Old 07-28-2003, 11:42 PM   #3091
VenomWorldOrder's Avatar
Originally posted by Sushi Boy
I hate it when it turns white.
-Sushi Boy
rub it with a cloth with metho on it. should come off.
or previous to putting glue. clean surface with metho. the white is sometimes grease from your hands that shows up. cops use CA glue to show up fingerprints for this exact reason.
my chassis went white in some areas and it came of with a rag with alot of metho
VenomWorldOrder is offline   Reply With Quote
Old 07-28-2003, 11:57 PM   #3092
GTMilenko's Avatar
i did the same thing here, also if you just rub your finger one it hard enough it comes off aswell! took less time to take the white off than it did to fill out the battery slots.
GTMilenko is offline   Reply With Quote
Old 07-29-2003, 01:37 AM   #3093
[quick question what is the internal gear ratio of the evo 3 surikarn?
Old 07-29-2003, 02:16 AM   #3094
GTMilenko's Avatar
2.6
Old 07-29-2003, 02:28 AM   #3095
Send a message via ICQ to David
ok im building my surikarn
could someone tell me a good starting point pinion and spur wise to race 27 turn stock the kit has 90 and 96 spurs with 34 pinion
if i have to buy others i will
i just want to build it right the first time
David is offline   Reply With Quote
Old 07-29-2003, 03:03 AM   #3096
hawker's Avatar
depends what surface your running on, i've got mine set on the 90 spur with a 47 or 48 pinion and BOY DOES IT FLY, however handling is another issue .
hawker is offline   Reply With Quote
Old 07-29-2003, 05:13 AM   #3097
did u get the gear info i sent you of what one of the zarbs ran at meca? he ran stock i recon that as a start point with a pinion of 1,2 or 3 teeth more if you want more top end.
heres some pics
Old 07-29-2003, 05:20 AM   #3098
hacket dude!
Old 07-29-2003, 05:24 AM   #3099
ohh ohh!! look!! blue and red!.........w---o----o-----w!
and it has my initials on the blue bit!!.........ooo- - - - - oooooo -o o-o-o-o-o-ohhhhh!!
Old 07-29-2003, 05:27 AM   #3100
I saw a photo with the BLUE gearbox! My Surikarn comes with the plastic gearbox. Where can I find the BLUE or RED aluminium gearboxes for sale? Thanks.
Raikonnen is offline   Reply With Quote
Old 07-29-2003, 05:54 AM   #3101
Motorsports00's Avatar
Raikkonenn you can find them on www.hobbymania.com under " square" or from rcmodel.com.hk
cheers
will
Motorsports00 is offline   Reply With Quote
Old 07-29-2003, 06:14 AM   #3102
also dave i recommend using steel screws for the engine mounts to the chassis. i used the titanium ones......and too much tamiya threadlock....
just use 2 from ur mtx3. or you will end up like me with a very well attached engine mount
Old 07-29-2003, 06:15 AM   #3103
I installed the LRP IPC DIGITAL V7.1 (No Motorlimit) on my TB EVO III. Can anyone tell me what is the best way to set it up for Stock Racing?
Old 07-29-2003, 07:42 AM   #3104
rtypec's Avatar
Give the kit spur gears away to some one at the track Pick up some RW 96Tooth 64 Pitch spurs. They are super smooth and I have never had one chunk. That coupled with TiR pinions, and you've got yourself a solid setup.
Oh yeah, back to the chassis. It's all good Much better now. I do have the anti-hazing glue, but I prefer the really gnarly stuff from Loctite.
rtypec is offline   Reply With Quote
Old 07-29-2003, 03:36 PM   #3105
Aluma's Avatar
hey guys what spur/pinion combos you running on the Pro Monster stock motors? yeah... I know it might be a different track, but i just want to get a good fast gear ratio for it.
Aluma is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
