Old 07-14-2003, 05:50 PM   #2926
NMRCDude's Avatar
Send a message via AIM to NMRCDude
On a tight track I would run somewhere around 6.3-6.7 over all gearing with the P2K2.
Thanks a bunch Tony!
NMRCDude is offline   Reply With Quote
Old 07-14-2003, 07:07 PM   #2927
gcooper's Avatar
Originally posted by KiwiKid
Hi,
On a EVO III, I don't know because I've never run a stock motor in it. (In fact, I've not even run it yet.)
In a TA-04R, I used to run between 6.2 to 6.5 on a tight track. Used Tamiya B2s mainly. No specific break-in for the motor.
Maybe you will get to run it soon.
Have you been able to compare the 23t motor to a 27turn in your 04? If you have what have you noticed between the two.
Coop
gcooper is offline   Reply With Quote
Old 07-14-2003, 07:34 PM   #2928
KiwiKid's Avatar
No I haven't, but I believe if you gear the 27 turn correctly, you should be able to get around the same top speed but will lose out slightly in the turns where acceleration counts.
Coop
KiwiKid is offline   Reply With Quote
Old 07-14-2003, 09:03 PM   #2929
NMRCDude's Avatar
1 more question...
The lower the final gear ratio (6.3), the more bottom end?
Also, what pitch is this...
Old 07-14-2003, 09:12 PM   #2930
Korey Harbke's Avatar
The lower the FD ratio the more top end you get. The higher it is, the more bottom end punch you get.
-Sushi Boy
Apex RC - Prospec America - LRP - Roche RC USA - Awesomatix USA - Protoform - AVID - Xenon - Xpert - Sanwa - Sweep - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 07-14-2003, 10:30 PM   #2931
defMondo's Avatar
Originally posted by NMRCDude
1 more question...
What Sushi Boy Said.
Well you said you had a 90T spur so I assumed it was the Tamiya 0.4 pitch which is close enough to 64pitch, so you will need similar pitch pinions, the Tamiya ones are very nice and light I use them.
Tony
defMondo is offline   Reply With Quote
Old 07-15-2003, 02:03 PM   #2932
Send a message via AIM to ZER01
Anyone got the part number/s for the updated parts to the oneway that is in the surikan edition evolution? I know there's a brace, anything else. Any help will be greatly appreaciated.
ZER01 is offline   Reply With Quote
Old 07-15-2003, 03:02 PM   #2933
racer's Avatar
the only difference in the Surikarn Edition besides the one-way brace are the reinforced cup joints. no need to shim with washers compared with the regular EvoIII.
part number for the cup joint is: 53590
racer is offline   Reply With Quote
Old 07-15-2003, 03:15 PM   #2934
You happen to have the part number for the brace? Much thanks racer.
Old 07-15-2003, 03:21 PM   #2935
racer's Avatar
yes, here is the part number you requested for:
one-way brace: 53626
Old 07-15-2003, 03:24 PM   #2936
Thanks Racer.
Old 07-15-2003, 03:25 PM   #2937
racer's Avatar
your welcome!
Old 07-15-2003, 11:29 PM   #2938
GTMilenko's Avatar
hey guys, i'm thinking about replacing the suspension blocks on my evo with the 414 ones, because i hear they and a bit stonger? can anyone fill me in on part numbers? and any other info about this matter? i use the "a" blocks all round at the moment. thanks in advance!
GTMilenko is offline   Reply With Quote
Old 07-16-2003, 07:13 AM   #2939
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
the 414s will be a bit ttricky, as they have no notch to get to the bottom diff housing screw... you will have to remove the block when you pull the diff. but they should be stronger, since they are thicker. tamiyausa's site gives 3454073 for the part #
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 07-16-2003, 09:14 AM   #2940
V12
V12's Avatar
What length are the Titanium turnbuckles included in the Surikarn EVO3īs? For steering itīs 18mm I think but what is for the a-arms? The stock EVO3 uses 28mm steel turnbuckles but as I know there is no 28mm Titanium turnbuckle from Tamiya right now. Is there a new 28mm Titanium with the Surikarnīs or is the 32mm turnbuckle included?
V12 is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
