Old 04-14-2003, 01:52 AM   #1786
davioh's Avatar
i want to know ur setup! hehe that would be great
davioh is offline   Reply With Quote
Old 04-14-2003, 01:53 AM   #1787
davioh's Avatar
how many ppl were there in each heat? hehe maybe if u weren't switched u might get #1! hehe...
Old 04-14-2003, 03:34 AM   #1788
GTMilenko's Avatar
thats what i thought. i'll post the setup for ya tomorrow
7 in each heat. i'm a rookie by the way this is only my second race meet, don't ask about the first.
GTMilenko is offline   Reply With Quote
Old 04-14-2003, 03:41 AM   #1789
davioh's Avatar
hehe good job! here is a pic of my tb stratus...updated...1 or 2
Old 04-14-2003, 03:41 AM   #1790
davioh's Avatar
2 of 2!
Old 04-14-2003, 03:42 AM   #1791
davioh's Avatar
hehe...in the blank area im gonna put a number 3! hehe...but i don't hav a sticker for that. if u see...my pics are focused! i figured out my camera CAN focus...hehe!
Old 04-14-2003, 07:18 AM   #1792
izzyracer's Avatar
Trader Rating: 27 (100%+)
Th body looks nice and clean, good job!
Izzy
izzyracer is offline   Reply With Quote
Old 04-14-2003, 07:58 AM   #1793
davioh's Avatar
hehe..thanks!
Old 04-14-2003, 10:20 AM   #1794
What is the best Tamiya body to run? TCS will be in Salt Lake in two months and I want to be prepared.
racerdave is offline   Reply With Quote
Old 04-14-2003, 10:31 AM   #1795
davioh's Avatar
whats that gotta do with Evo 3? but anyways...NSX 2002 is nice...very low....hehe...and looks the best too!
Old 04-14-2003, 10:46 AM   #1796
rtypec's Avatar
The new NSX should be the body to have, esp since they've introduced it in a lightweight version. Very neutral handling, sorta like the stratus 2.0. Also, it doesn't have a tendancy to lid skid and stay turtled because of the roof scoop (roll hoop )
rtypec is offline   Reply With Quote
Old 04-14-2003, 10:47 AM   #1797
davioh's Avatar
whats the diff between the lightweight version and the normal version anyways? i mean the effects of being lightweight...not the fact it is lightweight?
Old 04-14-2003, 11:09 AM   #1798
The lightweight one it made of thinner lexan and that helps lower the weith of the car ever so slightly. I have both and the car feels more on its toes with the lightweight one on. Rick
Rick Draper is offline   Reply With Quote
Old 04-14-2003, 11:54 AM   #1799
pcm
Guys, check this out. Evo III did really goog in this race. You guys probably know already.
http://www.lrp-electronic.de/e/main_frameset_e.htm
pcm is offline   Reply With Quote
Old 04-14-2003, 03:12 PM   #1800
GTMilenko's Avatar
ok heres my current setup, i like so i'm gonna keep it for awhile, maybe play around with sway bars.
if anyone tries it, let me know how it works for your.
Front
damper position hole = 3
upperarm position hole = 1
camber = -1.5
height = 5mm
rebound = 24.4mm(measured from top of axle to ground)
front drive = diff (1/4 turn tighter than back)
stabilizer =none
sus.mount spacer F=0.7mm r=0mm
toe out = 0.5
rear
damper position hole = 4
upperarm position hole = 4
camber = -2
height = 5mm
upperarm position = b
diff (just tight enough not to slip)
stabilizer =none
sus.mount spacer F=2mm r=2.1mm
shocks = factory
length = factory
sus blocks = "A" blocks all round (2degrees toe-in rear)
pinion/spur = 42/78
motor = johnson 540
tires = kyosho belted 35 (these are a massive improvement over the kit tires)
wheels = +2mm offset
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
