Like Tree2Likes
Old 05-09-2016, 12:53 PM   #211
dan_vector's Avatar
Trader Rating: 25 (100%+)
Originally Posted by Holmenkollen View Post
Halfway through the chicane so I guess its a little bit off power.
Ok. I call that scenario neutral power.
I'd personally have a play with roll centre. I'd first add a 1mm shim to the rear inboard upper link (lower RC) and remove a 1mm shim from the front inboard upper link (higher RC) then try again. If it is worse go in the opposite direction. You can also try a shorter front upper link going to the middle hole which also slightly angles the link. I've had great results doing that.
The stock springs are not the best on asphalt. I prefer HPI blue or silver all round depending on the traction level. I don't like the cars balance if we go different spring front to rear.
A little more front droop can help as well. I wouldn't bother with roll bars and stick with the 1.4mm bar front and rear. That pretty much works everywhere.
Serpent Viper 977e EVO2, Serpent 977 EVO2 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.0, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 05-09-2016, 11:44 PM   #212
Holmenkollen's Avatar
I use the HPI silvers around, I forgot to mention. That sounds like good changes, I will give those a try. Thanks!
Xray - Hobbywing - Graupner
Holmenkollen is offline   Reply With Quote
Old 05-10-2016, 04:03 AM   #213
I would also check the diff. oil. Go a tick lighter oil.
Sponsor: Team Serpent, 2-Speed RC, ToniSport, Allans Koereskole
Modified: Serpent S411 Eryx 4.0, LRP Flow, LRP X20 4,5 T, Sanwa M11X
Superstock: Serpent S411 Eryx 4.0. LRP Flow, LRP X20 13,5 T, Hitec Lynx 4S
BCDK is offline   Reply With Quote
Old 05-11-2016, 08:47 AM   #214
Location: Beneath a rock down by the river. Don't have money for van
What's the effective purpose of the front 3.5 brackets? More roll?
( ͡° ͜ʖ ͡°)
30Tooth is offline   Reply With Quote
Old 05-11-2016, 10:08 AM   #215
dan_vector's Avatar
Wider front track width. It takes the bite out on carpet indoors and settles the car down.
Old 05-11-2016, 11:25 AM   #216
Thanks, so one doesn't use the -0.75mm wheel hexes in conjunction with the 3.5 brackets?
( ͡° ͜ʖ ͡°)
Old 05-11-2016, 04:31 PM   #217
Trader Rating: 309 (100%+)
Use both, calmed the car down.
Jermaine Mitchell
I laugh at serious racers acting like B****
Free Agent racing team. No sponsors needed.
Mercenary Racer
jmoneym is offline   Reply With Quote
Old 05-12-2016, 02:32 AM   #218
Thank you both, good to know that as I want a S411 and will run it on carpet and asphalt.
Old 05-12-2016, 03:17 AM   #219
dan_vector's Avatar
Yes use both. If you don't use the -0.75 hexes you'll be over 190mm
Old 05-13-2016, 04:46 AM   #220
So would need brackets, -0.75 hexes and maybe springs and roll bars to cover most situations?
( ͡° ͜ʖ ͡°)
Old 05-16-2016, 09:33 AM   #221
The FastFred's Avatar
Originally Posted by Andy63 View Post
Nope, we use 3,5 block front and 3.5 block front/rear upsidedown with 3.5mm shim under.
Andy, I saw this on the can when I got it from Joaquin. whats the reason behind this odd mounting. What does it provide?
thanks!
The FastFred is offline   Reply With Quote
Old 05-16-2016, 03:57 PM   #222
gprcmx312's Avatar
Just got the car and I am running it in USGT. Right now I have a 92t 64p spur. I have looked through here and online and it seems that the 92 is the smallest spur that Serpent makes. Are there any companies that make smaller ones that will fit? Right now, with my gearing, I can not get to the motor bolts at all because of how big my pinion is. Really looking to get a smaller spur so I can use a smaller pinion and get access to the motor.
Thanks.
gprcmx312 is offline   Reply With Quote
Old 05-16-2016, 08:24 PM   #223
dan_vector's Avatar
Thanks.
You can go down to 69T on 48dp. Axon or arrowmax spurs are pretty good.
Old 05-17-2016, 12:09 AM   #224
So I came 2nd at our first nationals but the car was a handful to drive. Not until I changed the wheelbase from 3 mm to 5(!) for the finals could I drive it with some confidence. It was cold (34F) and windy so not the best conditions. I donīt think our tires (Sorex 36) got into the optimal temp levels. But always fun to run on +100 km/h straights.
Old 05-21-2016, 10:49 PM   #225
Les
Les's Avatar
Default Shocks
Hi,
Assembling my new S411 4.0, the shock pistons are very sloppy in the shock body, I can see down the side of the piston, the shock body 10.50mm the Pistons 10.28mm, the oil appears to be going down the side of the Pistons rather than thru the holes, shocks on my old car the Pistons are snug fit. Any idea's ?
Cheers
Serpent S411 4.0 13.5T D4
Kyosho V-ONE S3, RB Rota-Start
Sanwa MT4S
Les is offline   Reply With Quote
