Old 05-13-2003, 07:18 PM   #2116
GTMilenko's Avatar
yip it get clunky but it gets clunky at about %55-60 of full steering.
GTMilenko is offline   Reply With Quote
Old 05-13-2003, 07:35 PM   #2117
defMondo's Avatar
Do you have to many spacer washers in the one way outdrives?
Is that 55-60% on the radio or the actual wheels on the car?
defMondo is offline   Reply With Quote
Old 05-13-2003, 08:42 PM   #2118
GTMilenko's Avatar
ok, still no luck. i've rebuild all 4 cvds and put the back ones to the front, put "A" blocks all round.
it is alot more clunky at lower rpm, i've got my epa set %100 and my st d/r set to %50, and thats not much steering! and it still clunks and vibrates badly.
the out drive can wobble back and forth a bit in the gear case, could this be it?
Old 05-13-2003, 08:53 PM   #2119
defMondo's Avatar
The outdrive should be able to slide out a little bit, not much, I have 3 shim washers on each of mine and it seems fine.
If it's to loose you could put a small black o ring inside the outdrive cup where the dogbone sits, that will stop it coming out to far, make sure it doesn't bind though.
Make sure that the 2 notches in the cdv sit completely inside the outdrive cup and don't dind as you spin and turn the will with your hands, also as the suspension is compressed because it changes the agles on the cvd relative to the outdrive.
Old 05-13-2003, 09:23 PM   #2120
GTMilenko's Avatar
its seems ok at high rpm now, but still clunks at lower rpm. which is better but still no good, as i don't race at full throttle the whole race. my outdrives don't slid out at all cause its not like the one way, i have a spool(evo 3 diff, but locked).
the dust cover on the bear that goes on the pinion gear of the gear box has come off, could a gritty bearing be causing this?
Old 05-13-2003, 09:37 PM   #2121
defMondo's Avatar
ah a spool, fair enough.
Not sure about the bearing but I doub't it would be the cause though, specially as it only happens while turning.
There is nothing wrong with the wheels, like they are not warped or anything. Does it do it with the wheels on the car.
Old 05-13-2003, 09:57 PM   #2122
GTMilenko's Avatar
it only does it with the wheels on but i'm sure the wheels are fine cause there fine when pointing straight, and i've tried 3 sets of different wheels. i would be sure it had something to do with cvd's but they are fine.
Old 05-13-2003, 10:24 PM   #2123
Try changing the crown or ring gear it would show up as you describe if you have a tooth that is bent or broken I have seen it in mine when I have nuked a 1-way ring gear and also a crown gear
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 05-13-2003, 11:26 PM   #2124
GTMilenko's Avatar
Difuser- tried that just now no luck, it only does it with wheels on so maybe do you think the bearings are worn out and can't handle the spining weight(vibration), i relube them with a very light oil about a moth ago, the oil has probibly all come out and now wearing out, the car is also not as quiet any more. i don't have anyother bearing to try in it, so let me know if u think this could cause the vibration(specially at low rpm).
i've ordered the TB EVOLUTION 3 RACING FULL DRY BEARING SET ULTIMATE from rainbow ten anybody else have these bearings?
i have been negleting my poor son all day cause i've been trying to fix this, and it is better, but still not the high performance machine its ment to be.
Old 05-13-2003, 11:30 PM   #2125
defMondo's Avatar
Those "dry" bearings are ok and are on par with the Tamiya Blue Seal bearings after they have been cleaned and lubricated, except you don't need to do the work.
Tony
Old 05-13-2003, 11:31 PM   #2126
GTMilenko's Avatar
thanx tony, do you think my current bearings could be my problem?
Old 05-13-2003, 11:36 PM   #2127
defMondo's Avatar
It's possible, the quickest way to find out is to swap the front bearings with the rear and see if it's any better, the rear ones don't get as much of a workout.
That will prove if it's the bearings.
Tony
Old 05-14-2003, 02:30 AM   #2128
GTMilenko's Avatar
Tony
that didn't work eithier
it only seems to do it badly when accelerating with the wheels turned from zero, or when slowing to a stop with the wheels turn.
i'm doing all this testing on the car stand by the way.
so the low down is the front wheels in my car are clunking and vibrating when going slow and turning.
Old 05-14-2003, 03:09 AM   #2129
Originally posted by little*oak
alain1467,
Where about's in the UK do you race locally. I am from greatham, Cleveland, and would like to exchange views etc. with other EVOIII owners locally.
Let me know, my email is andrew.haigh@gardline.co.uk drop me a line
Cheers
Dunno where Alain does his racing but i do most of my racing at Ashby , Mark who wrote the radio race car review does all his racing there too.
Im also doing the whole of the Torc series in the stock class which just happens to be at Ashby this sunday.
Xray X1 "16" driven by an idiot, me
weekendracer_uk is offline   Reply With Quote
Old 05-14-2003, 03:16 AM   #2130
alan1467's Avatar
Well I race mostly at Teesside (TRCC) but also I'm doing the Tamiya Eurocup
Alan
Tamiya TRF - Tekin
F104W Pro - CRC Gen X10
alan1467 is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
