Like Tree5Likes
Old 01-09-2016, 02:47 PM   #31
daveaustin5's Avatar
Originally Posted by LOW ET View Post
any new info on this car?
It's qualified 4th in Mod at the DHI cup which is very impressive when you look at the drivers competing.
Out-qualified Bruno Coelho.
daveaustin5 is offline   Reply With Quote
Old 01-12-2016, 02:05 AM   #32
Default Picture at Redrc.net
Got pictures of the car being used at DHI on Redrc event page.
thesaint is offline   Reply With Quote
Old 01-12-2016, 06:00 AM   #33
Salkin's Avatar
GIZMO on facebook:
https://www.facebook.com/GIZMO-Racin...25389/?fref=ts
Yokomo BD7 2016 Black Series - MuchMore Fleta Pro / MuchMore ZX - Highest DLP650 - Sanwa M12
Salkin is offline   Reply With Quote
Old 01-17-2016, 11:19 PM   #34
Bump,
Does anybody have any news on an estimated release date or price?
Thank you,
Patrick
XCELL is offline   Reply With Quote
Old 02-08-2016, 05:01 AM   #35
kentech's Avatar
Pictures of the display car at the ETS race last weekend.
Lots of nice details/different thinking in this car. Enjoy
https://kentech.wordpress.com/2016/0...lheim-karlich/
kentech is offline   Reply With Quote
Old 02-12-2016, 11:57 AM   #36
Ok, so I'll bite...how to the front and rear axles not spin in different directions?
Kidspeed is offline   Reply With Quote
Old 02-12-2016, 12:07 PM   #37
wtcc's Avatar
The pinion turns in between the two spurs
@kentech: Thanks for great pics!
AE / Reedy / RSD
wtcc is online now   Reply With Quote
Old 02-12-2016, 12:28 PM   #38
1spunspur's Avatar
What's involved in changing the pinion size?
P./
1spunspur is offline   Reply With Quote
Old 02-12-2016, 12:33 PM   #39
DesertRat's Avatar
I think you set the gear mesh by moving the motor up and down slightly.
One thing I like about this setup is you can probably put different sized spurs on either side of the motor and overdrive the front wheels.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi, Xti, and Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model, and B4 Buggy.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 02-12-2016, 12:39 PM   #40
1spunspur's Avatar
Curious thing. That never would have crossed my mind. That is, moving the motor or changing gear ratios f/r. Thanx D rat.
P./
Old 02-12-2016, 10:10 PM   #41
noob question.. what is benefit with overdrive the front? and how did you do that?
nietzbatik is offline   Reply With Quote
Old 02-12-2016, 11:42 PM   #42
1spunspur's Avatar
When the rear tires start to break loose, the fronts well tend to pull it along, making it faster out of the turns. Keep in mind, he did say 'probably'.
P./
Old 02-12-2016, 11:53 PM   #43
DesertRat's Avatar
Its just another tuning option. It mellows out the cars turn-in and transition from corner entry to mid-corner, and gives a little more on-power steering and tends to to make the back of the car follow the front during corner exit. Its not a big change, but noticeable.
I did find that it made the car a little squirly under are braking.
Old 02-13-2016, 01:40 AM   #44
Couldn't you do the same with a traditional car by using smaller pulley in the front than in the rear? Not as fine as with spur gears of course.
perzeus is offline   Reply With Quote
Old 02-13-2016, 02:50 AM   #45
if the motor up and down movement is the only option for mesh adjustment - as opposed to fore and aft for either the motor or the spur - then i can't see how running different sized spurs will work.
Adelaide RC Team Driver - www.adelaiderc.com.au
Support the Shops that Support the Racers
cplus is offline   Reply With Quote
