Old 01-01-2003, 07:47 PM   #196
Hi all,
I have constructed my TBIII also. However I found that it is quite hard to push the front one-way and rear ball diff into the gear cast. According Tamiya's HP , it seems to be the design which used to hold the two gear firm. But I still hear that it is better to trim the gear cast so that the bearing can be push completely inside. Do you guys experience that and what do you think about. Trim it down or not??
Thanks!
mr4-tc sp is offline   Reply With Quote
Old 01-01-2003, 08:30 PM   #197
Originally posted by mr4-tc sp
Hi all,
Thanks!
I'd guess that if you are going to shave some plastic off, you would have to do a good job of making sure they are even otherwise you could hurt the efficiency of the diffs.
I've found that screwing in the diff covers too tight can actually hurth the smoothness of the driver train. I ended up backing the screws off slightly until the drive train freed up.
itchynads is offline   Reply With Quote
Old 01-01-2003, 10:01 PM   #198
Hi itchynads,
Thanks a lot!
I have already done the same action as you. What I doubt is if I cut off the part, and make the even, would it be smoother than screw back method?
Old 01-02-2003, 12:27 AM   #199
Hi itchynads,
Thanks a lot!
I think its safer to just leave it because if you do shave some off the diff mounts, it might be too loose when the mount wears over time.
Old 01-02-2003, 12:31 AM   #200
Thanks a lot!
In one word, TB EVO III is just a good car!
Old 01-02-2003, 10:43 AM   #201
rayhuang's Avatar
Default Set-up ???????
Hey guys,
My car is on its way!!! I should have it Monday or Tuesday!!! yahooo.
I cannot race it till I put a front diff in it-but that'll just allow me more time to make sure the drivetrain, etc is free and everything perfect!!!
I would like your guys comments on this set-up I am going to start with. I am going to run the car on Ozite carpet on foam tires on a 88' x 50' fast roadcourse. Stock and 19 turn. NO Mod.
Front shocks will be 60 wt. Associated oil with smallest hole piston. Associated yellow spring. Shocks mounted one hole in on tower. No or very thin sway bar. Plaid Jaco tires. Diff very tight.
Camber link second longest possible and as high as possible. Low roll center with zero kick-up and 6 degree castor blocks.
2 degrees toe out, camber set for tire wear. 4mm ride height. Front arms middle wheelbase.
Rear shocks will be 40 wt. oil with smallest hole pistons. Associated purple or copper spring. Shocks leaned in to third hole on tower. No sway bar. Purple tires.
Camber link long and high as possible. 2 degrees toe in. arms in low roll center with zero kick-up or antidive. Arms full forward. 4mm ride height.
I know this is all guess work-but as I have NEVER owned a Tamiya before-maybe you guys know stuff I dont about general set-ups!!!
Old 01-02-2003, 01:04 PM   #202
rayhuang: WOW, you already started thinking the setup for your new car. I rather think about it when I'm in the track. I believe the EVO3 comes with front oneway not diff. I'm getting my car TOMORROW!
smash123 is offline   Reply With Quote
Old 01-02-2003, 02:35 PM   #203
black-knight's Avatar
R/C Tech Charter Subscriber
Default Re: Set-up ???????
Originally posted by rayhuang
Hey guys,
i'd seriously start with box setup, and see how the car behaves...the kit comes with medium springs (yellow), the first change for carpet that i'd probably make is a move to harder springs (blue)
Black-Knight - None shall pass!
www.nbhc.com.au - www.facebook.com/smaracing
black-knight is offline   Reply With Quote
Old 01-02-2003, 07:21 PM   #204
rayhuang's Avatar
between owning my own business, owning my own track, raising my daughter, taking care of my house, wife, three cats and running my very small, but fun RC racing business, I dont know where I find the time to think up all this crap!!!
You gus are right-I should just set-it up as the book says, but I love to overthink everything!!!
Hmmm...maybe thats why I am always so stresed out..... hehehe!!
Old 01-03-2003, 12:53 AM   #205
fabolousRC's Avatar
Send a message via AIM to fabolousRC Send a message via Yahoo to fabolousRC
If I only have the extra $$$ to get one from your shipment, ray...I would love to join you in your fun. I got too many regular TB01 in my stable that I would love to get rid of right now...I wish I can...I wish I can...I wish I can...
Tamiya DB01 Durga\Kyosho Lazer ZX-5\Kyosho Turbo Optima
Lex Tyler Paints \ Norcal Hobbies \ Bay Area Peninsula R/C Club
fabolousRC is offline   Reply With Quote
Old 01-03-2003, 08:54 AM   #206
madjack's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to madjack
Default EVO3 Drive train
Has anyone else found the need to break-in the drive train on the E3?
My car seemed to have a rough spot that would hang up when rotating the spur.
http://groups.yahoo.com/group/tamiyatrf/
madjack is offline   Reply With Quote
Old 01-03-2003, 03:32 PM   #207
Default Re: EVO3 Drive train
yes i found a similar issue...
Old 01-03-2003, 03:36 PM   #208
No shaft for me ill stick with my 414MII
Chris@WeaponR is offline   Reply With Quote
Old 01-03-2003, 04:01 PM   #209
madjack's Avatar
Ah...I too ran the M. You might be suprised by the peformance of the EVO3...time will tell I guess.
As for real cars...tune Germans by chance, looking for some help with an S6
Old 01-03-2003, 04:11 PM   #210
KINGZJ's Avatar
Send a message via AIM to KINGZJ
I want to know how much this thing weights.
I don't want to buy a tamiya tank.
Someone please respond.
KINGZJ is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
