Like Tree2Likes
Old 05-22-2016, 05:52 AM   #226
dan_vector's Avatar
Trader Rating: 25 (100%+)
Originally Posted by Les View Post
Hi,
Assembling my new S411 4.0, the shock pistons are very sloppy in the shock body, I can see down the side of the piston, the shock body 10.50mm the Pistons 10.28mm, the oil appears to be going down the side of the Pistons rather than thru the holes, shocks on my old car the Pistons are snug fit. Any idea's ?
Cheers
Sorry just answered this in the wrong thread. Lol. Mine were a good fit and so I'd get onto Serpent America. Very unusual.
Serpent Viper 977e EVO2, Serpent 977 EVO2 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.0, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 08-18-2016, 02:26 AM   #227
Taffyjnr5's Avatar
Trader Rating: 32 (100%+)
Hi,
Will the 2.25mm 4.0 carbon chassis fit my 3.0?
Maybe not so Retired..........
Taffyjnr5 is offline   Reply With Quote
Old 08-18-2016, 03:49 AM   #228
Originally Posted by Taffyjnr5 View Post
Hi,
Yes
Sponsor: Team Serpent, 2-Speed RC, ToniSport, Allans Koereskole
Modified: Serpent S411 Eryx 4.0, LRP Flow, LRP X20 4,5 T, Sanwa M11X
Superstock: Serpent S411 Eryx 4.0. LRP Flow, LRP X20 13,5 T, Hitec Lynx 4S
BCDK is offline   Reply With Quote
Old 11-24-2016, 11:25 AM   #229
Taffyjnr5's Avatar
Hi,
Anyone have a high grip asphalt on foam tyre setup they are using?
Old 12-08-2016, 09:36 AM   #230
TJames987's Avatar
Trader Rating: 10 (92%+)
Default front spool blades
is the 4.0 still chewing up front spool blades like the original 411 did?
That was the bane of the otherwise awesome car. has there been any updates to strenghthen the front outdrive/bones to a stronger blade or just go metal to metal?
TJames987 is offline   Reply With Quote
Old 12-08-2016, 11:15 AM   #231
I have no proof, but my experience after 6 front aluspools from 3.0 to 4.0 they are a little tougher in material and does not start chewing up blades as fast. But the solution is using the out drives/spool from 4-x
http://serpent.com/product/401723/
Linguster is offline   Reply With Quote
Old 12-08-2016, 11:45 AM   #232
The 4X is doing the same thing ( chewing the blades ! ) I tried to retro fit the orange Xray blades to the serpent driveshafts but it's a bit too big .
X-ray , 17.5 + mod , fantom motors , KO servos , HW XR10 pro , ORCA and LRP lcg LIPOS . Sponsored by my wallet . Lol lol
Real men race mod
Ggrant is offline   Reply With Quote
Old 12-08-2016, 01:31 PM   #233
Johnny Wishbone's Avatar
Default Front spool blades
One of the things I found, that helped the durability of the blades in the front spool, was to pre-bend the blades.
I would take a drive pin the length of the one that goes into the out drive. Put the blade on the pin like it would normally look, then I would take a pair of pliers and hold the pin and blade so that it would put a slight closing pressure on the blade. Then I would heat it up with a lighter just enough so it would hold the shape and when released from the pliers the blade would hold the shape and be even with the pin length.
This makes more of the blade sit in the spool so there is more material for the pin to push on the out drive plunge face. This really slowed down the amount of blades I was going threw. They still wear out but not as fast.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 12-08-2016, 10:09 PM   #234
I think we have two "problems" that work together. When surface of the aluspool where the blades are sitting starts to wear the process of going through blades starts to accelerate. That part is better on the new out drives. I buy blades by truck loads
Old 12-14-2016, 11:48 AM   #235
TJames987's Avatar
what is the aftermarket spoot set-up on serpents website? is that a beefier design?
trouble is I run punishing mod races outdoors, need bullet-proof spool like a TC7 or Xray. Otherwise I love the Serp
Old 12-14-2016, 01:36 PM   #236
The new spool is a 3 piece unit, the center section, and the replaceable aluminum outdrives. They still require blades. The older spools where one piece aluminum and you could not replace the out drives, the whole unit needs to be replaced if damaged. The first gen serpent had a similar spool to this but used steel outdrives and ran on the pins only. These outdrives where/are very rare if they can be found but should work with the original center section or the new one. (same lock pin location)
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 12-19-2016, 06:24 PM   #237
TJames987's Avatar
Is there a whole different brand car that you could drop in their spool?
Old 12-19-2016, 08:20 PM   #238
purple haze's Avatar
I really wish Serpent had not discontinued those outdrives . I have one NIP set left ....
purple haze is offline   Reply With Quote
Old 12-21-2016, 05:02 AM   #239
chicky03's Avatar
Send a message via AIM to chicky03
Hi,
Cheers
On the 4.0 this is normal. If you check out yokomo shocks you'll see the same thing.
I know serpent is working on a new blade material that should solve all the issues.
chicky03 is offline   Reply With Quote
Old 12-21-2016, 07:13 AM   #240
Just put some Amsoil 5% moly grease between the blades and the outdrives, and durability will improve....
bertrandsv87 is offline   Reply With Quote
