Old 07-20-2003, 11:20 PM   #3016
defMondo's Avatar
Originally posted by Leester
Excuse me please? I asked very politely about a TCS asphalt setup and yet no one has responded yet. I hope no one is going to ignore me because I wrote down some good setup information for somebody to answer. So please I ask you kindly once more could anyone who has TCS expierince give me a good evo III setup so I can have somewhere to start with? Thank You
This setup is working extremely well for me:
Setup
The I where I got this setup was fairly smooth mid to high grip.
Tony
defMondo is offline   Reply With Quote
Old 07-21-2003, 12:23 AM   #3017
dsrbltoys's Avatar
Default Lee,
Are you going to nats again this year? If so what class are you looking to run???
As for the setup. Rod's set up seemed to work very well at Reedy I run a very similar setup to this!
Kevin
dsrbltoys is offline   Reply With Quote
Old 07-21-2003, 04:32 AM   #3018
could any one tell me y u cant use the outer hole for shock mounting position on the rear.
trf racer is offline   Reply With Quote
Old 07-21-2003, 04:49 AM   #3019
YOu cannot use the outer hole on the rear shock tower as the bodymount will not allow the screw to go in the hole, just dremil a little off the body mount where the screw would hit then all is ok. Rick
Rick Draper is offline   Reply With Quote
Old 07-21-2003, 11:26 AM   #3020
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
This is for GT1- a stock setup would be different
everything is quoted fr/rr (meaning front/rear)
springs- yellow/yellow
oil- 30/30
pistons- 3/3
arms- centered/centered
shock positions- #1/#4
camber links- #4/#1 (b on rear upright)
swaybars- none/yellow
camber 1.5/1.5
toe- 0/kit
ride height- 5/5.5
droop- 2/2 (that's mm- so the front is 7mm fully extended)
tires- Tamiya A or B2 if track temp is above 120 and Tamiya thin firm inserts
body- Modena
all the small stuff is kit settings
BigDogRacing is offline   Reply With Quote
Old 07-22-2003, 03:44 AM   #3021
ok thanx rick.
Old 07-22-2003, 01:04 PM   #3022
Leester's Avatar
Trader Rating: 20 (95%+)
Thank You for all the information. I wil try every setup
Kevin- I'm thinking of ethier running F1 Or GT1 I'll see what happens two months form now.
-Lee
Leester is offline   Reply With Quote
Old 07-23-2003, 01:12 PM   #3023
cud any one tellm me if u can use the outdrives from the f201 on the evo3 surikarn edition.
Old 07-23-2003, 02:31 PM   #3024
The f201 outdrives will not fit the evo 3 but the rear diff gears do.
If you need new outdrives get the new ones included in the surikarn. They should last a long time with antiweargrease.
Mr_Orange is offline   Reply With Quote
Old 07-23-2003, 03:39 PM   #3025
Send a message via AIM to ZER01
Anyone know if the outdrives on the evo2 are made of steel and will they fit using the evo3 diff gear? Basically I'm looking for some steel outdrives to fit my evo3. Just finished building my evo3 and I'm very pleased with the turnout, I don't think I've ever built some shocks as smooth as these.
ZER01 is offline   Reply With Quote
Old 07-23-2003, 03:54 PM   #3026
Trader Rating: 17 (100%+)
Send a message via AIM to AQuionIV Send a message via Yahoo to AQuionIV
tamiya shocks are always, the easiest and the smoothest to build=)
AQuionIV is offline   Reply With Quote
Old 07-23-2003, 04:37 PM   #3027
Korey Harbke's Avatar
Yes, I agree. I love top loading bladder shocks. It's WAY better than the funky bottom loading losi shocks. I could never get an air free shock out fo those. The Tamiya shocks are works of art. Super smooth, and I can get them air free.
-Sushi Boy
Apex RC - Prospec America - Awesomatix USA - Roche RC USA - Protoform - AVID - Xpert - Sweep - Slapmaster Tools - Hebiki Design Works - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 07-24-2003, 01:54 AM   #3028
Jesse- just run the black ones until the white ones come out. They don't have them at Tamiya USA yet, but shouldn't be long.
Old 07-24-2003, 04:56 AM   #3029
Johnny J's Avatar
I've had the Evo 3 for a while now, and i seem to be going through a lot of One-way gears. Can you buy aluminium ones?
Also, when i take the motor off, and i spin the spur, its very smooth, untill i come up against a resitence , then a bit of force and its right again. I have checked the front and back gears, and the shaft bearing, but have had no luck. I'm pretty sure its a tooth of something in the diffs, so i'll tear it down again later. But any idea's?
Thanks alot
Johnny J is offline   Reply With Quote
Old 07-24-2003, 07:40 AM   #3030
VenomWorldOrder's Avatar
Thanks alot
get the carbon plate and try to stop smashing, it may stop the gears from stripping.
in regards to ressistance i had the same with my evo 3 surikarn. some gears have small (read very small) imperfections. get some fine wet and dry sand paper and sand top of gears down lightly and with a rigid thin peice of metal (like a eating knife) wrap the wet and dry S paper over it and go through each tooth gap, a few times.
after this and a run on the track it is super free.
VenomWorldOrder is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 05:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 08:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 11:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 08:49 AM
SEO by vBSEO 3.5.0
