Old 08-04-2003, 01:51 AM   #3166
defMondo's Avatar
Interesting, I have only ever had this come off once and I thing that was due to not tightening the grub screw enough.
But other wise the loctite works a treat, even for the small screws that hold the one way diff gear.
Tony
defMondo is offline   Reply With Quote
Old 08-04-2003, 02:12 AM   #3167
WC
WC's Avatar
Trader Rating: 28 (100%+)
Don't use Tamiya's treadlock on the Unis... use a liquid anaerobic type like Loctite blue (non-permanent) stuff. And don't just put it on the grubscrew, drip it into the screwhole.
For extra security... nothing stopping you wrapping the outside of the unis with a little tape, so it holds the pin in even if its loose.
No uni problems so far.
(University? That's another story...)
But one of my shockers managed to disassemble itself last w/e.
Dumped its sump all over the arm & tyre - lucky it was a rear.
WC is offline   Reply With Quote
Old 08-04-2003, 03:10 AM   #3168
Johnny J's Avatar
Are you serious about that shock? Last week my FL shock also stuffed up. The cap thingo on the bottom unscrewed and oily goodness was all over the place. Sad thing is i raced the whole day wondering why my rear wheel would keep lifting up during the corners lol
Johnny J is offline   Reply With Quote
Old 08-04-2003, 06:21 AM   #3169
Aluma's Avatar
okay, I'm going to put in my axiom tuned monster stock... but am having a dilema as to which spur and pinion to install...
I have the 72 and 66 tooth spurs(kimborough) and a full assortment of pinions... I know from a few posts behind that a 96/30 or 96/31 would be a good place to start....which is a 8.1 or so final drive ratio. so which would be a better choice 72/23 or 66/something? Last time I had one, I kept getting passed by the p2k's and such.
Aluma is offline   Reply With Quote
Old 08-04-2003, 09:37 AM   #3170
NMRCDude's Avatar
Send a message via AIM to NMRCDude
Well the higher the FDR, the more bottom end youll get. Are the P2K's beating you on the straits? Or out of turns? And what size of a track is it?
NMRCDude is offline   Reply With Quote
Old 08-04-2003, 09:46 AM   #3171
Regional Moderator
Send a message via AIM to Mike F
Originally posted by itchynads
Most people who run the Evo3 accept the fact that you will have to replace the gears since it is considered a disposable item. I usually go through 1 or 2 a race day so I usually stock up on gears.
That's not being very efficient. you would think this probelm has been addressed and solved with Tamiya.
Mike F is offline   Reply With Quote
Old 08-04-2003, 11:03 AM   #3172
Is this a joke? Do you really need to change the diff/oneway gears if you race more than once with it?
Is this problem present in stock racing too?
Raikonnen is offline   Reply With Quote
Old 08-04-2003, 11:17 AM   #3173
Regional Moderator
Not sure if it's a joke but it's a problem that you think would have been fixed, especially when your talking about a high end price kit.
Old 08-04-2003, 11:56 AM   #3174
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
well, i have run mine every weekend for about 3 months, and have no problems at all... of course, i am running a diff, no oneway. stock motors, rubber tires, on asphalt. exceptionally smooth driveline currently... i did manage to crack the graphite battery hold down strap last saturday tho.
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 08-04-2003, 11:56 AM   #3175
racer's Avatar
what size spur do most of you use with a stock motor?
any suggestions for a Team Orion core stock?
any help would be appreciated.
Thanks!
racer is offline   Reply With Quote
Old 08-04-2003, 01:34 PM   #3176
I will try to use 62 spur with 34 titanium pinion with a stock motor, i.e. final drive ratio of 4.74 ... all the guys in our track have the cars setup this way ... have anyone tried such ratios before?
Old 08-04-2003, 01:48 PM   #3177
GTMilenko's Avatar
i gear my johnson 540 at 4.63, i've seen others go as high as 4.00
GTMilenko is offline   Reply With Quote
Old 08-04-2003, 04:42 PM   #3178
defMondo's Avatar
I have used Trinity Monster Pro and Fantom Tuned Monsters and have geared at up to 5.6 with good success. The motor comes back just warm after 5 minutes of racing.
I either use a 90 tooth 0.4 spur or an RW 71 tooth 48 pitch spur with the monsters.
I think 5.8 to 6.0 is a good ratio to start with. The tracks I race at have a straight which is about 35 - 40 meter long (~115 feet) and the rest of the track is flowing but not super fast.
Being very smooth with the throttle helps heeps with motor temperature as well, a stop/start style of driving will burn it up at these ratios.
Hope this helps.
Tony
Old 08-04-2003, 04:43 PM   #3179
defMondo's Avatar
With a 540 I have geared at 5.01 on a tight track and the car has been flying past everyone else.
Tony
Old 08-05-2003, 08:22 AM   #3180
Aluma's Avatar
heres my track... #3 has 60ft by 100ft or so. Hey, I was talkin to the TC3 guys and they said to run about a 7.5 to 8.0 Fdrive.
like a 72/21 or 72/25. (which is what i had before on my evo2 I used to have) But i was getting beat on both straightaway and infield....haven't tried it on the evo3 yet.
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
