Old 08-12-2003, 09:23 PM   #3256
Korey Harbke's Avatar
Anyone have a good carpet setup on rubber tires? Just wanna see what everyone else is running.
-Sushi Boy
Pro Spec America/Apex RC - Team ORCA - Awesomatix USA - Roche RC USA - AVID - Sweep - Protoform - Pro-One RC - Slapmaster Tools - Hebiki Design Works - Turtlemaster Racing - Seattle RC Racers - Timezone Hobbies
Korey Harbke is online now   Reply With Quote
Old 08-13-2003, 01:52 AM   #3257
McLaren's Avatar
I will race in Stock with 21T motors. Do the 1 way, diff gears need to be changed in Stock racing too or is the problem present in Modified racing only?
McLaren is offline   Reply With Quote
Old 08-13-2003, 02:04 AM   #3258
WC
WC's Avatar
Trader Rating: 28 (100%+)
Originally posted by Geetoo
Yes its thesame as the TA04's. Although what comes with the TB are carbon reinforced which has more strength compared to the 04's. Notacibly the arms hardly break that only hinge pins and suspension blocks are most of the time damaged on a hard crash.
The EvoIII arms are available as an option pack for "TA04 Hard Suspension Arm", think they are standard fitment on the TA04R.
I have not broken one myself, but when I lent my hard-arm'd
TA04PRO to a friend, he did manage to smack something hard
enough to snap a front arm. (Yes, hinge pin got bent too).
If ya gotta hit something, hit it front on & let the bumper
take the impact. Hitting it offset concentrates the force onto
bits not meant to take the hit, with expensive consequences.
WC is offline   Reply With Quote
Old 08-13-2003, 08:06 AM   #3259
McLaren's Avatar
What is the minimum drive frequency possible on the GT7? If you set it on 1 KHz, will it damage a stock motor?
I read that the smaller the drive frequency the more punch you have, is it true?
Old 08-13-2003, 08:12 AM   #3260
VenomWorldOrder's Avatar
the evo arms are tough but in cold conditions the overly hard arms may be more prone to cracking due to the cold. try standard arms in cold weather.
really, the front one way gear is the only breakable part. if you damage it it can be cleaned up with a sharp surgical blade. i race with a 6t hacker brushless and only found the gear becoming "damaged" after very hard hits. i cleaned it up and it was fine... now to figure out how the top drivers get 4 laps over me in 5 minutes........oww yeah, i remember, clean lines!
VenomWorldOrder is offline   Reply With Quote
Old 08-13-2003, 09:13 AM   #3261
davioh's Avatar
has anyone had a bent shaft? it seems that my shaft wiggles a bit...is this normal?
davioh is offline   Reply With Quote
Old 08-13-2003, 03:04 PM   #3262
rtypec's Avatar
Yes and No
Shafts get bent under extreme impacts. No car is immune to a bent center shaft. When the Evo3 first came out, I bent one at a state championships, had no spares, and suffered the rest of the day...only to realize that they arrived a week earlier and were only 5-7 bucks each. From then on, I've kept 2 or 3 on me at all times and replaced the one in the car whenever it looks really ratty or has a slight wobble...not that I'd ever go through that many in a race day..but it's always nice to know you're covered.
rtypec is offline   Reply With Quote
Old 08-13-2003, 03:08 PM   #3263
cHckbOY5's Avatar
Send a message via AIM to cHckbOY5
wat are must spare parts for the car?
cHckbOY5 is offline   Reply With Quote
Old 08-13-2003, 03:17 PM   #3264
rtypec's Avatar
Hmmm, a spares list. Here's what I usually bring with me:
One way gears
Diff and Pinion Gears
Center Shaft
Universal Parts
Hinge Pin Sets
A and B Blocks (depends on your setup)
Hub Carriers
Steering Knuckle Bits
Spacers
Plastic Trees
Bearings
Screws
Redbull and Rockstars
and a can of Whoop-A$$
Old 08-13-2003, 03:18 PM   #3265
cHckbOY5's Avatar
im thinkin of just gettin an evoS since the price on the cuda went up
Old 08-13-2003, 03:35 PM   #3266
izzyracer's Avatar
Trader Rating: 27 (100%+)
One way gears
Center Shaft
Universal Parts
Hinge Pin Sets
Hub Carriers
Spacers
Plastic Trees
Bearings
Screws
What about a whole new kit...make it two for spares
Izzy
izzyracer is offline   Reply With Quote
Old 08-13-2003, 09:20 PM   #3267
Hey rtypec,
I have a Question about the Reedt 19T spec motor. Whats the hot ticket for gearing and brush/spring combo. Our track size is very similar to the Tamiya America track. Thanks.
-Sushi Boy
Old 08-13-2003, 10:17 PM   #3268
Rod I see you added the Rockstar to the box the only way to go.
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 08-13-2003, 10:26 PM   #3269
rtypec's Avatar
Okay this is my recipe for the 19T. I don't have a dyno or anything like that so I can't provide numerical data to back this up. Just lots of track time.
1. Open new package containing a Reedy 19T Spec Motor
2. Solder on some capacitors to the endbell
3. Remove the brushes that came with the motor. Look at the wear on the brushes to see how close they are to being alligned. Allign the brushhoods if you feel like you're able to do it (I don't hehe)
4. Solder Trinity 4499's on. Use the straight serrated 4499's not the diagonal ones. The motor feels better with the straight serrations for some reason.
5. Cut the comm to make sure it's perfectly round.
6. Put the motor back together and shim the armature for magnet center with a little bit of play both ways. We don't want it bindy.
7. Bend the positive spring so that it's almost 180 degrees...more like 170-175 using the eyeball dyno.
8. Run the motor with approx 3V until the brushes are seated. This does not mean until the serrations are gone. Run it just enough so that there aren't super sharp edges on the brush. When their broken it...pull them out of the hoods. Spray some motor spray on a cotton swab (Q-Tip) and clean the face off the brush. You'll see a lot of poo come off with the swab (I don't use a stick because I believe they are too abrassive). RBF gets credit for this tip
9. Cut the comm again.
10. Reassemble, lube, and bolt it into your car.
11. Gear at 5.9 for tracks like Tamiya or 6.1-6.3 for tighter tracks like Socal.
That's it. I hope this helps
Old 08-13-2003, 10:31 PM   #3270
rtypec's Avatar
Holy Crow Dan! Rockstars make you run like a 2Turn Modified. Great stuff and good call on that. Twice the size and a bunch more zing! Haven't drank four yet but three gets ya movin. Would it help a johnson/mabuchi if you submerge it into rockstar for break in?
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 05:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 08:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 11:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 08:49 AM
SEO by vBSEO 3.5.0
