Old 07-16-2003, 09:57 AM   #2941
Regional Moderator
Send a message via AIM to Mike F
Originally posted by proudwinner
Anyone got the part number/s for the updated parts to the oneway that is in the surikan edition evolution? I know there's a brace, anything else. Any help will be greatly appreaciated.
How are you liking this car Proud as oppose to the others you've owned?
Mike F is offline   Reply With Quote
Old 07-16-2003, 10:05 AM   #2942
Korey Harbke's Avatar
I just got my Evo 3 S and WOW. This car is going to be sweet. The presentation of the parts is great, the quality is great, and all the carbon fiber chassis parts and red aluminum just blows me away. I'll be buildign this ALL day.
-Sushi Boy
Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - Xenon - Xpert - Sanwa - Sweep - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 07-16-2003, 12:16 PM   #2943
Intelligentsia's Avatar
I have been running mine for a couple nights and I am loving it so far!
Intelligentsia is offline   Reply With Quote
Old 07-16-2003, 01:02 PM   #2944
GTMilenko's Avatar
Originally posted by tamiyadriver
the 414s will be a bit ttricky, as they have no notch to get to the bottom diff housing screw... you will have to remove the block when you pull the diff. but they should be stronger, since they are thicker. tamiyausa's site gives 3454073 for the part #
great thanks! are these ones the same width as the "a" blocks?
i have to remove the blocks anyway because i have spacers under them.
GTMilenko is offline   Reply With Quote
Old 07-16-2003, 01:33 PM   #2945
Send a message via AIM to ZER01
Very much Mike! The quality and craftsmanship of Tamiya is nice. So far I'm impressed-alot.
ZER01 is offline   Reply With Quote
Old 07-16-2003, 01:41 PM   #2946
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
yup.. that part # is out of my manual. should be the sraight block, with no offset, just like the A. i do need to verify the spacing is the same, so ill do some measuring this evening and compare the two when i get home... handy having both cars!!
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 07-16-2003, 01:47 PM   #2947
GTMilenko's Avatar
thats great! thanks man, also any idea where i could get a set from for a good price?
Old 07-16-2003, 03:34 PM   #2948
racer's Avatar
V12,
here is the breakdown for the titanium turnbuckles used on the SEvoIII:
-one 42mm for the servo arm
#2520040 ??? (that what was printed on the parts list)
-four 32mm for the camber links
#53527
-two 23mm for the steering
#53526
hope this helps
racer is offline   Reply With Quote
Old 07-16-2003, 03:43 PM   #2949
V12
V12's Avatar
@ racer
thank you, thatīs exactly what I was looking for
V12 is offline   Reply With Quote
Old 07-16-2003, 07:10 PM   #2950
WC
WC's Avatar
Trader Rating: 28 (100%+)
The 414 boys here use the green bits interchangeably, so I would assume so...
WC is offline   Reply With Quote
Old 07-17-2003, 12:34 AM   #2951
Default TB EVO III (Surikarn Edition)
Hi everyone,
I just received the TB EVO III (Surikarn Limited Edition) yesterday and I was busy building it almost all the night. It is great with all the red hop ups, titanium staff, etc. included!
I have few queries and will be grateful if you can comment on the following:
- When you assemble the gearboxes, do you have to put a lot of grease on the Bevel Pinion Gear and the Main Ring Gear or just little?
- Once you finish the gearboxes and install the Propeller Shaft, if you turn the shaft with your fingers, does it have to be really smooth? Mine seems to be bit smooth, but makes small cracking noise. Is it normal?
Thanks everyone!
Raikonnen is offline   Reply With Quote
Old 07-17-2003, 12:51 AM   #2952
FUK_WRX's Avatar
Send a message via ICQ to FUK_WRX Send a message via AIM to FUK_WRX Send a message via MSN to FUK_WRX Send a message via Yahoo to FUK_WRX
Default Re: TB EVO III (Surikarn Edition)
Originally posted by Raikonnen
Hi everyone,
Thanks everyone!
Cracking noise dont sound normal, it suppose to be really smooth AND without any sort of cracking noise. Just rebuild it, you must have missed something, knowing tamiya it would be rare for it to have any miss moulds what soo ever. Hope this helps
FUK_WRX is offline   Reply With Quote
Old 07-17-2003, 01:03 AM   #2953
Post
Hi FUK_WRX,
Thanks for your suggestion ... and for the other question (please)
Old 07-17-2003, 01:12 AM   #2954
GTMilenko's Avatar
Hi FUK_WRX,
i myself just put a little on the pinion gear and none on the bevel gear, i've tried using more and it just flicks it off anyway.
Old 07-17-2003, 01:16 AM   #2955
raikanen wen u 1st built the gearboxes did u put grease in?the crackling noise cud be the grease.
trf racer is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
