Like Tree84Likes
Old 04-19-2017, 10:57 AM   #1996
J Lee's Avatar
I did that without the groove or a notch, no problem on the carpet tracks after10+runs.
Originally Posted by Nerobro View Post
Something tells me that AE is using off the shelf ground rod for that pin, and is then cutting (grinding?) the notch in it. Since I don't have my buddys TC7.1 handy, I can't measure the pin myself... but 2, 3, 4, and 5 mm ground tool steel rod is on ebay for $2-3-4. Make your own pins, grind a nice smooth round divot for your setscrew, or perhaps, none at all!
The smallest rods you can buy are like 200mm long, so cut a dozen, and sell to the locals who are cracking their pins. :-) You'd probally come out ahead.
Lets race!
J Lee is offline   Reply With Quote
Old 04-19-2017, 12:46 PM   #1997
beyondthepack's Avatar
Send a message via Yahoo to beyondthepack
Originally Posted by SGrubb View Post
Yep that is to much weight to put in. my car is under weight but only 10 grams so no weight in the front of this car. will try something different.
I put 2 Associated screw on weight on the front near the bell crank. problem solved.
https://www.teamassociated.com/parts...llast_weights/
AE B5R - SC10.2 - Outdoors
AE TC7.1 USGT - INFINITY IF14 - Indoors
LRP - REEDY - FUTABA - IDEAL HOBBIES - RC404
beyondthepack is offline   Reply With Quote
Old 04-19-2017, 02:13 PM   #1998
Thanks i put one in front of the motor mount. so maybe take it off and put it by the bell crank. yes p.s. i also broke two of the pin this last weekend.
SGrubb is offline   Reply With Quote
Old 04-24-2017, 10:08 AM   #1999
I would like to thank everyone over the past couple of months for all the help. so thank you i raced this past weekend MHIC here in colorado 7th in the b-main in 21.5 sedan and 3rd in USGT. in the A-main i had a good weekend of racing.
Old 04-24-2017, 10:30 AM   #2000
Outstanding, we had some Arizona racers go and where they qualified showed me that there was a lot of great drivers up there! Good job.
glennhl is offline   Reply With Quote
Old 04-24-2017, 12:18 PM   #2001
thanks. i have some changes to post. from the team drivers. made my car a lot better. coming soon.
Old 04-29-2017, 04:17 PM   #2002
JUNI is offline   Reply With Quote
Old 04-30-2017, 10:37 PM   #2003
CristianTabush's Avatar
Default New Flex Chassis
Our new flex chassis is now available:
aracefan likes this.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 05-01-2017, 08:06 AM   #2004
looks bad ass. How thick is the chassis?
Old 05-01-2017, 02:35 PM   #2005
Oh, that's purty!!!!
Old 05-01-2017, 03:54 PM   #2006
theproffesor's Avatar
Trader Rating: 55 (100%+)
That chassis does look very nice and I'm sure performs well, I just can't help but ask why?
I somewhat understand using the aluminum chassis to get less flex than the carbon, but on my 7.1, between using all the screws, the motor mount post, and the front steering post through the top deck, my carbon chassis has near zero noticeable flex.
And I thought that's why the aluminum chassis came to be, to stiffen the chassis more than carbon could.
So why now are we going to "flex" aluminum chassis instead of just using the standard carbon or thinner carbon chassis? Other than some nice bling, I just don't get it.
Associated - Fantom - Savox - Hobbywing - Spectrum.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 05-01-2017, 05:07 PM   #2007
The chassis is 2.0mm thick.
I disagree that making a car stiffer is what the largest benefit from aluminum is. The single biggest benefit is that it lowers the center of gravity of the car by putting weight down at it's lowest possible position. The stiffness is a side benefit that may be optimal under certain conditions, but a lower CG is beneficial under essentially all situations.
Now, as to why we offer a more flexible chassis, there are various reasons.
1.As stated before, stiffness is not what we try to achieve necessarily with aluminum, but it can help increase response in conditions of extreme grip. Our approach with the flex chassis is to isolate flex at specific point on the chassis to aid in rotation and increase steering on the car. A more flexible chassis typically provides an "easier to drive" feel, but in most cases makes the car respond lazily. By isolating the flex at the specific positions we target on the chassis we can get some of this response back and get a compromise of response and ease of control. Our flex chassis has more steering than the AE original aluminum one. It is also slightly narrower so it allows you to run slightly lower ride height without rubbing as much.
2.Not everyone races on SUPER high bite. If the grip is less than super high bite, a more flexible chassis has a wider set up window. There was several large races last year, even on black carpet where a lot of people preferred running something that flexes more.
3.Flex chassis are highly effective on asphalt surfaces as well. If the grip is high and/ or the temperature is high, they can lead to more consistent handling and cooler electronics!
4.It's a tuning OPTION. And as such it gives you, the end user the ability to select an item that is in the range between Flexy carbon and Stiffer than-all-get-out aluminum.
Now is it for everyone, in every track condition? Absolutely not. If you are happy with your stiff and solid AE chassis, use what works for you. We are just giving end users options that can help enhance their hobby enjoyment further, by again, providing options.
Old 05-01-2017, 05:58 PM   #2008
Penz316's Avatar
This weekend, at the Quebec National, my associated 7.1 was on point. She was easy to drive and so fast, it was a charm !
Here my setup sheets for you guys !
The track
ASM likes this.
Alex Fournier
Team Associated | Reedy | Team Scream Racing | Hyper Hobbies
Penz316 is offline   Reply With Quote
Old 05-02-2017, 09:37 AM   #2009
Unspoiled's Avatar
Hey Proffesor,
Flex can be your friend and it can be your enemy. Keep in mind there is more flex in a chassis than just grabbing the shock towers and twisting. The locations where the bulkheads and suspension block all flex even if the top deck is locked down. Aluminum reduces the flex there as well.
I have been running the Fenix chassis on asphalt for about 2 months now. I honestly prefer it over the carbon. We run on a high bite asphalt track. I have noticed two big advantages of running the aluminum over the carbon.
#1 - Frees up the car. With our high bite the car looses traction with the stiffer chassis. Add the lower CG and it keeps us from traction rolling. Also helps maintain corner speed.
#2 - Consistency! The aluminum chassis provides a lot of consistency from lap to lap. As temperatures, batteries, motors warm the chassis... You get the same feel out of the car.
I have 2 cars built identically to compare notes. One is carbon and one is aluminum. If traction is low... I prefer the carbon. As traction comes up... I prefer the feel of the aluminum. We recently ran at the Tamiya track for the CTS series. I also preferred the aluminum there.
I personally think you will see more aluminum chassis coming into the market across all brands of cars.
AJ Lorello - Gilbert, AZ
Associated, Hobbywing, Trinity, Airtronics, MKS, Losi, Orion
Unspoiled is offline   Reply With Quote
Old 05-02-2017, 11:45 AM   #2010
aracefan's Avatar
Trader Rating: 33 (100%+)
QFT.
davidl and Unspoiled like this.
All give some, but some give all - thank you veterans for my freedom.
VBC is my new addiction - have Alex Pate at GripworksRC to thank for that!
aracefan is offline   Reply With Quote
