Like Tree6Likes
Old 05-18-2016, 11:23 AM   #46
bkspeedo's Avatar
Originally Posted by hanulec View Post
Nazda4 feels someone like an LTC-R
We did some extensive testing w/ the Nazda4 at Mile High Champs and found that it really depends upon the layout. The Nazda4 has extreme high speed steering so if your layouts have a lot of full or near full throttle turning sections then it will be a great body.
Alternatively, when you have a lot of tight low speed corners nothing seems to match the Nazda2 corner rotation. In fact we had 6 of 10 A-main drivers in 17.5 TC at Mile High Champs --- not to mention it won the 2016 ROAR Carpet National Championship in 17.5 and 13.5 TC the month prior.
Don't forget it also won 17.5 and 13.5 at MHIC let alone had that many drivers using the body in the 17 A main.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 05-24-2016, 05:59 PM   #47
hanulec's Avatar
Trader Rating: 27 (100%+)
The Mon-Tech IS-200 body is now ROAR approved -- 016-004 (IFMAR 1647). This is the 5th body approved now by ROAR in 2016
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 08-19-2016, 05:35 PM   #48
hanulec's Avatar
we've been seeing a lot of different questions about the best mounting location for the ROAR certified 1/10th EP TC racing bodies. here is our best summary---
Mounting Neutral/Centered on wheel wells in front end:
- Nazda3
- Silvy
- Nazda4
Mounting Extremely Forward -- On Amtx or XRay cars - adjust the rear body post first so that it nearly goes through the rear wing upright:
- Nazda2
- IS-200
Old 08-19-2016, 11:52 PM   #49
Root_66's Avatar
Can you post a picture please.
Root_66 is offline   Reply With Quote
Old 08-20-2016, 04:14 AM   #50
hanulec's Avatar
https://www.facebook.com/MonTechRacingUSA/
Old 10-13-2016, 08:24 PM   #51
hanulec's Avatar
Mon-tech racing Dominates 2016 International Indoor Championships - IIC! What a difference two years makes! 5 TQ + Wins!!
Modified TC - Bruno Coelho - Mon-Tech IS-200
13.5 TC - Jan Ratheisky - Mon-Tech Nazda2
17.5 TC - Mike Gee - Mon-Tech Nazda2
Amateur TC - Armand DeForest - Mon-Tech Nazda2
F1 - Jan Ratheisky - Mon-Tech F13
Old 10-13-2016, 09:54 PM   #52
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
Jan used the stock X-ray '16 body for F1 at IIC.
Dan is offline   Reply With Quote
Old 01-27-2017, 06:36 PM   #53
hanulec's Avatar
Quick intro video on the pre-cut Mon-Tech Nazda2 and IS-200 bodies-
https://www.youtube.com/watch?v=4u1u...ature=youtu.be
Mon-Tech Racing USA will have pre-cut body samples for XRay and Awesomatix available at Snowbirds for people to check out
Old 01-28-2017, 03:11 PM   #54
Will you also have F1 front wings available also? Can't get any .
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT Racing USA (17.5 foam), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Old 05-25-2017, 09:05 PM   #55
hanulec's Avatar
IS-200 and 1.0mm/hard wings available tomorrow at the Reedy Race over in the invite section. If you cannot find us, just ask Eric from PROTOform.. he knows where we are
LOW ET likes this.
Old 05-26-2017, 08:56 AM   #56
Chris Adams's Avatar
This is actually pretty funny. Eric is a good dude, he would send you in the right direction.
LOW ET likes this.
TEXASEOS.net, RcAmerica, Xray, Hudy, Protoform, Orca, Avid, 2mm Designs
Texas EOS 2017!
Chris Adams is offline   Reply With Quote
Old 05-30-2017, 06:59 AM   #57
Trader Rating: 34 (100%+)
I see many people say that the IS200 and Nazda 2 are the bodies to have. What is the direct comparison between the two in terms of handling? What is the reason that the Nazda appears to be more preferred for stock racing and the IS200 more preferred for mod?
Smith90 is offline   Reply With Quote
Old 05-30-2017, 07:37 AM   #58
geeunit1014's Avatar
The Nazda 2 has less initial steering, and more mid corner steering. The IS200 has more initial steering, and is more stable mid corner. The IS200 also has more downforce so is better at high speed.
N2 is liked for stock for its cornerspeed. IS for mod for downforce and stability. Many peopl like the IS for stock as well, it comes down to driver/setup preferences
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 05-30-2017, 09:11 AM   #59
hanulec's Avatar
One last statement to add to Gee's-- unless you have euro-style sweeping corners, the is200 is likely better on asphalt in all motor classes.
Old 07-28-2017, 02:29 PM   #60
LOW ET's Avatar
Trader Rating: 95 (100%+)
so when are the mon-tech racer bodies gonna be in stock?
LOW ET is online now   Reply With Quote
Tags
awesomatix, f-1, montech, nazda, usa
