Team Associated TC7 & TC7.1 Touring Car
#1546
I personally made the move from a 6.2-7-7.1 since about june of last year and stepping into racing tc.
the change from 6.2-7 was not noticeable for me. the change from the 7-7.1 was night and day. I am still learning certain things in onroad but i have been much more competitive and consistent since i have moved over to the 7.1. This is also on a low-med bite bumpy carpet surface mostly still running the kit carbon chassis.
IMO the car is more stable, responsive, and predictable compared to the 7. I am on average .2 faster on my average lap times over a 5 min run.
#1547
#1548
I'm with Myron on this one, Looks great, works great. On my TC6.2 I had to grind a bit on the LF corner of the front bracket to get clearance from the steering post, but it was nothing overly challenging. I did a little clearancing on my TC7's. The set was intended for the TC6.1 which had a center-post steering, the dual bellcrank system on the later cars reduces clearance but is not insurmountable by any means.
They are in-stock at Tower/Great Planes, but for whatever reason this is one of the Associated parts they won't sell to dealers (the upgrade pulleys, shock pliers, a few other "specialty" things) so I had to order direct from Tower.
http://www3.towerhobbies.com/cgi-bin...&I=LXFWKS&P=ML
I've literally been using strapping tape from the hardware store and while it works fine, I'd rather deal with velcro.
Matt
#1549
#1550
Do you or anyone else have a pic of how the AE strap kit fits on a TC7? I'm just wondering what it really takes to get it to fit. Are we talking about a tiny notch in the front bracket?
Matt
Matt
#1551
#1552
#1553
the TC7 imo is the best TC Team Associated has ever put out...and I own most of them....the TC7.1 just added that extra !!!!!! to a great chassis...add the aluminum chassis for high bite situations and you have a TC that is one of the best out there....if not the best...the entire chassis is better from the plastics and geometry to the setup and weight....its just a better car
#1554
We will see if the tc7.1 is better than my tc4 special edition....
Who's running the tc7.1 at 360v2 again ??? I've got all my upgrades installed finally, and I will be going from bench racing to carpet racing immediately.....
See you guys soon....
#1555
My only concern is it adds a little height under the batt. I even shaved (literally, with one of my shavers. Lol) the little fibres to make it thinner. We'll see how it holds up.
#1556
Happy new year. got some money for x mas so i put it in my car got alum chassis floating steering and dcv kit and steel outdrives is this a good start to a 7.1 please let me know if the setup is a tc7 or a tc7.1. i should put on. black carpet. we run on. i have the car all apart os now the time to put a good setup on.
