Old 04-30-2003, 06:40 AM   #1966
TTT=to the top
sportracer is offline   Reply With Quote
Old 04-30-2003, 07:51 AM   #1967
davioh's Avatar
oo i c
davioh is offline   Reply With Quote
Old 04-30-2003, 08:08 AM   #1968
izzyracer's Avatar
Trader Rating: 27 (100%+)
I decided to rebuild my EVO3 last night and found out all of my suspension hinge pins are slightly bent, keeping the arms from moving smoothly and messing up my toe adjustments. This also happened on my 04R. Does Tamiya sell hardenend pins?
Izzy
izzyracer is offline   Reply With Quote
Old 04-30-2003, 11:11 AM   #1969
rtypec's Avatar
Hey izzy,
It is always a good idea to check your hinge pins whenever your car feels weird after setting it up. What I mean is that you can set your droops, ride heights, cambers, toes...etc but if your car fells funky on track, almost like its tweaked, then you've probably got a bent hinge pin or suspension block.
As for a harder material, I asked about that and they don't have anything in stock that would work. Perhap lunsford makes a set that can be modifed for use in Tamiya cars but I doubt it.
Also, has anybody been having problems with the 12x8mm bearing shields popping off the crown gear? Anybody have problems with the bearing shifting on the crown gear causing a roachy drivetrain? Do you think rubber sealed bearings would solve this? TIA.
One more thing:
davioh, I understand and share your excitement about the Evo3 but to save some face, here's is something futureal posted in another thread and I hope that you don't take it the wrong way.
"We specifically warned you to stop posting junk and you have continued. Yesterday I saw you respond to about 9 or 10 different threads in the Paint forum, with every one of your responses being one line or less.
DON'T respond to threads with things like "me too" or "" or "wow really?" and so on. And don't tell me that you've stopped doing that, because you posted about 40 times yesterday across half the forums.
Part of the appeal of this site is that people tend to have real discussions and act a bit more mature than other places. This isn't meant to be a chat forum like RCCA (www.caraction.com). I'm not trying to be harsh, be we HAVE warned you, and you choose to ignore it.
edit: In fact, in this forum alone, you responded to the last 7 or 8 threads, with one of your responses be nothing more than "yeah." and most of the others being something like "Yea, do what he said." Those are posts that don't need to be made, they just clutter things up. Only respond to a thread if you have something to ADD to the discussion, not just for the sake of posting. "
rtypec is offline   Reply With Quote
Old 04-30-2003, 11:18 AM   #1970
Rod, I had the same bearing problem. I found my bearing sheilds spinning on my driveshaft. I had already purchased the rubber sealed kit but hadn't installed it. I replaced those two bearings with the rubber sealed and so far no problems.
DOTMAN is offline   Reply With Quote
Old 04-30-2003, 11:56 AM   #1971
rtypec's Avatar
Thanks Dotman. I too have picked up a set of 12x8mm rubber bearings from Tamiya and will install them tonight. As for the bearing itself shifting around on the crown gear, any problems with that?
Old 04-30-2003, 12:00 PM   #1972
What do you mean by shifting around?
Old 04-30-2003, 12:08 PM   #1973
rtypec,
Did you have that problem with your ceramic bearings?
underdog is offline   Reply With Quote
Old 04-30-2003, 12:33 PM   #1974
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Rtype, just curious if the brgs are housed internally? (i.e gear cases that the tevo have) why do you need the shields ? also the shields should not affect the spacing on any brg.
rock on !
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 04-30-2003, 12:57 PM   #1975
rtypec's Avatar
Attached is an illustration of what I mean about the bearing shifting on the crown gear.
Also, it seems that the bearings without shields tend to let the crown gear wobble more (again causing bad mesh) than bearings with their shields intact. I'll install rubber bearings and see if it helps.
As for the ceramic bearings. Acer didn't have those sizes at the time and I had to go with metal shielded bearings when I placed the order.
Old 04-30-2003, 01:24 PM   #1976
izzyracer's Avatar
Holly Molly Batman, I mean Rod, that's one fast draft...cool.
Hey, I had that happen on my original bearings.
Izzy
Old 04-30-2003, 01:27 PM   #1977
izzyracer's Avatar
Default TB EVO 3 officially discontnued.
According to RCzone.net our awesome car is now officially discontinued to make way for the Shurikarn Edition, is anyone starting a new thread for this baby?
Izzy
Old 04-30-2003, 01:33 PM   #1978
Nice illustration RC, however I do not understand how a shield can have an effect on the brg. There is obviously a problem with any brg that has this issue. If the shield were to contact the inner race it would bind up considerably. If the crown gear is contacting the shield ? then the design engineer should be promptly escorted off the premises
Old 04-30-2003, 01:53 PM   #1979
Rod, I've been having problems with my front diff in general. I'll have to look closer at my bearings. What bothers me about the bearing/crown gear setup is that there's really nothing holding it in place. It's free to move around at will. If I remove my front diff and hold the car vertical with the nose down, the gear and bearing will fall right out. Same with the rear.
Old 05-01-2003, 02:20 AM   #1980
rtypec, I was checking my Evo 3 over the other night and noticed that the bearing shield had come off the front crown gear, i have no idea what has caused this but is it possible that the chassis is flexing and with the prop been one piece this is causing the bearing to deflect slightly and the seal pop out? Rick
Rick Draper is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
