Like Tree138Likes
Old 07-15-2017, 04:33 PM   #2221
Originally Posted by WEEZY View Post
Yes it is the yokomo ars kit, the center link I used the small blue spacer from the top deck and the steering rack and a couple shims. Standard turnbuckle works fine for length.
Have you noticed much difference with the ARS? I remember back with the TC6.1 a friend of mine tried ARS and said there was no difference.
glennhl is offline   Reply With Quote
Old 07-17-2017, 12:02 PM   #2222
Default Bumper
I notice reflex isn't stocking their wide bumper anymore; are most people not bothering anymore or is their a good replacement for the stock bumper?
irvinew is offline   Reply With Quote
Old 07-17-2017, 12:04 PM   #2223
RobS's Avatar
If your looking for a hard bumper the Xray low profile bumper is a direct fit. That's what I use.
Rob Say
Action Hobbies Kingsville
"In racing you never really lose. You either win, or learn."
RobS is offline   Reply With Quote
Old 07-17-2017, 01:10 PM   #2224
CristianTabush's Avatar
It's back in stock now.
micrors4guy and Edwin Pibal like this.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 07-17-2017, 01:23 PM   #2225
Unspoiled's Avatar
Not sure why that came innupsode down, posted from my phone. Sorry
Giving away our secrets one pic at a time...
AJ Lorello - Gilbert, AZ
Mugen, Trinity, Fenix, MKS, ActivRC, Hobbywing, Airtronics, Losi, Orion
Unspoiled is offline   Reply With Quote
Old 07-17-2017, 01:25 PM   #2226
Unspoiled's Avatar
Glenn... If its set up correctly it should be a noticeable difference!
glennhl likes this.
Old 07-17-2017, 06:09 PM   #2227
ASM
ASM's Avatar
Trader Rating: 17 (100%+)
Purchased one not too long ago from Cristian and have been very satisfied with the piece!
Scott Meeks
2016 & 2017 ROAR Region 4 VTA Champion
USVTA Member #116
ASM is offline   Reply With Quote
Old 07-17-2017, 07:00 PM   #2228
Thanks Scott. This is definitely one of our best sellers. Sometimes they go out of stock, but since the carbon is mostly cut in house, it's just a matter of cutting a small batch once again.
Old 07-18-2017, 12:42 PM   #2229
Bought 2 of them; thanx for the heads up Christian
Old 07-18-2017, 01:39 PM   #2230
Thanks to you too. I appreciate the support!
Old 07-25-2017, 09:13 PM   #2231
pyro854's Avatar
Going to be picking up a TC7 soon to get back into racing. What parts would I have to buy to convert it to a 7.1 IF i ever decided to? I know the 7.1 has lower shock towers so that means towers/shocks/bearing caps would be needed but im not sure what else, if anything, there is.
RJ Whiteside
pyro854 is offline   Reply With Quote
Old 07-25-2017, 09:49 PM   #2232
Not cheap to convert, most people sell their TC7's and buy a new or used TC7.1. You listed all the items you need. You need the lower shock towers, front and rear (31741 & 31742)($36) and new bearing caps front and rear (31743 & 31744) ($70). Then the big ticket item, a set of new short shocks from Associated (TWO 31760) ($160). It will put you back something like $266 for all the parts retail. If you shop, you should be able to find everything for around $170 (Power Hobby). When I converted mine, I substituted the short shocks from Yokomo and saved some money, but the main reason I did that was the Associated short shocks were out of stock everywhere for quite a while.
The other things you need to be equal to a 7.1 are the front steel outdrives and dual cardon joint front axles. But truthfully even a TC7 needs these mods and most TC7's have them if you buy the 7 used. Good luck.
Old 07-26-2017, 09:27 PM   #2233
Scottrik's Avatar
Trader Rating: 245 (100%+)
Agreed. The only way upgrading makes any sense at all is if you already own a TC7. You can't buy a TC7 and convert it to a TC7.1 and save any money unless someone is pretty much GIVING you the TC7 and I'm not seeing that yet.
fwiw,
Scottrik
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline   Reply With Quote
Old 07-27-2017, 01:38 PM   #2234
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
If he price was right like under $200 usd, just run the car as is. The lowered shocks prob wont be something you can really tell the difference as a returning racer.
If you wanted to upgrade, cristian makes towers that would prob fit the 7.0 upper clamps allowing you to run short shocks. You can also compare the exploded views of the two different shocks and peice budget conversion together. Yoj could prob get by with just the short bodies and shafts though. Maybe lower caps but i doubt it.
My stuff
| Team Associated - Reedy - Reflex Racing/RSD - ProAMPS RC |
My RC
www.irocc.ca - www.wcics.ca - www.vrcworld.com - http://proampsrc.com/ - www.teamassociated.com
valk is offline   Reply With Quote
Old 07-27-2017, 02:16 PM   #2235
DARKSIDE's Avatar
hey young man, how have you been...cool I hope...
but if you have a TC7, depending on what class you coming into...if you are in VTA GT or 17.5...its fine...if beyond that, 7.1...also if you are running on carpet or asphalt....
I wouldnt to much worry with the upgrades, cause you will probably get a new kit soon anyway, and a 7.1 is the way to go
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform
2017 U.S.VTA+ Southern Nationals in Music City U.S.A.
Sept 21-24th @ Thunder RC Raceway
1172 Park Ave, Murfreesboro, TN 37129
DARKSIDE is offline   Reply With Quote
