Like Tree2Likes
Old 01-24-2016, 06:00 AM   #76
The FastFred's Avatar
Dan, that consistency... Especially after a brush with the wall is worth it's weight in gold.
The FastFred is offline   Reply With Quote
Old 01-24-2016, 06:13 AM   #77
dan_vector's Avatar
Trader Rating: 27 (100%+)
Yes exactly! That's one of the good things they haven't tried to reinvent the wheel. All of the changes have been very welcome ones but as I said the car is very similar to the 3.0 setup wise so let's see what direction the 4.0 takes us. I'll be watching the team drivers closely to see what new things they start trying...
Serpent Viper 977e EVO2, Serpent Viper 988 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.1, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 01-24-2016, 06:16 AM   #78
In reviewing many setups I see rear diffs are very lightly set. Mostly with 1k oil. Are you doing the same here? Any one experiment with heavier weights?
Old 01-24-2016, 08:35 AM   #79
dan_vector's Avatar
I've never seen diffs set that light! I run minimum of 3k. I've gone as high as 10k at some very high traction asphalt events in Asia.
Old 01-24-2016, 11:55 AM   #80
And this being the 4.0 thread your referring to the new chassis
Old 01-24-2016, 01:28 PM   #81
dan_vector's Avatar
No. It's the same 3.0 vs 4.0. Don't get me started on that multiple 411 threads thing again! The 2 versions really aren't different to setup.
If you like ALOT of under steer go with a light diff. For me in 13.5 boost or modified which are my main classes I usually start 5k and go from there. That's regardless of 3.0 or 4.0. In fact even back when I was running the 2.0 car I still ran similar diff setup.
Old 01-24-2016, 04:47 PM   #82
Andy63's Avatar
I see you talk about how the car is handling. I use 7000oil in my geardiff.
And you can visit www.andrefossto.wordpress.com and see how that might look like.
I will post setup from the video this week.
Cheers//
www.andrefossto.wordpress.com|HOBBYWING |YOKOMO |HBracing |MIBOSPORT.COM |Reservdelsrc.com |Jockeli-Painting |
Andy63 is offline   Reply With Quote
Old 01-24-2016, 05:45 PM   #83
Johnny Wishbone's Avatar
Default Diffs on Carpet
The Serpent diffs from the V1, V2, V2.5 and the early V3 diffs, depending on which seals where being used generally do not like the heavier diff fluids as the diffs, well, they just would not diff properly. The biggest handling issue is/was that you would get a marginal oversteer on exit off of corner. The diffs themselves would "feel" like they where running 3k to 5k heavier fluid over a xray diff.
With that said, also be wary that some of the setups posted have guys running Xray diffs over the stock Serpent diff, so just keep that in mind. (Pretty sure Cody Woods runs a Xray diff in his 3.0 car.)
The new diffs that come with the 4.0 car are really nice, I would compare them to the Xray diffs now, so I suspect diff fluids will start to show up running heavier compounds.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 01-24-2016, 05:53 PM   #84
So your all finding the 4.0 a superior car. Easier to tune. Easier to drive?
Does it have a broader window of set-up...
Is the rear end more stable? Or able to be dialed in more readily.
Same tuning window as the 3.0. I feel the car would benefit with a spring change and sway bar change over the out of the box stock setup, which isn't much. Car shows a lot off potential and thats running the aluminum chassis on carpet.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 01-25-2016, 09:06 AM   #85
Default Chassis plates
So I was measuring the new chassis and the stock Serpent 4.0 chassis is the same width as the, no longer available, Avid chassis. The Serpent still has the milled areas, but the overal width is 82mm. This is quite a bit narrower than the 3.0 chassis as well. Just another thing to consider if you plan on converting a 3.0 to a 4.0.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 01-25-2016, 10:34 AM   #86
dan_vector's Avatar
I agree about the springs and bars. I never run serpent springs anyway. Never have since the 2.0. I also generally run the X-ray 1.3mm front and rear bars. The 1.4 is a bit hard and the 1.2 a bit soft so I'm forced to use the X-ray T5 bars. Spring wise I use HPI blue or silver mainly. Sometimes Ride 25mm Yellow or Green.
Old 01-25-2016, 03:33 PM   #87
Any one try these set-ups:
http://site.petitrc.com/reglages/ser...ongwy20151206/
Or see these??
http://site.petitrc.com/reglages/ser...ntS4114.0.html
I see here they used 8k diff oil.
Old 01-25-2016, 03:39 PM   #88
Cheers//
I like how he noted moving to thicker diff oil to make the car better out of the corners and easier to drive... really ?? true.
Old 01-25-2016, 04:43 PM   #89
Andy63's Avatar
True, i feel that it is easier throttle control with 7k instead of 5k oil in rear diff. But that is also dependant on size of track and driving style.
Old 01-25-2016, 04:44 PM   #90
1spunspur's Avatar
I've been reading along with you all, and I am a little confused. Wouldn't a lighter fluid make your car more manageable, and heavier fluid make your rear end lock up sooner or easier, and make you fish-tail or spin-out easier?
P./
1spunspur is offline   Reply With Quote
