Like Tree21Likes
Old 06-21-2016, 10:03 AM   #46
32819toon's Avatar
I need some steel outdrives as I've now broken all 3 spares I had. The Nando / Exceed ones are only available in the USA & shipping is too expensive . Is there another car whose outdrives will fit, or may be a gear diff ?
32819toon
VBC Wildfire D08, Yokomo BD7 RS, Schumacher Atom, Tamiya M03, M05 (outdoor Mini), M03RWD, MF01-X, BSR M-Rage, ABC Gambado, Associated TC4 (outdoor car).
32819toon is offline   Reply With Quote
Old 08-25-2016, 10:54 PM   #47
RotorTruck's Avatar
So I bought the option spool for the m.rage, installed it in the front with new bearings. Drove it last weekend at the track. Normally I have the ball diff up there set very tight. Spool does a little better acceleration, and I swear braking was a little better. It understeered a touch so I added 5% more steering and it drove rather well. Tire wear.... was horrible. Outdoor asphalt sunny 95* ambient. I was using the kit tires and rims, that I prepped at home. Scuffed and 3 coats of Formula V traction treatment. At the track cleaned tires with Simple Green and sauced before each session with 50/50 mix of Paragon and WD-40. They were driveable for 15 minutes of practice, and two 5 minute qualifiers. But by the time for the main race, they were worn and coned. Drove anyway, drove okay but just didn't have the traction from earlier. Went from pole position to 3rd place. Front tires were just toast.
Had to try it out, a worthy experiment. I'll switch back to the very tight ball diff, thank you!
-Brad
RotorTruck is offline   Reply With Quote
Old 08-26-2016, 05:03 AM   #48
sakadachi's Avatar
Sounds like fun, RotoTruck. Glad to hear you're enjoying your BSR!
I'm going back to my RC hobby in a few months when it gets colder where I am.
4PKS-R, DX4S, EX-5UR: Sabre4WD Mini, SabreFD Mini, M01, M02, M03, M04, M05 (2), M05ProV2, TA05 M-Four, CupRacer, BSR M-Rage, WR02, GF01 (2), CC01 (2), CW01, CR01, DF02, TT02B, TA02, RS4, MicroRS4, MR01, MR03-S (2), MR03VE, DigiQ (7), & more.. Updates of projects I am working on in my profile page.
sakadachi is offline   Reply With Quote
Old 08-26-2016, 05:37 AM   #49
SteveM's Avatar
Trader Rating: 134 (100%+)
Tamiya sells 3x3mm bushings that can be used in a ball diff that gives a limited slip diff that might work for you. The part number is 54424 and I used these very successfully in my TB-03 in the past. Might be worth a try.
SteveM is offline   Reply With Quote
Old 08-27-2016, 09:55 PM   #50
RotorTruck's Avatar
The stock ball diff tightened up on the tight side works really well but I may try those Tamiya bushings you spec'd just for kicks. Thanks!
-Brad
Old 10-21-2016, 12:56 PM   #51
longuylander's Avatar
Just ordered one of these from HobbyKing. From the U.S. East warehouse, with shipping, cost just over $50. I couldn't pass on that. I probably should have bought a second too, for spare parts.
longuylander is offline   Reply With Quote
Old 10-24-2016, 04:11 AM   #52
sakadachi's Avatar
Wow, that's a super deal! Keep us posted how you like it.
Old 10-24-2016, 04:49 AM   #53
SteveM's Avatar
How did you manage to do that? I still see these listed for $89.50 USD plus the shipping from the US warehouse.
Old 10-24-2016, 06:38 AM   #54
aracefan's Avatar
Trader Rating: 38 (100%+)
On Friday, they were $39 (for the kit) on HK's East warehouse site - I almost ordered 2, but didn't. Just ordered another 1/12 scale.
All give some, but some give all - thank you veterans for my freedom.
VBC is my new addiction - have Alex Pate at GripworksRC to thank for that!
aracefan is offline   Reply With Quote
Old 10-24-2016, 06:43 AM   #55
aracefan's Avatar
just ordered 2 of them... they were $39.03 /ea. $88 with shipping for 2 of 'em.
Old 10-24-2016, 06:51 AM   #56
SteveM's Avatar
All I see is International for $78.14 and USA West for $89.50, no USA East warehouse listings at all. Bummer, for $39 I would have grabbed two as well.
Spharticus likes this.
Old 10-24-2016, 07:43 AM   #57
aracefan's Avatar
Here ya go.
Make sure it says: Shipped from USA East Warehouse above the quantity.
Old 10-24-2016, 11:21 AM   #58
I ordered one too. It arrived on Saturday. I have not started the build, but did pull a few parts out of the box. I was surprised at how small the "mini-10" scale is - my 1/16 SCT is about the same size
The m.rage tire on top of a few 1/16 tires -
And the m.rage body on top of my 1/16 sct chassis -
JerryRigged is offline   Reply With Quote
Old 10-24-2016, 12:43 PM   #59
I wonder why some people can't see the U.S. East price. Mine should be arriving on Wednesday. I ordered a set of the soft, medium, and hard springs and an extra set of diff outdrives (after reading this thread) from the HK warehouse too.
Old 10-24-2016, 12:44 PM   #60
aracefan, I just noticed the five minute time difference between your "I almost ordered two but just bought another 1/12" post and your "I just ordered two of them" post. Couldn't resist, eh?
