Old 04-13-2003, 02:36 AM   #1771
davioh's Avatar
Default also needing a setup
street...not very bumpy...Tamiya evo 3...
my setup now includes
front:
blue sways
yellow springs
front one-way
back:
red sways
purple springs
11T kyosho X speed stock
Futaba MC600C
Futaba 9402 servo
davioh is offline   Reply With Quote
Old 04-13-2003, 05:06 PM   #1772
racer's Avatar
does anyone know what size tamiya titanium shafts are used in the front/rear suspension arms?
is it 32mm?
and for the steerings arms?
is it 23mm?
any help would be appreciated
Thanks in advance
racer is offline   Reply With Quote
Old 04-13-2003, 05:51 PM   #1773
Aluma's Avatar
hey lee82gx.... I got a good setup for all diffs...
tires: I use take off 32's (the 4pack that dont come with inserts) for my outdoor asphalt track. They got more grip than the hpi 33r.( which i also tried) with soft inserts cuz we race at night. and HPI 24mm 5 spokes.
front: -2 deg tamiya white spring, yellow sway, 50wt oil, top shock all way out. .7mm spacer under the front rear block.(you might need to shave off a bit from the block if you're still using the tamiya screws)
rear: -2deg tamiya blue spring, yellow sway, 40wt oil, top shock all way out. 1mm spacer under the rear front block. B rear block.
2mm hex spacers that come with hpi wheels on all four corners.
I run the stratus 2.0 body, gear it 72spur/29pinion or one smaller depending on your track. these are 48 pitch gears from robison racing. I use them for a tuned p2k2.
I find it rotates on a dime and hauls @@@!
Aluma is offline   Reply With Quote
Old 04-13-2003, 07:34 PM   #1774
lee82gx's Avatar
thanks a big bunch Aluma.
will try it
lee82gx is offline   Reply With Quote
Old 04-13-2003, 08:37 PM   #1775
Aurra Sing's Avatar
I was looking at Evo3 setups. If "Rebound Stroke" = Droop... Does anyone know what the difference between these two rebound strokes are?
Aurra Sing is offline   Reply With Quote
Old 04-13-2003, 08:55 PM   #1776
TAO4R's Avatar
Nope Sry.
TAO4R is offline   Reply With Quote
Old 04-14-2003, 12:48 AM   #1777
Send a message via ICQ to TRF Germany
I've talked to Mr. Hara, chief designer of TB EVO III, and he told me that it is a translation failure in the setup sheet. the first "rebound stroke" means dropp and the second "rebound stroke" means wheel spacer. As you can see the japanese signs are different, so they simply made a translation failure.
BTW:
TB EVO III had big succes in Germany at the German Indoor Nats!!!!
Place 1 and 2 in Touring Car Stock (Winner Bernhard Bopp)
Place 1, 4, 8, 10, 12 in Touring Car Modified (Winner Marc Rheinard)
As soon as possible i will post some pics of Germany's EVO III.
TRF Germany is offline   Reply With Quote
Old 04-14-2003, 12:56 AM   #1778
davioh's Avatar
go EVO III! hehe...wait...isn't the HPI racer also Hara?
Old 04-14-2003, 12:59 AM   #1779
the hpi driver is atsushi hara. the chief designer of EVO III is Toshihiko Hara
Old 04-14-2003, 01:00 AM   #1780
davioh's Avatar
hehe...no relation im guessing. Thanks
Old 04-14-2003, 01:59 AM   #1781
Iso Octane's Avatar
What is a wheel spacer? Offset?
Iso Octane is offline   Reply With Quote
Old 04-14-2003, 02:13 AM   #1782
davioh's Avatar
it's a hex spacer so the wheel would go out more...to avoid touching anything else...sadly i have one in and it still touches stuff (with one set)
Old 04-14-2003, 02:18 AM   #1783
A wheel spacer is a 1 mm or 2 mm Shim that helps to change easily the front or rear width.
Old 04-14-2003, 02:30 AM   #1784
davioh's Avatar
hehe...my bad
Old 04-14-2003, 02:46 AM   #1785
GTMilenko's Avatar
hey guys, i raced the evo this weekend, and she went very.
1st heat = finsihed 3rd
2nd heat = finished 4th (but had to start at the back of grid for some reason.
3rd heat = finished 2nd
had heaps of comments on how fast she was.
i'm running the front diff. if anyone wants the setup let me know.
the track was med size, farly techincal, high grip concrete.
i'm running kyosho tyres belted 35's they work well, some guys have 30's. we race at night with med inserts
GTMilenko is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 05:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 08:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 11:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 08:49 AM
SEO by vBSEO 3.5.0
