Tamiya TB-Evolution III >
Old 07-09-2003, 06:46 PM
  #2851
Korey Harbke's Avatar
Default Re: FAT EVO III
Originally posted by FUK_WRX
Fat evo III, by KAI although i dont think looks so good preety curious how it will handle
KAI EVO III FAT VERSION
That thing looks scary. It's not even an Evo 3 anymore
-Sushi Boy
Korey Harbke is offline
Old 07-09-2003, 09:13 PM
  #2852
davioh's Avatar
hey is the internal gear ration 2.2 or 2.6? im beginning to think its 2.6 cuz GT said it...maybe i got mixed up with my friends tao4...
davioh is offline
Old 07-09-2003, 09:24 PM
  #2853
V12
V12's Avatar
the EVO3īs internal gear ratio is 2.6
V12 is offline
Old 07-09-2003, 09:28 PM
  #2854
davioh's Avatar
damn! i havto regear everything!
davioh is offline
Old 07-10-2003, 07:57 AM
  #2855
izzyracer's Avatar
Trader Rating: 27 (100%+)
Default BUilding EVO 3 S
For you who has built the Surikarn Edition. Did you guys had a hard time inserting the shaft thru the small bevel gears, or is it just me? It was so super tight I was afraid I would bend the shaft or warp something, It worked out fine at the end but it would probably difficult to get it out during rebuild. I'm just curious because I don't remember having difficulty inserting the shaft with the original EVO 3. I also wonder if this is intentional to help the one way from stripping.
izzyracer is offline
Old 07-10-2003, 08:46 AM
  #2856
Fully Hopped's Avatar
Default Re: BUilding EVO 3 S
I didn' have any problems with it. It went in with ease. Its kinda strange that yours was a tight fit.
Fully Hopped is offline
Old 07-10-2003, 09:24 AM
  #2857
izzyracer's Avatar
Default Re: Re: BUilding EVO 3 S
Hmmm, I even tried all other small bevel gears thinking there is something wrong with molding. I think this is a positive thing, keeping the small gears from moving, but it is just weired specially knowing that mine might be an exception.
Old 07-10-2003, 09:35 AM
  #2858
Intelligentsia's Avatar
How about the part where you slide the aluminum gear holder onto the shaft. Is that also supposed to go on super tight?
Intelligentsia is offline
Old 07-10-2003, 09:46 AM
  #2859
If your talking about this part of the kit, everything went on smooth for me.
Old 07-10-2003, 10:14 AM
  #2860
That part slid right onto the shaft smoothly for you?
Old 07-10-2003, 10:30 AM
  #2861
Yeah. It slid on smooth, didn't have to jam it on.
Old 07-10-2003, 10:39 AM
  #2862
OK, thanks
Old 07-10-2003, 10:58 AM
  #2863
The bevil gears on my car were a very tight fit on the propshaft, ooo eerrrr misses. Rick
Rick Draper is online now
Old 07-10-2003, 04:35 PM
  #2864
racer's Avatar
same here, it was tough inserting the drive shaft through the bevel gear.
the side notes does mention to insert and remove the bevel gear 2-3 times. my guess is to work in the gear so it is easier for removal or have the bevel gear sitting on the drive shaft at a correct position so the gear won't slide off and jam the one way.
my .02 cents...
racer is offline
Old 07-10-2003, 04:41 PM
  #2865
izzyracer's Avatar
my .02 cents...
I'm going to check on that side note. But I ended up doing that anyway trying to make sure it works. I'm just glad I'm not alone. Thanks!
