17-2003, 07:47 AM   #3296
Default Evo3 noise
Hi guys.....
I bought the Evo3 S. 2 weeks ago and I'm still fine adjusting it, but it runs very well....
I was wondering if anyone found a smart trick to get the spurgear to sit tight on the driveshaft. Mine seems a bit loose, and it makes a lot of noise when driving...
Any ideas???
SpineX-SSL is offline   Reply With Quote
Old 08-17-2003, 10:10 AM   #3297
NMRCDude's Avatar
Send a message via AIM to NMRCDude
The Spur gear SHOULD sit tight on the shaft,but the shaft should move up and down a few millimeters.
NMRCDude is offline   Reply With Quote
Old 08-17-2003, 11:46 AM   #3298
What I mean is that the spur + alu. holder doesn't sit tight on to the driveshaft, because it is only put on with the little metal tap through the hole in the shaft. This means that the spurgear can be moved back and forth and up and down.... Se what i mean on the attached file.
Old 08-17-2003, 08:18 PM   #3299
defMondo's Avatar
How can it move up and down? the shaft is simialr diameter to the hole in the spur gear holder.
There is a tiny bit of play back and forth but it's no biggy.
Have you actually build it?
Tony
defMondo is offline   Reply With Quote
Old 08-17-2003, 09:18 PM   #3300
I don't see how the shaft could move up and down in the spur gear holder unless the hole the bearing sits in was defective or the bearing itself was defective. Also check if you used the right sized holding pin to secure the spur gear to the shaft.
Awesomatix A700L (building) | VBC Wildfire D07 (building) |416WE/X Smokem | Hobbywing 120A v2.1 | Sanwa M11x
itchynads is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
