Like Tree2Likes
Old 01-27-2016, 06:41 AM   #106
Holmenkollen's Avatar
Originally Posted by BCDK View Post
Inside upper link: if you add shims here you lower the roll center. Shims on the upper inside link is about 1/4 or 1/3 of the low rc adjustment = shims under the blocks.
That is the way I do it, and the car also reacts so.
It is very good and detailed explained by Martin Crisp in his app "Workbench".
Yes, thatīs what I wrote. I run less shims inside front camberlink than Eryx 3.0 = higher roll center.
Xray - Hobbywing - Graupner
Holmenkollen is offline   Reply With Quote
Old 01-27-2016, 11:06 AM   #107
corallyman's Avatar
Trader Rating: 99 (100%+)
Originally Posted by Andy63 View Post
Thank you very much! I write everything on my phone or ipad and there seem to
be hard to get all the fancy parts in there. But why i post on the blog and link to it is becuse this forum dont allow me to upload from my phone. Just to ckear that up.
To be able to see my sheet you can try clicking on it or use CTRL+ + on your keyboard. Thanks again!
OK, thanks for the tip. that CTRL + tip worked great. I am used to enlarging images a different way, and my way did not work on your image. I never knew of your tip though, maybe it will help others as well. Thanks.
Steve
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 01-30-2016, 09:41 PM   #108
purple haze's Avatar
Which chassis would you guys recommend for carpet tracks ? Or is it more of a personal preference ?
www.karz.ca
www.carcar.ca
www.rcgears.net
purple haze is offline   Reply With Quote
Old 01-31-2016, 12:06 AM   #109
Andy63's Avatar
It seems like the 2.25mm carbon or 2mm carbon chassies is the way for carpet.
I would recomend to try 2.25mm first.
www.andrefossto.wordpress.com|HOBBYWING |YOKOMO |HBracing |MIBOSPORT.COM |Reservdelsrc.com |Jockeli-Painting |
Andy63 is offline   Reply With Quote
Old 01-31-2016, 04:27 AM   #110
dan_vector's Avatar
Trader Rating: 25 (100%+)
For me Alu chassis for carpet. 2.25 carbon only in super high traction carpet.
Serpent Viper 977e EVO2, Serpent 977 EVO2 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.0, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 01-31-2016, 12:02 PM   #111
Andy63's Avatar
I heard that the 2.0mm is stiffer then the 2.25mm even tho it's thicker. So in high grip condition the new 2.0 or aluminium is the best. But i would still say that the 2.25mm is best allrounder.
I could today advance my best laptime on my nearest track by half a second! Much setup work is still needed for this car tho! Will post more on my blog this week
EDIT: i tried the setup with wider front and upsidedown 3.5 bracket f/r. This setup is recomended!!!
Old 02-01-2016, 07:54 AM   #112
dan_vector's Avatar
The 2.0 carbon is harder because of the weave of the carbon itself. Every time I've ever tried the 2.0 carbon chassis I've ended up with massive under steer.
Old 02-01-2016, 10:54 AM   #113
Pit-racer's Avatar
Which manufacturer are the best spur and pinion gears to use for the 3.0 and 4.0?
Team Misfits / www.igthobbies.com / Desoto Racing / Veytrex.com / JZRacing / RcShox / IGT8 '17
Pit-racer is offline   Reply With Quote
Old 02-01-2016, 12:30 PM   #114
spacendeman's Avatar
Send a message via MSN to spacendeman
I use Serpent spur gears and Arrowmax pinions.
Currently:
Serpent F110 SF2 with Hobbywing ETS setup.
Serpent S411 Eryx 4.0 with ETS Stock setup
Serpent S411 Eryx 3.0 with ETS Stock setup as rain car.
Serpent S120 LTR with 10.5 blinky mode.
spacendeman is offline   Reply With Quote
Old 02-01-2016, 01:24 PM   #115
Andy63's Avatar
Thing is, if you drive on high grip carpets, stiffer is faster. You got to make setup changes to make the car roll and get more steering, Marc Fischer used 5.5mm shims in the upper link arms to get much roll with the new 2.0mm chassies.
Old 02-01-2016, 01:38 PM   #116
Johnny Wishbone's Avatar
Um, no.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 02-02-2016, 12:13 AM   #117
Fjeld's Avatar
Alu! It is much easier to drive, it will make you faster in 5min.
|| Yokomo BD7 2015 || XRAY T4'15 ||
|| Muchmore Fleta POWER :D ||
Fjeld is offline   Reply With Quote
Old 02-02-2016, 05:19 AM   #118
Pit-racer's Avatar
Old 02-02-2016, 06:16 AM   #119
Andy63's Avatar
Originally Posted by Johnny Wishbone View Post
Um, no.
Ok then, can you explain this setup sheet?
http://site.petitrc.com/reglages/ser...gwy2016012324/
Old 02-02-2016, 06:55 AM   #120
Very high grip at that track so lower roll centers prevent traction roll. Actually, a soft chassis is a way to go in high grip situations because a stiff chassis rolls less to a certain point and then it tips over.
