Old 04-08-2003, 11:49 PM   #1726
KINGZJ's Avatar
Send a message via AIM to KINGZJ
Masami allways has extra body posts I have seen as many a 7 on his car
KINGZJ is offline   Reply With Quote
Old 04-09-2003, 03:08 AM   #1727
lee82gx's Avatar
my favourite spurs are from Robinson Racing.Stealth i think.very hard and they can probably outlast a pinion when rocks get in.
not available in metric so u get either 64p or 48p.
what pinions do u recommend.according to my experience , lightweight alu pinions are not durable BUT those steel ones are WAY too heavy.any compromise in between?
GT:
i would say keep the stock bearings..just degrease them in any fancy way u desire...being metal shielded...u can even burn them over a flame!
once degreased and then lubed then can be just as free.
and when there is too much slop/vibration from the bearings only then buy the rubber shielded ones.
i found out that once the bearings are free the car performs much better overall.
lee82gx is offline   Reply With Quote
Old 04-09-2003, 06:49 AM   #1728
Bearings:
The stock seem fine to me. I degrease them with Goof-Off and lube with Aero-Car bearing lube. I like it because it cleans up with isopropyl alcohol.
The only bearings I have replaced so far are the 8x12 that holds the crown gear. If you crash or tap boards from time to time, check these often. My originals still spin free, but the shields have been damaged. I replaced them with high quality 3rd party units (in stock at my LHS).
Davioh – I guess it come down to whether or not you want to spend the money. My advice, use the stock ones until they need replacing.
Gears:
I have used Tamiya, Kimborough & RRP gears. I also use Tamiya, Kimborough & RRP pinions, no problem with any of those.
One thing though, I only run indoors at the moment, and once the summer comes, I would only use my Evolution III on a prepared surface. I couldn’t imagine running it on the street with all the rocks and dirt and various other nasties that can make an RC car unhappy.
ARC MotorSports is offline   Reply With Quote
Old 04-09-2003, 10:25 AM   #1729
Geetoo's Avatar
Send a message via AIM to Geetoo Send a message via Yahoo to Geetoo
has anyone tried using TB-01 carbon shaft set on the evo3? Want to know the difference on its rotating mass. But I heard the shaft set strips on mod motors, guys here use ca cement on endpoints to hold on the tips to the carbon shaft.
www.hpiracing.com
www.hotbodiesonline.net
www.nosram.com
www.team-durango.com
www.actionhobbiesonline.net
Geetoo is offline   Reply With Quote
Old 04-09-2003, 04:06 PM   #1730
racer's Avatar
anyone know where i can order online Square's 3mm chassis for the Evo III?
Thanks in advance
racer is offline   Reply With Quote
Old 04-09-2003, 04:41 PM   #1731
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Thanks in advance
Rainbow Ten
They can get them
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽµ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 04-09-2003, 06:20 PM   #1732
theisgroup's Avatar
I have the tamiya tool set, where can i get the rest of the tools?
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 04-10-2003, 04:20 AM   #1733
Steevo's Avatar
Try This Link For more Tamiya Tools
HOBBYMANIA
Just ask Andy about what you are looking for and he will help you out.
Steevo
Steevo is offline   Reply With Quote
Old 04-10-2003, 06:31 AM   #1734
Parts Evo III Torque rod setup?
If someone could post what Tamiya parts I need to install torque rods on my Evo III, that would be great.
Thanks!
Old 04-10-2003, 06:41 AM   #1735
lee82gx's Avatar
regarding the torque rod
can anybody give instructions?
that would also be great
Old 04-10-2003, 06:57 AM   #1736
davioh's Avatar
what are torque rods?
davioh is offline   Reply With Quote
Old 04-10-2003, 07:19 AM   #1737
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
If you've seen the tao4r.well Look at front of the car, and there's a turn buckle attached to hub carriers and the top deck..
OVA is offline   Reply With Quote
Old 04-10-2003, 07:40 AM   #1738
davioh's Avatar
my friend has a TA04R....(infact his name is TAO4R) but i haven't noticed a torque rod
Old 04-10-2003, 07:45 AM   #1739
izzyracer's Avatar
Trader Rating: 27 (100%+)
Maybe he took it out!
Izzy
izzyracer is offline   Reply With Quote
Old 04-10-2003, 07:57 AM   #1740
davioh's Avatar
hehe...maybe...what does it do...the torque rod....and so whats with installing it? doesn't come with the e3?
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 04:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 07:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 10:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 07:49 AM
