Like Tree125Likes
Old 08-12-2017, 07:06 PM   #2251
gigaplex's Avatar
Originally Posted by davidl View Post
6.25x5.16x2.81mm I had my hub apart so I measured it. Good luck. Sorry it took so long for you to get this information.
Thanks, that helps
gigaplex is offline   Reply With Quote
Old 08-13-2017, 07:43 PM   #2252
Lone Drifter's Avatar
Has anyone used the Graphite FT bumper brace for the 7.1 # 31649 on the Tc7?
USVTA , USGT and Wheeler
TC7, TC6, T3 11 & 12, and TLR 22-4
Lone Drifter is offline   Reply With Quote
Old 08-14-2017, 08:34 AM   #2253
Trader Rating: 18 (100%+)
Yeah and it helps a LOT.
iTz Nicholas72 is offline   Reply With Quote
Old 08-14-2017, 09:23 AM   #2254
Korey Harbke's Avatar
Should work great considering all of the interfacing parts are the same. It has little extensions that butt against the bulkhead to keep the bumper from folding up in a crash .
Scott R likes this.
Seido Speed Works - Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 08-14-2017, 02:16 PM   #2255
Thanks Im on my second bumper plate
Old 08-14-2017, 02:17 PM   #2256
Thanks as well
Old 08-14-2017, 02:38 PM   #2257
big_ads's Avatar
Trader Rating: 78 (100%+)
Send a message via MSN to big_ads
using longer screws that go all the way through the bumper and putting a washer and lock nut on the top to "sandwich" the bumper plate to the chassis helps in strengthening things as well.
Scott R likes this.
Adam Balk
Northern Mini Racers (www.facebook.com/groups/northernminiracers/)
Team CRC - Protoform/Pro-line - Team Genesis R/C Products - Big Head Racing - Team PRCP
big_ads is online now   Reply With Quote
Old 08-14-2017, 02:47 PM   #2258
Thanks Ill give that a Try as well , The brace is on backorder at the moment . My hobby shop said maybe late August
My Tc6 and my T3 are both supported on the top so ive never had a bumper plate back before.
Old 08-14-2017, 08:22 PM   #2259
Trying to figure out arm mounts.
If the track is tighter (carpet) with a larger chicane would it be better to have 1 dot all around or would it be better to have 1 dot rear with .5 deg arm sweep out front. 1 dot outer with -2 dot front inner.
Or once the grip goes high like crc black one should run 2 dot with with 2.5 deg toe rear and .5 deg arm sweep out front; again achieved with 2 and 3 dot.
I guess in simple terms when do you swap out the default one's for 2's?
irvinew is offline   Reply With Quote
Old 08-15-2017, 07:47 AM   #2260
RobS's Avatar
I just use an upside down Xray upper bumper on top of the stock Associated one. Still leaves about a 1-2mm gap from the sway bar mounts but definitely better then having nothing at all.
Rob Say
Action Hobbies Kingsville
"In racing you never really lose. You either win, or learn."
RobS is offline   Reply With Quote
Old 08-15-2017, 04:12 PM   #2261
Thanks I may have those parts , Ill give it a try.
Ive got the Associated part on order , I was going to shelve the TC 7 till I get it .
Ill see if I can do a temporary fix.
Old 08-15-2017, 06:00 PM   #2262
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
I built my car with the graphite plate, but i have always thought the stock bumper was too soft and sat too low. I broke and put a t4 hard bumper on, sanded so the graphite plate sits just inset of it, and cut it like the stock one to fit the lower plate as the stock one does. since the bumper is naturallythicker, even with the carving ive done, the graphite plate hits more of the plastic in a crash than the stock one would have.
in the stock location, i had my upper plate dalam a tiny bit in a crash. sucks but is life.
My stuff
| Team Associated - Reedy - Reflex Racing/RSD - ProAMPS RC |
My RC
www.irocc.ca - www.wcics.ca - www.vrcworld.com - http://proampsrc.com/ - www.teamassociated.com
valk is offline   Reply With Quote
Old 08-16-2017, 08:30 AM   #2263
Reflex also has a hard bumper and brace set I've heard good things about.
Old 08-16-2017, 12:44 PM   #2264
AlanHall's Avatar
Trader Rating: 43 (100%+)
Send a message via AIM to AlanHall Send a message via Yahoo to AlanHall
Can can I use the yok 8DF16 bladders in 7 and 7.1 shocks ? What is the advantage to these bladders ?
Alan Hall
AlanHall is offline   Reply With Quote
Old 08-16-2017, 12:54 PM   #2265
I think YS-8HD16 only work in the TC7.1 shocks. The material they are made from is harder, and resist swelling a lot better. You can keep using them a lot longer in comparison to the standard silicone bladders.
For the TC7 shocks, I think you need YS-8HD (slightly smaller diameter), but someone else might want to confirm that.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Sean Williams
