Like Tree2Likes
Old 02-15-2016, 09:31 PM   #151
If you guys are using the 3.5/3.5 brackets up front, doesn't that make the overall width over 190mm. I seem to recall that using 2.0/2.0 with camber at 1 degree makes the front of the car exactly 190mm.
Bottom line, is going that wide legal?
kaye7877 is offline   Reply With Quote
Old 02-15-2016, 10:11 PM   #152
spacendeman's Avatar
Send a message via MSN to spacendeman
I believe they also used the -0.75 wheel hexes.
So then the width of the care is just good enough.
Currently:
Serpent F110 SF2 with Hobbywing ETS setup.
Serpent S411 Eryx 4.0 with ETS Stock setup
Serpent S411 Eryx 3.0 with ETS Stock setup as rain car.
Serpent S120 LTR with 10.5 blinky mode.
spacendeman is offline   Reply With Quote
Old 02-16-2016, 02:04 AM   #153
dan_vector's Avatar
Trader Rating: 25 (100%+)
Originally Posted by Andy63 View Post
I do it like this, fill shock all the way up, let it sit to get rid of air after i pushed shaft up and down. Then i push the shaft all the way up and then i put on bladder and then slowly put on cap while i hold shaft all the way in. Isnt this the right way?
You will probably get negative rebound doing it that way. I've tried Johnny's method but it is quite difficult to do without trapping air in the shock. Try the way I described. There are so many ways really just try them all and decide which is right for you.
Serpent Viper 977e EVO2, Serpent 977 EVO2 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.0, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 02-16-2016, 03:13 AM   #154
Andy63's Avatar
Thanks! This is really one thing ive always struggled with is the rebound on the shocks hehe :P
Andy63 is offline   Reply With Quote
Old 02-16-2016, 05:30 AM   #155
dan_vector's Avatar
Yeah and to be honest the old SS serpent shocks were not the easiest to get zero rebound (positive or negative!). The new shock are MUCH better and easier to build.
Old 02-16-2016, 09:19 AM   #156
Johnny Wishbone's Avatar
My method should expel any excessive oil or air in the system before the cap is put on, and this can be verified if your bladder is opec, once the piston is brought to the top and the ball wrench pressure is removed. This is like doing a normal bleed with the top caps on, but not tight and the piston brought to the top of the 3mm spacer. Be wary though that the top cap is a 2 part procedure, the plastic part is put on and located correctly into the bladder, then the screw cap is installed, I like to keep slight pressure on the plastic part as the screw cap is installed. with the new bladders, or using the Tamiya or Yokomo bladders this works well for me, if your using the old Serpent bladders with the square edge shoulder, there is no easy way to build.
I would agree with Dan though, try them all out and pick the one that works best for you, there a lot of them out there.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 02-16-2016, 09:40 PM   #157
Dork Missile's Avatar
Questions??
how many years does a person have to spend on this thread to understand any of this? i will continue to study and keep reading...
Team Associated/Reedy/Schelle Racing/Go Go Hobbies/Toy Car Creative
B6D/B6/B64D/TC7/RC10R5.2
Dork Missile is offline   Reply With Quote
Old 02-17-2016, 03:20 AM   #158
dan_vector's Avatar
A while... There is some good and useful info here!
Old 02-17-2016, 01:58 PM   #159
axle182's Avatar
Trader Rating: 18 (100%+)
Send a message via MSN to axle182
I have been cutting a few Serpent 411 top decks for a few locals. If anyone wants one, I have two designs, and a few different thicknesses. Sorry for the terrible pic, its all I have right now. PM or email me at kinetic29@shaw.ca Thanks!
Aaron "AJ" Freind
axle182 is offline   Reply With Quote
Old 02-17-2016, 07:43 PM   #160
Default top decks
i have heard of the 3 different top decks...has anyone experimented yet with any of the others? i am told the 1.75mm is the stock TC deck to have. Any opinions out there? if i only have the 2.0mm top deck...i have also heard you can remove some screws to increase flex? which screws?
Old 02-17-2016, 09:45 PM   #161
R3VoLuTiOn's Avatar
Trader Rating: 27 (100%+)
bring the car over to my pits on Saturday, I'll help you out with it.
John Tsang 🏁 VBC Racing 🚗 ORCA RC 🚗 GripworksRC 🚗 MotivRC 🚗 GravityRC 🚗 RC America
http://www.facebook.com/VancouverRRR 🏁 http://www.facebook.com/OvergearedRacing
R3VoLuTiOn is offline   Reply With Quote
Old 02-18-2016, 03:22 AM   #162
Andy63's Avatar
I am pretty sure standard top deck that comes with ERYX 4.0 is the best choice for both carpet and asphalt. For carpet you might need to shim front part 0.1mm to change the flex.
Old 02-18-2016, 05:01 PM   #163
Trader Rating: 309 (100%+)
What's the part number for the 3.5 front?
Jermaine Mitchell
I laugh at serious racers acting like B****
Free Agent racing team. No sponsors needed.
Mercenary Racer
jmoneym is offline   Reply With Quote
Old 02-18-2016, 06:08 PM   #164
corallyman's Avatar
Trader Rating: 99 (100%+)
SER401420 3.5 bracket
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 02-20-2016, 01:37 PM   #165
Default eryx 3.0
looking for aluminum chassis 3.0
EREX_91 is offline   Reply With Quote
