Like Tree35Likes
Old 08-15-2016, 06:22 AM   #256
Trader Rating: 25 (100%+)
Originally Posted by CristianTabush View Post
Had a great weekend racing the GZ1 at The Full Throttle Championships in Richardson, TX (Dallas).
Qual 5th in 17.5 with a 3rd overall place finish (behind Former National champs Eric Anderson and Kyle Klingforth), battling for position with both of them, finishishing within 2 seconds of the winnner in both A2 and A3.
In Modified, I qualified 2nd and finished second behind National Champion Chris Adams at his home track.
This was only the second time for myself as well as the Gizmo on the new black carpet. I had been up to Dallas 2 weeks before for a very brief testing session before this event. I had never had an extended period of time on black carpet with a sedan before, so I think the results were truly impressive considering the circumstances. The car had the pace to hang with national champions all weekend long, in 17.5 and mod. I'd say it was a succesful debut for the car on CRC black carpet.
Very nice! It's great to hear that this platform works great on all types of surfaces. Any idea on an eta for more kits?
Hopper99 is offline   Reply With Quote
Old 08-15-2016, 06:55 AM   #257
CristianTabush's Avatar
Last I heard was another week or so. They are waiting on sway bar holders from the manufacturers.
CristianTabush is offline   Reply With Quote
Old 08-15-2016, 07:50 AM   #258
Thanks. If we backorder now will we get one from this next batch?
Old 08-15-2016, 08:23 AM   #259
Yes, we have no cars on back order right now. So if you order over the next few days you should guarantee yourself a kit.
Old 08-15-2016, 09:26 AM   #260
LOW ET's Avatar
Trader Rating: 96 (100%+)
when will the spare parts be back in stock, same eta?
LOW ET is offline   Reply With Quote
Old 08-15-2016, 12:10 PM   #261
Which parts are you looking for?
For those of you that are curious here is the set-up sheets along with a small recap of the weekend.
http://gizmoracingusa.com/?p=436
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
Old 08-15-2016, 12:15 PM   #262
Ok, thx for the info.
Old 08-15-2016, 12:20 PM   #263
Default Results
Old 08-16-2016, 09:44 AM   #264
Kurly's Avatar
Default Nice
Very nice run Christian. Found this on Redrc....
http://www.redrc.net/2016/08/adams-a...s/#more-117588
L2Kracing, LeisureHours Hobbies & Raceway
Gizmo Racing USA, ARC USA, Motiv RC.
Kurly is offline   Reply With Quote
Old 08-16-2016, 10:07 AM   #265
For the guys who have the car, what are your thoughts so far? Pros/Cons etc…
Patrick
XCELL is offline   Reply With Quote
Old 08-16-2016, 10:35 AM   #266
Trader Rating: 114 (100%+)
Patrick
The car is stupid fast, ive been picking up .1 after .1. You can read my message on the previous page. Thr build quality is pretty good, a few small issues suck as the shock towers needed sanded down .1mm on thr bottom to fit properly. The fade on thr car is ridiculously low.
Cons you have to buy some extra spur gears, because you can only get 3 teeth per spur gear. But theyare really easy to change, just 4 screws.
thecaptain is offline   Reply With Quote
Old 08-16-2016, 11:37 AM   #267
Kurly's Avatar
Default Gizmo
What turned me on to this car is the infinite adjustments that you can make. I come from an 1/8th scale On road background. We adjust everything by turning the pillow balls out or in to adjust the cars. This car is the same but uses turnbuckles. we can adjust this car in 1/4 to 1/8 turn increments to where other manufactures use braces that choose the increment for you. And you have to buy every one of those pieces. This car comes ready to run and choose every setup you want to put under it. You dont need to run back to the pit to change a toe block. You just adjust it at the track and put the car back down to try your adjustment. I know Im very happy with my car and will do more testing to let everyone know. But, thanks to Christian, I believe I found a good home. Plus this car is very very new. Theres a ton more to come.
Old 08-16-2016, 01:38 PM   #268
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
Patrick
My experience (only a few runs so far)....
Pros
  • on pace out of the box (comparable to my a800)
  • huge amount of forward traction
  • good rotation
  • build quality awesome (just a small amount of hand finishing - just like every car)
  • diff is super smooth and leak free
Cons
very tight fit for electronics
  • depending on motor used, you may have to cut or grind motor tabs down
  • would have liked the brass weight/spine anodised black like the rest of the car
Very happy so far. I race on large outdoor tracks in 13.5t blinky.
Leonard.
:::RCMaker.com.au:::Speedy RC.com.au:::
DirtyDog3375 is offline   Reply With Quote
Old 08-16-2016, 03:02 PM   #269
Thanks to everybody who provided feedback.
Patrick
Old 08-16-2016, 03:21 PM   #270
LOW ET's Avatar
thanks for putting the parts up on the website. order placed
