Old 05-27-2003, 07:28 AM   #2266
GT another part we found with the spools down at Reedy is that the front has the same shake due to a slight bind in the CVD as it rotates over center. The shake you have will come back but only at lock.
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 05-27-2003, 07:40 AM   #2267
rtypec's Avatar
Hey Dan! What's up man? I'm alive hehe. Took a "nap" yesterday afternoon and woke up at 5am this morning
Good job putting so many Evo3's in the Amain and thank you for the spool. The spool looks bomb proof and it's a keeper. I didn't have time to shim mine up so I left it out and ran David Beale's spool instead. My car needed extra weight so why not add the extra weight to something that needs to be as light as possible and rotates at high speed hahaha. Oh well.
In regards to the front wheels vibrating at full lock, it only seems to occur when we run spools. The vibration is really bad when the wheels are off the ground but seem to mellow out a tad when they're on the track. I look forward to taking out the spool and running a one-way again but I will sure miss the brakes!
Also, the setup that I used was exactly the same one that's been posted here for the last few months. The only changes being made is the decrease in down travel to 5mm instead of 6mm and putting on the front yellow sway bar when the temperature went up and whenever I ran 3-run tires (in the last main I was running 3 Left Rear Tires and one Left Front, woops). Even though my driving looked ragged, it was all under control, sort of ; in corners, I let the car enter wherever it wanted and reacted to get the best speed coming out so that I can setup for the next.
All in all it was great fun and the Evo3 was a blast to drive. I look forward to seeing what kind of laptimes I could do if I were running some 1.18-1.19+ cells at the Tamiya track with its huge straights (as if a 13.9sec lap isn't good enough ).
rtypec is offline   Reply With Quote
Old 05-27-2003, 07:56 AM   #2268
peter_robinson's Avatar
Trader Rating: 21 (100%+)
Default OPEN MOD REEDY SETUP
this is how i ran my car down at the reedy race this weekend. i placed 4th in the B-main, on spot up from my 5th in the B last year... at this rate i will be the champ in 2016!
Front:
Oil- 50wt
piston- 2 hole
2 black o-rings in bladder
spring- associated blue
shock mount- all the way out on tower/all the way out on the arm
camber- neg. 2 degrees
camber link- top middle hole on tower
swaybar- yellow
droop- 24.9mm (measured from the top of axle to setup board.
wheelbase- 2mm forward from stock
blocks level (A block was used front and back)
ride height- 5mm
Rear:
oil- 50wt
piston- 2 hole
nothing in bladder
spring- associated silver
shock mount- one in on tower/all the way out on arm
camber- neg. 1.5
swaybar- yellow
droop- 25.1mm
wheelbase- stock
blocks level (A block was used front and rear)
ride height- 5mm
a protoype spool was used in the front, and the new delrin diff halves from tamiya were used in the rear.
the tires were the spec take-off cs-27
and i ran a reedy KR 10x2 geard at 32/100 for a final drive of 8.1
i also used a protoform stratus 2.0 body.
pete
For orders or inquiries, email sales@rc-trim.com. Follow RC-Trim on Twitter and Facebook
RC-Trim | Serpent USA | On-Point | Trinity | Revtech | ORCA | BSR | KO Propo | PT RC Racing Oil | WTRC | rcpitwhores.com
peter_robinson is offline   Reply With Quote
Old 05-27-2003, 08:12 AM   #2269
Great job Rod you drove great and represented Tamiya well.
how are you measuring your droop?
Mine and Pete's cars were the same except front camber link I went back to the inner upper as the front dug to hard in the sweeper and scrubbed speed. The upper rear tower was all the way out also.
Old 05-27-2003, 08:16 AM   #2270
rtypec's Avatar
The way I measure droop isn't exactly the best but it kinda works (I need a hudy ride height gauge with 1/2mm increments). I take the wheels off the car and measure the lowest part of the suspension arm to the setup board with a ride height gauge. I know it isn't the most ideal but atleast I don't have to try and hold calipers still while I take a reading off the top of the axles. Too much redbull and coffee can do that
Old 05-27-2003, 08:50 AM   #2271
Thumbs up thanxs
thank you for the setup .
al jones is offline   Reply With Quote
Old 05-27-2003, 08:59 AM   #2272
I never could figure out your #'s sound like you are running 2mm od droop or so. Not much uptravel?
Old 05-27-2003, 09:15 AM   #2273
rtypec's Avatar
For me, that's a lot of downtravel/droop. I usually run a lot less than that at Socal. If you thought I was running very little, David Berger was running even less
Old 05-27-2003, 09:52 AM   #2274
Intelligentsia's Avatar
Hey rtypec,
Will you be at the Tamiya race? If so what is a decent setup since we must run all Tamiya?
Intelligentsia is offline   Reply With Quote
Old 05-27-2003, 09:53 AM   #2275
rtypec's Avatar
Yes, I'll be at the Tamiya Race in a couple of weeks. As for setup, let me try a few things next weekend and I'll post a setup here.
Old 05-27-2003, 10:01 AM   #2276
Sounds like a plan. I will be out there this Saturday also trying a few things.
Old 05-27-2003, 12:57 PM   #2277
question what do the black O rings or the red foams do for the shocks is their a big difference in using then and not using them?
sportracer is offline   Reply With Quote
Old 05-27-2003, 06:37 PM   #2278
Aurra Sing's Avatar
When you remove the urethane spacer, you decrease the amount of "pack" in the shock. Correct me if i'm wrong.
The track I raced at a few weeks ago was moderately bumpy. I removed the urethane spacers in the shocks of my 414M and the car wasn't bouncing around in the corners as much. It really does make a difference!
Aurra Sing is offline   Reply With Quote
Old 05-27-2003, 06:38 PM   #2279
Aurra Sing's Avatar
I do not know what the difference is between using black o-rings and the urethane spacer. Can someone clarify this?
Old 05-27-2003, 06:39 PM   #2280
Aurra Sing's Avatar
414M for life!
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
