Old 12-30-2002, 03:26 PM   #181
Trader Rating: 28 (100%+)
Default evo3 front ball diff.
Cool beans! Now the question is,where do you get these parts?I race on carpet and want to know where to get the diff parts asap.Are they even available?Overseas?Ineed them !Also steve wang said you could peice the diff together except the outdrives are unique to this car.Any other help locating the parts is greatly appreciated.
racenut123 is offline   Reply With Quote
Old 12-30-2002, 04:25 PM   #182
NANAKO's Avatar
http://www.rainbowten.co.jp/english/...newrelease.htm
NANAKO is offline   Reply With Quote
Old 12-30-2002, 07:01 PM   #183
I will getting EVO3 this week! Want to know where can I get the Tamiya setup board and setup tools showing on the previous reply. Please provide URL. thanks
smash123 is offline   Reply With Quote
Old 12-30-2002, 09:07 PM   #184
SpeedTech's Avatar
Hi Guys,
I got one of these EVOIII myself (I've yet to have time to build it though), and as soon as some spare parts are available, we'll have them on our website Looks like most of the parts will be available soon.
Steve Wang
Speed Tech R/C
www.speedtechrc.com
SpeedTech is offline   Reply With Quote
Old 12-30-2002, 11:08 PM   #185
rccarracer's Avatar
smash123, check the following shop, this is where I'm getting my setup board, tools, and TB Evo 3 from.
I unfortunately forgot that they were not shipping between the 28th and the 6th, and ordered on the 27th, meaning I fall into their no dispatch period.....what a pain in the butt!!
http://www.rainbowten.co.jp/english/index.html
rccarracer is offline   Reply With Quote
Old 12-30-2002, 11:54 PM   #186
black-knight's Avatar
R/C Tech Charter Subscriber
work in prodress...
Black-Knight - None shall pass!
www.nbhc.com.au - www.facebook.com/smaracing
black-knight is offline   Reply With Quote
Old 12-31-2002, 12:07 AM   #187
Originally posted by itchynads
Just a question for those who have built the kit, is it really necessary to grease the diff gears with the included ceramic grease? I don't really want to since it may reduce the efficiency of the gears which are super smooth right now.
i'm not putting any ceramic grease or otherwise on the diff gears, if a TC3 can do with out so can the Evo.
Old 12-31-2002, 12:39 AM   #188
Originally posted by NANAKO
Do you guys know where I should start with gearing for a 9T mod for the EVOIII? Thanks~!
Gearing the TB Evo III for modified racing:
Ok here is what i have discovered.
1. Stick to 64 pitch gears (0.4 module is the same), you will not fit bigger than the supplied 96 spur gear onto the car, 112 and up appear to be too big. This calculation is based on 64mm tire/wheel diameter.
(there is no chance of fitting 86 or 90 tooth 48 pitch gears they are too big, anything smaller is not suitable). 81 may fit??? i did not have one handy.
2. A good starting ratio for a 9 turn would be 23 - 24mm roll out. This would involve using a 96 spur with a 29 pinion, i have set my car up with this combo...so we know it fits.
This is the starting ratio i use for most race meets (depending on track), i use this ratio with my 414 and Corally C4.1.
I would normally end up gearing up taller...but the above mentioned ratio is a good starting point. I's also recommend sticking with 64 pitch as the gears appear smoother and the car is quieter.
If you want a copy of my rollout chart for the 414 or TB Evo grab it via this link... (right click the link and choose "save target as")
Ratio / Rollout Chart
Old 12-31-2002, 06:25 AM   #189
An 81t 48p spur will be out of the question since it is bigger than the 96t 0.4 kit spur. My guess is that you will need something in the 65 to 70t range for a 48p spur.
black-knight: How heavy is your car with all the electronics minus the body? I'm sitting at 1435g at the moment. About 25g heavier than my 414m2 but still pretty good as far as Evos go At least I won't have to worry about being underweight
itchynads is offline   Reply With Quote
Old 12-31-2002, 07:42 AM   #190
rtypec's Avatar
Default Weight Savings
"When in doubt, Ti it out!"
rtypec is offline   Reply With Quote
Old 12-31-2002, 08:17 AM   #191
NANAKO's Avatar
Kansha no kotoba black-knight~!
Old 01-01-2003, 05:57 AM   #192
Default Re: Weight Savings
Looks like I might have a look at some Ti turnbuckles next payday
Old 01-01-2003, 10:16 AM   #193
Aluma's Avatar
so what would be a good ratio/combo for stock racing? with a P2K or a Core or a Revenge of the Monster?
48P gears and pinions, cuz I hate it when i get a pebble stuck in the 64P and the whole spur just disappears.
I have a 48Pitch asso. 72T spur with a 28T pinion on the side...would that be okay?
Aluma is offline   Reply With Quote
Old 01-01-2003, 10:29 AM   #194
PizzaDude's Avatar
Aluma, if it is a pretty large track then yes.
If the track is medium or small, then use a smaller pinion!!!
Good luck.
PizzaDude is offline   Reply With Quote
Old 01-01-2003, 04:20 PM   #195
The Core is a fairly high torque motor so around 5.8 - 6.5 would be a starting point. The Monster is a high RPM motor so around 6.5 would be its starting point. These are really generalisation, depending on how you tune these motors, you may find that their characteristics will change.
I tend to run my Core at 5.6 - 5.8 on a track with a very long straight. The motor does get hot but I'm gearing just to keep up with the rest of the field who use insane gearing.
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
