Old 07-26-2003, 04:29 PM   #3046
GTMilenko's Avatar
Aluma- thanks man, i will have to try that! i've got the stratus 2.0 now.
davioh - yes that weight was with everything on except the transponder, i only used one can of paint on my body and my batteries are sanyo's 1300nicd's
JDM_DOHC_SiR - i don't know how much it weights now with the new gear box's, i also just added a metal geared servo and some more alloy parts aswell so i would say its well over 1500 now! i just got a full set of ti screw to bring it back down a little.
GTMilenko is offline   Reply With Quote
Old 07-26-2003, 07:23 PM   #3047
hawker's Avatar
how come your cars are so heavy?
i've got mine weighing at exactly 1500 EVERY time it goes on the scales. I had to add weight to get it up to that though, with everything on it was about 1460
hawker is offline   Reply With Quote
Old 07-26-2003, 07:48 PM   #3048
Fully Hopped's Avatar
Originally posted by NMRCDude
Hey,
You guys have any trouble with the servo mounts? I purchased a low profile servo the other day, and the thing would not fit between the two mounts! The case was too big! I ended up mounting it to one of the mounts and laying a strip of double-stick tape for the rest. Seems to work.
I'm using a futaba s9550 low pro servo and it fits perfect. What brand servo are you using?
Fully Hopped is offline   Reply With Quote
Old 07-26-2003, 07:50 PM   #3049
Do you guys styill have any problems with the gears striping or did they fix it with the back plate?
I wanted to getr one put this was the only thing that put me off.
teamAE is offline   Reply With Quote
Old 07-26-2003, 08:14 PM   #3050
davioh's Avatar
what batts do you use?
GT: haha i hav 2 and a half cans of paint and a bunch of stickers! im gonna go easy on the stickers next time!
davioh is offline   Reply With Quote
Old 07-26-2003, 08:22 PM   #3051
hawker's Avatar
i'm using Tamiya 2400 and a Tamiya 3000NiMh
Old 07-26-2003, 08:27 PM   #3052
davioh's Avatar
damn GP's! but the thing is that sanyo's don't fit my car! they are too wide (3300)
Old 07-26-2003, 08:29 PM   #3053
hawker's Avatar
i'm using stick packs so yeah
Old 07-26-2003, 08:35 PM   #3054
davioh's Avatar
ah i see...when i used stick pack my car was 1525 race ready and that was with the tamiya 3300
Old 07-26-2003, 08:38 PM   #3055
hawker's Avatar
tru, ah well 1500 1525 i don't think there is that much difference
Old 07-27-2003, 04:57 AM   #3056
Johnny J's Avatar
Default Surikarn Setup
I am about to put the Surikarn setup on my car, but i noticed that under oil weights, he put 700 #. What would this be in conventinal weights such as 50 wt or 45 wt etc?
Johnny J is offline   Reply With Quote
Old 07-27-2003, 08:29 AM   #3057
rtypec's Avatar
Tamiya has addressed the gear stripping problem with a new backing plate part number:
Item 53625 TB Evo.III Oneway Ring Gear Carbon Plate.
It does help the one way gear last a lot longer, but with any big shunt, you should take the pinion gear off your motor and give the drivetrain a spin. If you feel a notch, check the one way gear. Chances are that you can avoid replacing the gear if you find a little gear flashing early enough (indication that the gears gonna get roached) and clean it up with an exacto knife.
Johnny J: The 700# is a metric weight as opposed to an SAE weight that Losi and AE uses. There is no definable way of calculating a conversion between the two. Your best bet is to puchase a collection of Tamiya damper oils, they're relatively inexpensive and it's awesome stuff.
53443 Silicon Damper Oil Soft Set (#200,300,400)
53444 Silicon Damper Oil Medium Set (#500,600,700)
53445 Silicon Damper Oil Hard Set (#800,900,1000)
GT: Your car is understeering? Where? coming into a corner, mid, exit? Your setup looks like it would have a ton of steering. Have you tried dropping the front upper inner camber links (if you have a standard Evo) and have you played with anti squat?
davioh: Please, try to add something useful to this discussion instead of your one-sentence babble. At one point, my Evo3 weighed in at around 1400g race ready with transponder and Ultlra Metals..blah blah blah...I dont know how much it weighs anymore and I don't care. As long as it barely makes the legal weight at big events. I'd rather worry about how the car is handling than how much it weighs...no ammount of weight savings is gonna save you if your car and driving is poo
rtypec is offline   Reply With Quote
Old 07-27-2003, 08:44 AM   #3058
davioh's Avatar
sorry about the babbles! i hav a habit of doing it...hmm...thanks for heads up...again? my driving has been much better than it was during the last race...but sadly my second attempt was GONE because i forgot about it
Old 07-27-2003, 08:47 AM   #3059
rtypec's Avatar
No worries, davioh. It's hard to contain our enthusiasm about the Evo3 sometimes It's all good.
It could be worse, have you seen some of the signatures in the baracuda thread? Take about a scrolling and hunting for the message!
Old 07-27-2003, 09:10 AM   #3060
madjack's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to madjack
rtypec...how true.
I have my index finger in a cast currently. Web injury: due in part to excessive movement of the mouse wheel while scrolling thru the fish thread
So did the E3 update parts ever hit TA last week?
madjack is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
