Tamiya TB-Evolution III
#2656
Originally posted by PizzaDude
Guys,
Don't you get grip and stability mixed up.
The outer hole makes the car stabile, and more predictable.
The inner hole (due to leverage) gives more grip.
Shocks lay-down seems to give more side-bite and feesl as if the car is more direct.
but trough long corners a standup will work better.
Also standup keeps up the speed (momentum) through the corners.
Pizza
Guys,
Pizza
i've just been reading the book trying to help out trf man , and i've learnt alot myself tonite. but in terms of grip, is what i've said tonite correct?
i figured that moving it in on the a-arm would make it more stand up therefore giving less grip,more corner speed. but what your saying is that leverage has more effect than the angle of the shock.correct?
#2657
What grease does everyone use to run the gears in in there Surikarn evo 3? I have built mine but am not happy at all with how tight the transmission is, its far tighter than my other evo 3 was when i first built that. Rick
#2658
Rick go to the local bicycle store and fing a dry lube for chains.
It brushes on and dries and gives a very free drivetrain and with lube to quiet the gear mesh, and still rolls very free.
I use White lightning here in the States. I have seen a product fron Castrol that is the same that you should be able to find in the UK. I stay entirely away from any grease type lube as it is too " Sticky "
#2659
I have seen that mentioned as what TC3 drivers use but i wondered if you used any graphite based greases to run the gears in on the bench before you clean the gears off and use the white lightening? Rick
#2660
When I built the car the first time I used of all things toothpaste and 3v on a 540 motor and let it run for 2-3 hours.
Since then I haven't found the need to do this and have been able to keep the car very free.
The 2 cars I have seen better than mine was Taka at Tamiya America he is R&D for them and Rod Canare's car both of them have the Acer bearings in them and roll forever I know Rod does a little shimming on the diffs also. How much is by feel I am sure as all the cars are slightly different.
#2661
I would only shim if necessary. It's all a matter of trial and error. and sometimes shimming will cause excess binding. For the most part, I try to do as little shiming as necessary and make sure that the main shaft is as straight as possible (replacements are only like 5 bucks) and that the pinion gears within the gearboxes spin perfectly round and do not wobble (again, these are pretty cheap). Prior to the Reedy Race, I used White Lightning and sprayed it on the bevel and pinion gears. It helps quit a bit and you do not get any "stiction" (I think this was coined by Difuser) caused by using grease for lubrication. Lately, I've been spraying my gears with Sailkote (it's basically spray on PFTE). It lubricates the same and is not as waxy as white lightning.
Here's some info on Sailkote:
http://www.mclube.com/frames/sailkote/index.html
#2662
gt milenko.wot u r saying is very interesting[i also have the xxx main set up book].wen i was testing upright shocks gave more overall grip than layed down.
but iam running on polished wooden floor indoors so maybe it give it a bit more stabillity and i 4ort it was grip?
difference between stabillity and grip anyone?
#2663
#2664
My pinion gears in my new Surikarn evo 3 float up and down in the gearbox's as do everyone elses i know of with evo 3's. Thanks for the tips difuser i will strip it down tomorrow and put some tooth paste on the gears then run it in! Rick
#2667
Originally posted by Difuser
Rod did you find it at West Marine??
I will have to try it, it sounds like it is a touch better than the WL.
By the way where did you find the spray on WL
I have only found it in the liquid form and using it with a Toothbrush it is a pita
I found the spray on WL at my local cycle shop. I've heard that the brush on type is more waxy but I haven't tried the brush on type yet. I guess you can attribute my purchase of the spray on type to laziness Put it down and spray it baby! hehe.
Oh snap, I see Fangio...what's up Tom, how are things in Texass? Man, we're missing you guys out here We had the LA Adventure 3 thing going on this Sunday and it was a blast!
#2668
see you there.
#2669
anybody know where i can get a spool for my evo III?
