Like Tree2Likes
Old 02-21-2016, 04:57 AM   #166
The FastFred's Avatar
Originally Posted by EREX_91 View Post
looking for aluminum chassis 3.0
I have a pair and do not run carpet . One I ran oce on carpet and is in very new condition. let me know if interested.
The FastFred is offline   Reply With Quote
Old 02-21-2016, 07:17 AM   #167
CamLS's Avatar
I might be interested in one of those for my eryx 2.0 Fred. I'm in Canada, so if you are willing to ship to Canada via USPS pm me the price etc. Thanks!
CamLS is offline   Reply With Quote
Old 02-26-2016, 03:17 PM   #168
Byronf1's Avatar
Does someone already tried with the carbon chassis, on asphalt, 2.25mm?
Which chassis is better, on asphalt low-mid grip...?
Serpent Project 4X - 748-TQ -S811 Be 2.1
Byronf1 is offline   Reply With Quote
Old 02-27-2016, 12:33 AM   #169
Andy63's Avatar
Standard carbon top deck and chassies is without doubt the best both indoor and outdoors so far.
Alu chassie from 3.0 seem to work well for some. But standard carbon is my choice on high grip carpet indoor and should be greater on asphalt!
Andy63 is offline   Reply With Quote
Old 02-29-2016, 02:02 AM   #170
Andy63's Avatar
I have found a great setup that works great on high grip carpet! I will post it later this week at www.andrefossto.wordpress.com
I also tried the mazdaspeed 6 and it really calmed the car down alot. But as i got problems the moment i was going to try it, i didnt have a chance to really push the cars limits.
Old 02-29-2016, 08:58 AM   #171
dan_vector's Avatar
Trader Rating: 26 (100%+)
So guys. I am back from the TITC 2016 race in Thailand and what an interesting weeks racing it was! I gotta say that the 4.0 is a vast improvement over the 3.0. I knew this already but the TITC race cemented that belief.
The RC Addict track was crazy high traction and early on it was clear that you'd need to have several setup options for best performance and to avoid traction rolling in the afternoons as the traction peaked. Ask the organisers sprayed the track each morning and so the early rounds were sometimes met with a slightly damp track!
The other issue was the very poor consistency of the RIDE tyres being used in the 13.5 open brushless class which I had entered. The problems was that the construction of the wheel/insert/tyre was very poorly assembled and glued. We cut open some of the tyres and found the insert glued to the tyre in some places. Out of the 4 controlled sets I had been issued only 2 sets were actually any good!! This made qualifying very hard.
I tried many things during the week in the search of initial bite in turn in to the corner which is something the car initially lacked. The Power on exit steering (and stability) was there from the outset and was something the 3.0 really struggled with. The biggest change came when we moved the front upper link inner to the middle/forward hole with 4mm roll centre shims. This gave the turn in off power I needed. Then to gain rotating dropped the rear inner link down to 3mm (inner hole - long link).
Diff wise we ended up at 12,000cst. Anything less and the car was nervous on power and skated around the bumps. The track is getting very bumpy in places. It also helped to increase the forward drive through the flat out chicane before the main straight.
The new shocks are great! I tried a few different combinations but ended up stock at 500cst 3 hole. Shocks in hole 3 up front and rear. This seemed the best compromise. Springs were alternated between HPI blue and silver with the best feeling when the traction really increased were the silvers. I also tried ride long green but the HPi silvers seemed to be the right choice.
Camber was 2 degrees all round in the morning but by the mid afternoon when the traction increased we had to reduce to 1.5 on the front to minimise the risk of traction roll at the expense of some steering.
Standard top deck and 2.25 4.0 carbon chassis. XH arms.
The car was fantastic all week long. Qualifying was really tough with only 2 good sets of tyres especially where tyre degradation was very high. After round 1 I was 19th/109 in class which was good however as this was 3 rounds to count (point system not FTD) I struggled to maintain the times against those who had better tyres so ended up 43rd in class. A pretty decent result on the whole and I learnt a lot about the car!
Serpent Viper 977e EVO2, Serpent 977 EVO2 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.0, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 02-29-2016, 10:48 AM   #172
spacendeman's Avatar
Send a message via MSN to spacendeman
Nice report!
Hope that the car also will work good on low-med grip tracks.
Currently:
Serpent F110 SF2 with Hobbywing ETS setup.
Serpent S411 Eryx 4.0 with ETS Stock setup
Serpent S411 Eryx 3.0 with ETS Stock setup as rain car.
Serpent S120 LTR with 10.5 blinky mode.
spacendeman is offline   Reply With Quote
Old 02-29-2016, 01:40 PM   #173
dan_vector's Avatar
Originally Posted by spacendeman View Post
Nice report!
I think we have a bit of work to do in those conditions!
Old 03-02-2016, 01:36 PM   #174
Andy63's Avatar
I made a new setup wich you can see at www.andrefossto.wordpress.com
This is by far the best setup i have tried on carpet. Try it if you have time! Cheers
Old 03-02-2016, 11:03 PM   #175
Thanks for the update Andy!
Currently:
Old 03-05-2016, 12:50 PM   #176
Trader Rating: 309 (100%+)
Using the 3.5 front block do you use the stock Front/rear with it?
Jermaine Mitchell
I laugh at serious racers acting like B****
Free Agent racing team. No sponsors needed.
Mercenary Racer
jmoneym is offline   Reply With Quote
Old 03-06-2016, 12:11 PM   #177
Andy63's Avatar
Nope, we use 3,5 block front and 3.5 block front/rear upsidedown with 3.5mm shim under.
www.andrefossto.wordpress.com|HOBBYWING |YOKOMO |HBracing |MIBOSPORT.COM |Reservdelsrc.com |Jockeli-Painting |
Old 03-07-2016, 06:43 AM   #178
BardSmith's Avatar
Trader Rating: 61 (98%+)
My rockin 4.0 at ROAR Nats...
"Bard"
On-Road Only!
BardSmith is offline   Reply With Quote
Old 03-07-2016, 06:48 AM   #179
Jermaine Mitchell
Mercenary Racer
Old 03-07-2016, 06:49 AM   #180
Nice can you share your setup.
Jermaine Mitchell
Mercenary Racer
