Like Tree2Likes
Old 01-25-2016, 04:04 PM   #91
performula's Avatar
Amain has the 4.0 fyi I know it was mentioned in the 3.0 thread.
performula is offline   Reply With Quote
Old 01-25-2016, 08:00 PM   #92
The FastFred's Avatar
Originally Posted by 1spunspur View Post
I've been reading along with you all, and I am a little confused. Wouldn't a lighter fluid make your car more manageable, and heavier fluid make your rear end lock up sooner or easier, and make you fish-tail or spin-out easier?
Exactly as I understood... But they are saying something different. But I also think many of the comments are for carpet. Need to find out more!
The FastFred is offline   Reply With Quote
Old 01-25-2016, 08:14 PM   #93
corallyman's Avatar
Trader Rating: 99 (100%+)
I feel your confusion but as someone who has owned rc cars since the early eighties, all I can say is read, learn, and ask but nothing beats trying all these changes for yourself. RC cars have sooooo many adjustments and they all work in conjunction with all the other adjustments, plus track conditions, plus motor characteristics, plus ........
You get the point. I have several diffs pre made up and marked for these reasons, and I think the heavier oils will work better for me too. My car is a little weird at times with light fluid so I'm building my new Eryx 4.0 with 5k, and 7k. This is for Mod carpet.
Steve
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 01-25-2016, 09:21 PM   #94
dan_vector's Avatar
Trader Rating: 27 (100%+)
It's really the opposite! Of course a lighter fluid does make the car a little bit easier to drive (up to a point) in some scenarios particularly in very low traction but we are talking 3k here as the lightest I'd go. The issue is that lower than 3k our diff has a tendency to diff-out causing strange on power characteristics. The new diff is only better more robust plastics over the 3.0 diff and I haven't found a huge difference in setup between the two. But as others have said the only way to really understand what is being said is to try it yourself.
Fast Fred this is not only related to carpet. This is for asphalt as well. Medium to high traction.
Serpent Viper 977e EVO2, Serpent Viper 988 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.1, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 01-26-2016, 02:42 AM   #95
Andy63's Avatar
In my case, using heavier diff oil is easier in modified (5-7kish) for me to handle. If the oil is to light it can very twitchy and react to every steering input you do. Hesvier oil is the opposite, making the car stable on power while steering and have less respond when steering. I am not so good at explaining. But dont get confused with real cars and r/c cars. They work somewhat different sometimes. And in this case, the geardiff needs that heavy oil in modified to become an easy drive.
www.andrefossto.wordpress.com|HOBBYWING |YOKOMO |HBracing |MIBOSPORT.COM |Reservdelsrc.com |Jockeli-Painting |
Andy63 is offline   Reply With Quote
Old 01-26-2016, 04:24 AM   #96
Both my sons are driving the 4.0 - one in modified and one in superstock (13,5 T blinky) - and they don't use the same diff-setup. In modified startingpoint is 5k and in superstock 3k.
It depends on the track - grip, size, layout - car setup - class - but also on the driving style.
Different thinkness can make the car struggle in both turn in or out.
Therefore - diff setup depends on so many things, that you can't just take a setup from another driver and say, that is the correct setup. You have to test by yourself, what you like for that day on that track with that grip.
I would say: thin oil let your car oversteer out of corners, and thick oil let your car oversteer in turn in.
My way to do it: low grip = thin oil. More grip = thicker oil.
But as written: it depends on so many things.
Sponsor: Team Serpent, 2-Speed RC, ToniSport, Allans Koereskole
Modified: Serpent S411 Eryx 4.0, LRP Flow, LRP X20 4,5 T, Sanwa M11X
Superstock: Serpent S411 Eryx 4.0. LRP Flow, LRP X20 13,5 T, Hitec Lynx 4S
BCDK is offline   Reply With Quote
Old 01-26-2016, 09:41 AM   #97
Johnny Wishbone's Avatar
Very true, and words to live by. Great input.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 01-26-2016, 12:04 PM   #98
Andy63's Avatar
Posted my latest setup for the ERYX 4.0, it is very easy to drive!
Old 01-26-2016, 01:18 PM   #99
You need to download the revised setup sheet so we can see where your upper camber link locations are.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 01-26-2016, 02:41 PM   #100
Andy63's Avatar
You actually can. But it isshortest possible both front and rear.
Old 01-26-2016, 04:14 PM   #101
I pleaded with Ronald to get the setup sheets changed to show the 3 options settings, someone has to use them, LOL.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 01-26-2016, 05:16 PM   #102
corallyman's Avatar
Andre,
Is it possible for you to also include a link that we can click on so that I can see a bigger setup sheet. It is hard for me to see some of the finer detail on your sheet. I do enjoy reading your blog posts, so keep on doing what your doing!
Thanks,
Steve
Old 01-26-2016, 11:40 PM   #103
Holmenkollen's Avatar
Thatīs some high roll centers. Shortest link and 3 mm inside camber link.
What I have tested so far on the 4.0 is that I tend to run a little higher front roll centers compared to the 3.0 so your findings seem to be in line with that.
I also tried the 2 mm carbon instead of the stock 2.25. itīs a little bit harder overall (not much), it freed up the car a bit in the corners. Itīs the 3.0 2 mm carbon chassis. The new one is a different shape.
Xray - Hobbywing - Graupner
Holmenkollen is offline   Reply With Quote
Old 01-27-2016, 02:27 AM   #104
Andy63's Avatar
Post
Originally Posted by corallyman View Post
Andre,
Thanks,
Steve
Thank you very much! I write everything on my phone or ipad and there seem to
be hard to get all the fancy parts in there. But why i post on the blog and link to it is becuse this forum dont allow me to upload from my phone. Just to ckear that up.
To be able to see my sheet you can try clicking on it or use CTRL+ + on your keyboard. Thanks again!
Actually, i tried your shock setup you sent me on FB, and it feels great. But i think i will try 450cst next time to maybe get better high speed steering and maybe reduce grip roll that occurs at this track. Other then that, i think there is quite smalm changes to make to get the car very dialed.
We have pretty much the same style of tracks here in Sweden, so every track needs minimal changes.
Old 01-27-2016, 04:28 AM   #105
Inside upper link: if you add shims here you lower the roll center. Shims on the upper inside link is about 1/4 or 1/3 of the low rc adjustment = shims under the blocks.
That is the way I do it, and the car also reacts so.
It is very good and detailed explained by Martin Crisp in his app "Workbench".
