Old 06-04-2003, 12:22 AM   #2416
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally posted by Difuser
DB the body isn't too bad but the nose is waaaaaay out front from the car.
By the way are you going to race the past champs this year?
Rumor is Mod FWD
nope, maybe next year
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 06-04-2003, 09:12 AM   #2417
peter_robinson's Avatar
Trader Rating: 21 (100%+)
Originally posted by TRF-Powered
Are you talking about the blue aluminum gear box for Evo3 from Sqaure?
I saw it on square's website. Did you get it through rainbowten? or other source? Please share. Thanks!
yes these are the square gearboxes, and i did get them from rainbow ten. you can see them on my car in the pics in past posts, i jus chose to get the ilver colored ones.
For orders or inquiries, email sales@rc-trim.com. Follow RC-Trim on Twitter and Facebook
RC-Trim | Serpent USA | On-Point | Trinity | Revtech | ORCA | BSR | KO Propo | PT RC Racing Oil | WTRC | rcpitwhores.com
peter_robinson is offline   Reply With Quote
Old 06-04-2003, 12:34 PM   #2418
Trader Rating: 17 (100%+)
Send a message via AIM to AQuionIV Send a message via Yahoo to AQuionIV
Reedy 8x2 motor, LRP V7.1 speedcontrol: Using 96 spur, and 34 pinion.. in everyone's opinion, who thinks I'll fry my car up before the end of a 5 minute heat?
AQuionIV is offline   Reply With Quote
Old 06-04-2003, 12:40 PM   #2419
Intelligentsia's Avatar
I don't know which will happen first. You either fry your motor or your batteries dump.
Intelligentsia is offline   Reply With Quote
Old 06-04-2003, 01:25 PM   #2420
eeyan's Avatar
Send a message via AIM to eeyan Send a message via Yahoo to eeyan
Hehehe... I'll bet with that crazy HORSEPOWER... you'll bent a hinge pin or break an arm first when you slam on to the outside boards on the sweepers... ouch! Poor evo...
Just kidding!
TAOB Racing Team (1999 - 2011)
eeyan is offline   Reply With Quote
Old 06-04-2003, 04:29 PM   #2421
lol.. eeyan..
I'll make sure when I slam, I'll take you down with me=P.. heheh.. jk. I figured, if Rod was gonna run a Krypton 8x2, and gear it 31/96, and the guy at the Reedy Race told me that Kryptons had 2 gear down 2 to 3 teeth, I'd be fine with a 34/96 setup. Then again, I can see Rod my like going through motors a lot=)
Old 06-04-2003, 06:25 PM   #2422
defMondo's Avatar
I think if your an incredibly smooth driver you can get away with ludricous gearing, but if you aren't as smooth and are forever getting on and off the throttle then I'm prety sure something is going to let go before the 5minutes are up.
Obviously this all depends on the track I have seen an evo with a 8x2 geared at 4:1 run extremely well around a velodrome.
Tony
defMondo is offline   Reply With Quote
Old 06-04-2003, 08:30 PM   #2423
Tony
That would not have been My Evo3 going around the velodrome would it??? Don't worry I'll be back.....
Awesomatix A700L (building) | VBC Wildfire D07 (building) |416WE/X Smokem | Hobbywing 120A v2.1 | Sanwa M11x
itchynads is offline   Reply With Quote
Old 06-04-2003, 10:41 PM   #2424
defMondo's Avatar
Maybe..
Old 06-04-2003, 11:33 PM   #2425
j0n0's Avatar
Send a message via ICQ to j0n0
Mine now...
damn exams...i want to race!!
j0n0 is offline   Reply With Quote
Old 06-05-2003, 01:34 AM   #2426
Originally posted by j0n0
Mine now...
You have NO excuses for not going fast now Jono!
Old 06-05-2003, 08:20 AM   #2427
Arrow Three questions...
I've got three questions for you guys that I need a really quick reply on if you can help me. The Icelandic nats round 2 are this comming Saturday.
1. I'm having a really hard time holding my battery pack in the car?!?! It seems like the batterybrace is barly touching the batteries and there for they aren't really holding down the pack..? Any ideas??
2. Have any of you guys changed your cars from 64 pitch gears to 48 pitch? Do I only have to buy a spurgear to do that (+ a pinion)? And if so what kind of spurgear?
3. Where do you guys fit a transpondermount? I just bought a TA04 transpondermount, and I'm not really finding a good spot for it.
Thanks a lot!! I'm all alone up here, the only Tamiya guy. So I have no back up... Help!
Yokio is offline   Reply With Quote
Old 06-05-2003, 08:28 AM   #2428
alan1467's Avatar
Default Re: Three questions...
Here are some answers :-
1 If you cut 4mm off the top of the battery posts and the screw the bolt/post in this makes the battery brace tight.
2 I still use the gears supplied with the kit, but any gear fits (Robson Kimbro etc )
3 I've made a carbon bracket that is stuck on the top of the servo
Hope this helps
Alan
Tamiya TRF - Tekin
F104W Pro - CRC Gen X10
alan1467 is offline   Reply With Quote
Old 06-05-2003, 08:33 AM   #2429
jedi's Avatar
Default Yokio
1.) Screw two Tamiya ball cups on to the two hole on the left side of your chassis where the battery holder for the stick cells are. Use the stockd countersunk screws. No more battery flying out in a crash.
2.) All you have to buy is the spur and pinion. I know a 72 tooth or smaller spur would fit or maybe a 74 tooth at the biggest.
3.) Just use a long body clip and mount the transponder between the two front body posts on top of the bumper. Or you could buy the associated lexan body mount and attach it to your servo via double sided tape.
jedi is offline   Reply With Quote
Old 06-05-2003, 08:42 AM   #2430
1. don't use the battery tray, use strapping tpae to hold the battery in the slots.
2. this one is easy, buy yourself a 70, or 72 tooth spur (or both) and then just figure out with a calculator which pinion you should run.
3. since you are gonna be using tape to hold the battery in, cut the carbon battery strap in half, and servo tape this to the top of the servo, and use this to mount your transponder (you may have seen this done by surikarn)
peter
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 05:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 08:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 11:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 08:49 AM
SEO by vBSEO 3.5.0
