Old 06-07-2003, 09:52 AM   #2446
jedi's Avatar
Default dsrbltoys
How do cut them out? Do you remove the whle round back portion of the gear or do you cut them to contour to each tooth? Thanks
jedi is offline   Reply With Quote
Old 06-07-2003, 11:38 PM   #2447
GTMilenko's Avatar
Originally posted by dsrbltoys
GT
Do not use any shims in this area. If you do you WILL strip, or even chip the teeth on one of the gears. When you do this you loose the horizontal mesh between the ring and pinion gears. Meaning the diff can slide out of the case that much more. I actually used sand paper (to level the case top and botton faces) to allow this cover to sit more flat and tighter on the case and shock tower. My chassis is just as free as any other EVO III out there, no binding in this area. Well ok peter's might be better only cause of his alloy cases.
This is the problem a lot of people have had with thier EVO III's. The best solution I heard, is the cutting of the backing on the pinion (crown) gear for the diff. When you hit something the shaft moves forward, and the backing of the pinion gear pushes on the ring (diff) gear, and separates the gear mesh (if you are on the throttle, the shaft is still trying to rotate, and chips a tooth). The solution I and many others have used, is to use a sharp pair of side cutters, and remove all backing behind the teeth on the gear, then re-shim the diff with the 10mm shims now available from Tamiya. Just to make sure, when looking at the pinion gear from the front you see the teeth, but the back of the gear is round, cut the round part away! Do this only on the front gear though.
Kevin
thanks , i'll do that. i noticed when i check the diff by holding the spur and one front wheel ,i turn the other wheel and it will click easy even without the spacers i talked about.
GTMilenko is offline   Reply With Quote
Old 06-08-2003, 06:56 AM   #2448
Default Servo saver
has anyone experienced a little play on the servo saver? what other servo savers are available that can prevent the play? I already used the white and black servo savers but there's still a little play.
Thanks.
Explorer
Explorer is offline   Reply With Quote
Old 06-08-2003, 06:59 AM   #2449
davioh's Avatar
yea a lot of ppl including me has had that problem...i guess u gotta keep switching?
davioh is offline   Reply With Quote
Old 06-08-2003, 06:59 AM   #2450
davioh's Avatar
i saw the surikarn edition for sale today...didn't check the price though...i saw the box only too
Old 06-08-2003, 12:16 PM   #2451
racer's Avatar
does anyone know if the Surikarn Edition come with wheel spacers?
Thanks in advance!
racer is offline   Reply With Quote
Old 06-08-2003, 03:00 PM   #2452
Default Re: Servo saver
Thanks.
Explorer
The first thing I did when I recived the car was buying a new servo saver.. I think the original one is pure crap. Anyway, I bought a Kimbrough servo saver, it works perfectly!
Just watchout that you use the top middle hole if you install it.
Yokio is offline   Reply With Quote
Old 06-08-2003, 03:05 PM   #2453
Default Icelandic nats round 2
The second round of the Icelandic nats was held this weekend in grate weather although we got a little bit of rain in the first A finals.
I was TQ after qualifying after setting a record lap time. I then ended up second after the first final, first in the second final and again first in the third and last final! So I won the second round of the Icelandic nats with my Tamiya TB Evolution III.
Not a bad weekend for me and my record braking Tamiya.
I just wanted to thank you guys with my "three questions" last week! Thanks guys!
Regards,
Andri Orn Vidisson
Old 06-08-2003, 04:21 PM   #2454
Aluma's Avatar
hey guys, i was looking through rcmodel.com's site and found that they have titanium bones/shafts for the evo 3... you think they'd make a big impact on performance?
I was also thinking of maybe getting Acer's nitride ceramic bearing kit for my evo3... wonder if they'd be better than the ones it has now... hmmmm
Aluma is offline   Reply With Quote
Old 06-08-2003, 04:21 PM   #2455
tomdav's Avatar
Trader Rating: 41 (100%+)
Default Surikarn Limited Edition
http://shopping.rcmodel.com.hk/
They have some nice pics of the box and the red bits.
Tom
tomdav is offline   Reply With Quote
Old 06-08-2003, 04:51 PM   #2456
GTMilenko's Avatar
could some please give me the part number for the worlds sway bay kit, and also what swaybars come with the kit? thanks
Old 06-08-2003, 09:00 PM   #2457
dynoman007's Avatar
Send a message via MSN to dynoman007 Send a message via Skype™ to dynoman007
Default hello
how much are the square alum gear box halves for the evo 3 ??
dynoman007 is offline   Reply With Quote
Old 06-09-2003, 05:04 AM   #2458
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: hello
David Hit me up I can help you ..but man those things are "very" heavy
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 06-09-2003, 07:04 AM   #2459
Default Re: Re: Servo saver
Thanks Yokio.
Would you happen to know the part number of the Kimbrough servo saver?
Old 06-09-2003, 07:29 AM   #2460
Default Re: Re: Re: Servo saver
Thanks Yokio.
Their website is here: http://www.kimbrough-products.com and the servo savers are here: http://www.kimbrough-products.com/servosvr.htm I bought one that looks just like the one on the picture on the servo saver page - the mid-size.
Hope this helps.
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
