Old 06-17-2003, 02:23 AM   #2551
Trader Rating: 17 (100%+)
Send a message via AIM to AQuionIV Send a message via Yahoo to AQuionIV
Just rebuilt my diff.. Took all the gunk out, feels a little better.. but not as good as I want it to be.. I used to own a TC3.. Is my diff supposed to be as smooth as that one?? anyone>?
AQuionIV is offline   Reply With Quote
Old 06-17-2003, 02:23 AM   #2552
GTMilenko's Avatar
i use as little ball diff grease as i posibly can. and when i rebuild i soak and clean all the non-plastic parts in actone. is the team AE ball diff grease too, seems smoother
GTMilenko is offline   Reply With Quote
Old 06-17-2003, 02:23 AM   #2553
davioh's Avatar
check the joints if they hav stripped...i hav always had that problem and after like 5 times makin' the diff it is p-e-r fect!
davioh is offline   Reply With Quote
Old 06-17-2003, 02:25 AM   #2554
GTMilenko's Avatar
i think the thrust bearing are a little crunchy.
Old 06-17-2003, 02:26 AM   #2555
davioh's Avatar
aiy! i called up my LHS and they said that the 3mm chassis will be here in like 2 weeks and probably the white diff joints as well! do the square aluminium upper deck holder do much?
Old 06-17-2003, 02:51 AM   #2556
hahahah.. yay! My diffs free'd up quite a lot. I ran my Body reamer through the holes a little, took out most of the binding. I'm using the silicone greast that came w/ the 1way from my old TC3.. is that ok? Sitll not as loose as I want it, but much much batter now than earlier=)
Old 06-17-2003, 06:36 AM   #2557
Aluma's Avatar
well, I've always used associated stealth grease on the rings/balls of the diff, bearing/bushing oil drops on the inner bushings, and mugen super grease(super thick stuff) on the caged outter balls. makes it very smooth, and no more crunchy.
Aluma is offline   Reply With Quote
Old 06-17-2003, 07:04 AM   #2558
davioh's Avatar
wahh so many steps! all i do is put ball diff grease on the plates and on each individual ball. then i give it a spin and afterwards i drop in some royal oil (dunno why but it works for me) and it's much better than before! also maybe try oiling the berrings...i find that helpfull too
Old 06-17-2003, 07:54 AM   #2559
SAT
Hello,
Iīve one problem and hope anyone of you can help me.
since last week, my rear balldiff works not good. After maximum 5 runs(Batteries) the teeth of the little gear wheel are broken. Weīve made much sings, that the diff is sitting in the middle of the gearbox anytime. But it all donīt helpīs. During one race, Iīve lost two of this gear wheels, because they were uncommen, after 3 runs.
SAT is offline   Reply With Quote
Old 06-17-2003, 08:53 AM   #2560
davioh's Avatar
sometimes the gear box cover is loose...check that the screws are on tight and if stripped gearbox...get new ones or get bigger screws
Old 06-17-2003, 08:59 AM   #2561
davioh's Avatar
i was wondering if the square aluminium upperdeck holders are any different from the tamiya ones. thanx
Old 06-17-2003, 09:14 AM   #2562
To minimise stripping of the gear box screw holes, use machine thread screws. The wood screws tamiya supply are not really suitable for a high stress area like the gear box. This won't be an issue with the Evo3-S since it comes with machine thread titanium screws.
Awesomatix A700L (building) | VBC Wildfire D07 (building) |416WE/X Smokem | Hobbywing 120A v2.1 | Sanwa M11x
itchynads is offline   Reply With Quote
Old 06-17-2003, 09:59 AM   #2563
Got my nice surikarn edition evo 3 yesterday and have spent the last day building it, the new chassis is so much stiffer than the old one! Rick
Rick Draper is offline   Reply With Quote
Old 06-17-2003, 11:41 AM   #2564
R/C Tech Charter Subscriber
Default evo 3 s
pics of the evo if anyone is interested:
http://uk.msnusers.com/KEITHANDER/otherstuff.msnw
keithander is offline   Reply With Quote
Old 06-17-2003, 11:44 AM   #2565
Default filing chassis
Tony - what did you use to file the battery slots down - I'm a bit concerned I haven't taken enough off! Do you think it makes a lot of difference?
thanks,
Keith.
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 05:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 08:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 11:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 08:49 AM
SEO by vBSEO 3.5.0
