Old 05-24-2003, 06:40 AM   #2251
davioh's Avatar
would WD 40 work to free the berings?
davioh is offline   Reply With Quote
Old 05-24-2003, 10:27 PM   #2252
rtypec's Avatar
Default Re: Just got my kit
Originally posted by Bubbasteponit
Can someone please hit me with a good high traction asphalt set for very warm to hot weather.
Try this setup. It works well for the conditions that you specified. Also, Charlie, if you see this before tomorrow, here it is.
http://www.rctech.net/forum/attachme...&postid=371869
Please change the rear downtravel measurement from 5mm to 6mm. The rear was a bit too lively off power when it was at 5mm.
Also, the steering ball ends are on the inner-most hole on C1 and C2 for better ackerman.
One last thing, if the car has too much steering going in, mid, and exiting a turn then go with a yellow sway bar up front.
rtypec is offline   Reply With Quote
Old 05-25-2003, 05:35 AM   #2253
VenomWorldOrder's Avatar
Default Re: before getting kit
Originally posted by VenomWorldOrder
i'm a electric newbie who has had a 2 year run in nitro. what option parts do i need for the surikarn edition evo 3?
-are there different caster blocks which i can purchase what are the part numbers?(front and rear blocks ) (part numbers please)
-also what gears and motor pinion gears do i have to buy for small/medium/large/extra large tracks?? (part numbers please)
-what are the part numbers for the option springs and swaybars?
i couldn't find any of it in the tamiya website
Anyone?
VenomWorldOrder is offline   Reply With Quote
Old 05-25-2003, 06:04 AM   #2254
defMondo's Avatar
I haven't seen any different caster blocs.
The car will come with tamiya 0.4 pitch spurs (EVO3 had 3 x 96tooth and 3 x 90 tooth) it also comes with a 34 tooth 0.4 pitch pinion. You can stick with the Tamiya pinions all the way from 34 up to 53 (maybe a little higher) or you can get a 71 tooth 48 pitch spur and replace the 0.4 pitch ones with it, then just use standard 48 pitch pinions.
The surikarn kit should be similar to the EVO3 and it will come with a full compliment of sway bars ( 3 fronts SMH and 3 rears SMH). It should come with yellow springs as well. The springs are the normal Tamiya touring car springs which you can buy in packs of 4 pairs and will include (soft to hard) 2xRed,2xYellow, 2xBlue,2xWhite.
You should be able to get the numbers from Tamiya website for the pininons and the spring sets. They are just standard parts and not really specific to the the EVO3.
Hope this helps.
Tony
defMondo is offline   Reply With Quote
Old 05-25-2003, 11:39 PM   #2255
WC
WC's Avatar
Trader Rating: 28 (100%+)
...what option parts do i need for the surikarn edition evo 3?
Are these kits actually shipping yet?
If not... that'll explain why you haven't got the car's manual and the list of usable option & spare parts on the back.
WC is offline   Reply With Quote
Old 05-25-2003, 11:52 PM   #2256
defMondo's Avatar
June 12th is the date that R10 have for the Surikarn edition.
Tony
Old 05-26-2003, 09:52 AM   #2257
Neil Rabara's Avatar
Great job to Rod Canare for his win in the Open class spec at the Reedy TC Race of Champions.
Neil Rabara is offline   Reply With Quote
Old 05-26-2003, 03:02 PM   #2258
rtypec's Avatar
Thanks Neil, now that I've been awake for a couple of hours, I think I'll eat and go take a nap again
Also, the setup that I used is exactly the same one that I posted here a page or so ago.
Old 05-26-2003, 10:07 PM   #2259
rough512's Avatar
Originally posted by GTMilenko
it only does it bad when turning and at low speeds. i drove it round it circles real slow and you can see the inside wheel pulling in and out.
Not much you can do about it. This occurs on my EVO2 too.
With the radio turned off, try turning the wheels to full-lock one side. Now look at the inside wheel.
The rod (linking the steering arm and the knuckle arm) is almost straight inline with the knuckle arm (the knuckle arm will not turn anymore, even if you twist the servo further. You will only pull apart the link if you try).
The knuckle arm is at its maximum throw, and at this point the servo cannot do anything to prevent that wiggling of the tire.. The only way you can prevent the inside tyre from wiggling is to reduce your steering throw so the steering arm can get some leverage on the knuckle arm, or to try fitting in some other knuckle arms.
Hope the above is clear. Difficult describing it in words...
rough512 is offline   Reply With Quote
Old 05-26-2003, 10:21 PM   #2260
Steevo's Avatar
Right again rough
I noticed this on My Evo II as well. I was a little concerned at first but I have not noticed it to be any real detrement to the performance. My car still kicks Ass
Not much you can do to stop it as far as I can see
Steevo
Steevo is offline   Reply With Quote
Old 05-27-2003, 12:14 AM   #2261
GTMilenko's Avatar
i think i understand, and it makes seens, i think, lol
i took it out for a test and its running like a dream again, before it was oversteering hard and shaking heaps when turning left but not right. but with the whole new drivetrain its prefect again.
but still vaibraates on the stand at low speed turning hard.
thanx for the word up stevo!
GTMilenko is offline   Reply With Quote
Old 05-27-2003, 12:22 AM   #2262
WC
WC's Avatar
TBe3's green driveshaft, there's 2 holes towards the rear end.
Spurgear sits in 1 of those holes...
what's the other one for??
(just wondering if I'm missing something...)
Old 05-27-2003, 12:35 AM   #2263
GTMilenko's Avatar
If you use a TB01 spur gear, the pin goes in the other hole.
i think they are ok gears, pretty soft, but it must save weight on the driveline, cause you don't use the spurgear holder.
Old 05-27-2003, 06:48 AM   #2264
Thumbs up evo 3 carpet setup(foams)
can some one help me with setup for foam tires on carpet thanks
al jones is offline   Reply With Quote
Old 05-27-2003, 06:54 AM   #2265
alan1467's Avatar
Default Re: evo 3 carpet setup(foams)
Hope this helps
I normally run stock monster geared at 33/96
Front
Tamiya Blue
Yellow Roll bar
Centre top shock hole
Outer bottom hole
Frt 2 hole piston 60W Associated
Upper arm mount top inner (Nearest Gearbox)
Jaco Double Purple
Ride 5.5mm
Spacers under mounting blocks Frt 0 Rear 1mm (Need to machine top off mounting)
1.5' negitive camber
4' Caster
2mm Droop
0' toe in
Rear
Tamiya Yellow
NO Roll bar
Outer bottom hole
Rear 2 hole piston 50w Associated
Jaco Purple
Ride 5.0mm
2mm Droop
2' toe in (A Block on rear)
Alan
Tamiya TRF - Tekin
F104W Pro - CRC Gen X10
alan1467 is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
